FlyingHollander wrote:PHX is also at T3 now. Made the connection to my AMS flight at T5 quite tight. The split really isn't an ideal situation and something I take into consideration when looking at BA flights.
alasizon wrote:BA most certainly operates flights out of T3, only a handful but as I recall it is mostly the low-J 744s.
EastLondoner wrote:alasizon wrote:BA most certainly operates flights out of T3, only a handful but as I recall it is mostly the low-J 744s.
You quite often see an A380 parked up as well at Terminal 3. I imagine this is the Miami flight.
LiviFlier wrote:How long was your connection, I'm the same domestic into T5, off to MIA from T3, with 2 kids
tomkell92 wrote:Miami is an A380. I think that's the only A380 flight from T3, but might be wrong.
Pretty sure Vancouver is from T5.
The rest of the T3 flights are operated by 747's (long haul) and A320's (short haul) - there's a few A320neo's operating out of T3 as well.
LiviFlier wrote:FlyingHollander wrote:PHX is also at T3 now. Made the connection to my AMS flight at T5 quite tight. The split really isn't an ideal situation and something I take into consideration when looking at BA flights.
jubaexpress wrote:There's an airside bus. Takes about 20 minutes on the bus. Depending on the time of day you might get on the first, if not the second, with frequency about every 5-10 minutes. Done it a few times now onto the Nairobi, which leaves at 12 ish. In that direction T5-T3 at lunchtime it took about 30-40 minutes all told. Reverse at 06.30 it took more like an hour, waiting for the second bus and queuing for security. But that was off of EU flights, not domestic.
FlyingHollander wrote:jubaexpress wrote:There's an airside bus. Takes about 20 minutes on the bus. Depending on the time of day you might get on the first, if not the second, with frequency about every 5-10 minutes. Done it a few times now onto the Nairobi, which leaves at 12 ish. In that direction T5-T3 at lunchtime it took about 30-40 minutes all told. Reverse at 06.30 it took more like an hour, waiting for the second bus and queuing for security. But that was off of EU flights, not domestic.
I definitely didn't get on the first or second bus. More like bus five or six, and we were one of the first economy passengers of our flight to get there. Obviously this isn't always the case, but it does happen.
FlyingHollander wrote:LiviFlier wrote:How long was your connection, I'm the same domestic into T5, off to MIA from T3, with 2 kids
I'm not exactly sure. Our inbound was delayed. I think door to door we had about 1:15h. We walked fast, but the line for the busses and the ride itself took quite long. After going to the restroom and getting a sandwich at Pret, we were second to last on the plane.
CarbonFibre wrote:Why do the BA neo's only use T3?
LiviFlier wrote:I thought BA was all in Heathrow Terminal 5? Just booked flights from LHR to MIA and it lists T3 as the departure terminal. Is this right?
jghealey wrote:CarbonFibre wrote:Why do the BA neo's only use T3?
I asked the same question a while ago - apparently it's to keep them in one place. Hopefully when the A321neos come they'll move them to T5
