vuelti24
Re: How far out of the way will people connect?
Fri Jun 08, 2018 7:57 pm
Next year I´ll flight MVD-POA-LIS-MAD-FRA because of a very convenient fare. Not a big detour, but a lot of stops on the way...
DaveFly
Sun Jun 10, 2018 11:32 pm
SWF-ATL-SEA (AirTran)
It was convenient to use SWF, the fare was cheap, and the connection was only one hour and added negligible time to the trip.
717,727,737,747,757,767,777,787
L1011,DC8,DC9,DC10,MD80/90
A300,A319,320,321,330,340,
CRJ,E135/45/190,
DH8,Avro85,DHBeaver,AstarHelo,F100,ATR42
Carp12c
Mon Jun 11, 2018 5:46 am
Back in May, I went to Houston from San Francisco by way of ORD and DFW on my first part of the trip and by way of DFW and LAX on the second part of my trip in order to rack up miles. SFO-IAH nonstop roundtrip is 3,270 miles. I ended up flying 4,668 miles, which is only 1,400 more flying miles.
evank516
Mon Jun 11, 2018 8:45 pm
Not sure if you would consider it out of the way but I've flown (and am doing it again next week) LGA-ATL-BNA to avoid flying on an RJ. Ironically the routing makes a check mark if you connect the dots as the crow flies.
crazytoaster
Tue Jun 12, 2018 12:23 am
Back from Queenstown I flew ZQN-WLG-SYD-SFO-ORD-IND instead of a more direct routing of ZQN-AKL-SFO-IND
It was an award ticket and were the only segments I could availability. Ended up having enough time to wander Wellington for a couple of hours and overnighted in Sydney and walked around the opera house. Saved thousands of dollars so totally worth it
DEN homebase. Frequent traveler to IND and RNO.
Users browsing this forum: No registered users and 27 guests
