matthew11
Transiting in Sydney
Sun Jun 10, 2018 8:00 pm
Hello!
Anybody have experience connecting onto another flight via Sydney? I am looking booking a flight AKL-SYD-YVR for the return trip. It would be Air New Zealand connecting to Air Canada via SYD. There is is 1hr 35 mins to connect. Is that enough time or am I risking it?
New Gemini Jets retailer in YYC (Calgary)! Purchase in store or online! http://www.euphoriacafe.ca
jupiter2
Re: Transiting in Sydney
Sun Jun 10, 2018 8:47 pm
As long as your NZ flight is on time there should be no problem. They normally park in the same area of the terminal, so the only hold up will be doing a security screening and for internatiobal transfer passengers, that is usually pretty quick.
n729pa
Mon Jun 11, 2018 9:23 pm
I've transitted via SYD internationally twice. LHR SYD AKL and return on QF. At 5am it was ok. But coming back some passengers were having a nightmare. I had a 10 hour layover so I was letting people go past me in a rush. Like anywhere you get busy times and quiet times. Travel light. You can get through security quicker. If your flight is late your may need to push forward to get through.
grozzy
Tue Jun 12, 2018 1:26 am
The main issue is is it on the one ticket? You'll be good if it is. Otherwise check if there's an interline agreement for baggage. You don't want to be collecting you bags and check in again. There's no time for that.
steveinbc
Tue Jun 12, 2018 3:39 am
In my view 35 .minutes is far too tight for SYD regardless of the arrival and departure within the same terminal. For a start your bags may not make it. Secondly you will be constantly worrying if you're delayed. Thirdly there's only one YVR flight daily and no good option of getting there the same day if you miss it. All9w 90 minutes minimum
A319 320 321 330 340 380 B707 727 737 747 757 767 777 787 BAe1-11 Trident 1, 2, 3B Viscount Lancaster VC10 HS748, ATP DHC-1, 3 Dash-8 Dash-400 Shorts 330 360 Embraer Banderiante Brasileria 175 190 BAe146 Saab 200 DC-3 -8 -9 -10 MD-11 ATR42-72
XAM2175
Tue Jun 12, 2018 6:46 pm
steveinbc wrote:
In my view 35 .minutes is far too tight for SYD ... All9w 90 minutes minimum
matthew11
Tue Jun 12, 2018 9:20 pm
Yes it is one ticket. Baggage will directly connect onto AC. Ticket is booked. Hopefully all will go well. Didn’t have another option.
steveinbc
Wed Jun 13, 2018 12:23 am
Sorry Matthew11
I didn't notice the 1hr in front of the 35m! Yes that is more than sufficient to transfer. Good travels. Steve
matthew11
Wed Jun 13, 2018 2:51 pm
steveinbc wrote:
Sorry Matthew11
Thank you Steve!!
