SFODXBFRALHRBLR
Airports With Most A380 Capable Gates (including remote stands)
Mon Oct 01, 2018 3:20 am
I've been doing some "research" (counting off the number of gates through Google Maps), and it's quite unreliable, as some airports have A380s park at gates with 2 jet bridges, and some at remote stands. Can someone help me with this?
Why do I like the A380 so much?
Bradin
Re: Airports With Most A380 Capable Gates (including remote stands)
Mon Oct 01, 2018 3:26 am
What is your definition of an "Airbus A380" capable gate ?
FlyHappy
Mon Oct 01, 2018 3:27 am
soooooooooooooooooooooooooooooo.... there cannot possibly be any other answer than DXB for #1 , yes?
after that.... who cares?
FA9295
Mon Oct 01, 2018 3:34 am
Yes. It's obviously DXB.
SFODXBFRALHRBLR
Mon Oct 01, 2018 3:35 am
A gate or remote stand at an airport with regularly scheduled A380 flights capable of handing the A380.
SFODXBFRALHRBLR
Mon Oct 01, 2018 3:36 am
I mean, of course, but I was looking for a list.
notaxonrotax
Mon Oct 01, 2018 5:10 am
Toulouse has a few, too.
No Tax On Rotax
For anybody that happens to be wondering:"yes, owning your own aircraft is a 100% worth it!"
sixfootscream
Mon Oct 01, 2018 5:48 am
Let me think. Which airport has the most A380 operations. #MustbeDXB
CARST
Mon Oct 01, 2018 6:13 am
Bradin asks a very valid question here. Because there are no "A380 capable gates" in real life. We have gate categories and the largest one is category F which is a square box of 80x80m (or 262.5x262.5ft).
Here's the full list Stitch posted into a thread nine years ago:
ICAO Annex 14 - Aerodrome Reference Code
(Aeroplane Wingspan; Outer Main Gear Wheel Span)
Code A - < 15m (49.2'); <4.5m (14.8')
Code B - 15m (49.2') - <24m (78.7'); 4.5m (14.8') - <6m (19.7')
Code C - 24m (78.7') - <36m (118.1'); 6m (19.7') - <9m (29.5')
Code D - 36m (118.1') - <52m (170.6'); 9m (29.5') - <14m (45.9')
Code E - 52m (170.6') - <65m (213.3'); 9m (29.5') - <14m (45.9')
Code F - 65m (213.3') - <80m (262.5'); 14m (45.9') - <16m (52.5')
There are other gate / parking spot sizes, but usually the shortest side defines into which category a spot falls. Because if you have a parking spot 70m wide, but only 60m long, you get the wingspan of certain aircraft into that spot, but not its length.
So counting double jet bridges is not relevant either, because a lot of aircraft use double jet bridges. 747s, 777s, 767s, some 757s, A330s, A340s, A380s...
Also the category F is not only required by the A380, but also by the 747 (since its existence), by the 773/77W, A346 and other aircraft longer than 65m.
So the only thing that was build on purpose for the A380 were tripple-jetbridge gates, where one jetbridge is dedicated to serving the upper deck. And these are only found on a few airports in the world. Usually the mega hubs. And sure DXB will be number one here, without having numbers on hand, but I guess that's a safe bet.
Perhaps someone has a list with all airports with tripple jet bridge gates?
Another point is, that while most larger airports have category F gates to take up 747s, A380s, etc., not all of them are A380 capable. And why is that? Mostly because the A380 has such a wide wingspan. That wingspan fits into the 80m-cat-F-box, but it's too wide for many taxiways and wouldn't allow the use of parallel taxiways, runways or even could collide with structures/buildings beside the taxiways. So that's the number 1 reason why you don't see the A380 at certain large airports (like HND).
Fitlikemin
Mon Oct 01, 2018 6:30 am
DXB, then the home airport of those airlines with the biggest A380 fleets presumably.
aviatorcraig
Mon Oct 01, 2018 7:07 am
In addition to CARST's excellent detail above, any airport that can accept an A380 and has somewhere to park it (e.g. remote stand) could be considered to have "A380 capable gates".
An A380 can be serviced, enplaned and deplaned with one set of steps... it just takes a long time!
707 727 Caravelle Comet Concorde Dash-7 DC-9 DC-10 One-Eleven Trident Tristar Tu-134 VC-10 Viscount plus boring stuff!
JWKIII
Mon Oct 01, 2018 7:16 am
Thanks for this CARST. Interesting table about the different stand codes. Just this summer I also had a unique experience in Frankfurt. A double jet bridge for an A321. So you can add that to your list as well :)
A380MSN004
Mon Oct 01, 2018 7:46 am
What about DWC?
hooverman
Mon Oct 01, 2018 8:43 am
LAX, LHR and CDG can handle a bunch.
LH779
Mon Oct 01, 2018 8:59 am
FRA too. I counted 12 gates with 3 jetways, 9 at T1 and 3 at T2.
Kiwirob
Mon Oct 01, 2018 10:21 am
Baku has an A380 gate, and another couple than can be converted to A380 configuration, but it's never as far as I can find out been used, it's just another vanity project.
AKL has 4 A380 gates with a number of hard stands for A380's as well.
OA940
Mon Oct 01, 2018 11:05 am
I'd put Lukla on that list :D
Seriously though, I heard that the new IST has 12 or 16 A380 gates (can't remember which)
A350/CSeries = bae
SomebodyInTLS
Mon Oct 01, 2018 11:25 am
The myth that the A380 requires special gates goes on...
"As with most things related to aircraft design, it's all about the trade-offs and much more nuanced than A.net likes to make out."
skipness1E
Mon Oct 01, 2018 11:45 am
It’s not a myth. Every existing gate at LHR not at new build T5 and used for A380s had to be re-aligned and rebuilt at considerable expense. Code F capable gates are pretty rare to be fair.
TonyBurr
Mon Oct 01, 2018 12:19 pm
Would SIN have a number of such gates ?
SomebodyInTLS
Mon Oct 01, 2018 2:27 pm
Maybe - but "code F" ≠ "A380-only". A380 was very deliberately built to an *existing* standard.
SFODXBFRALHRBLR
Mon Oct 01, 2018 10:44 pm
Yes, but then I wanted to differentiate between gates in let’s say a US airport’s domestic terminal used to handle B747 and in it’s international terminal being used to handle B747 and A380. I wanted a count of gates used to handle the A380, it’s fine if they handle other aircraft when the A380 is gone.
FlyRow
A380MSN004 wrote:
What about DWC?
If plans go as planned. I wonder if there is any gates now.
100% sure no jetway-gates (at all), remote I can't say.
F70-F100-RJ85-RJ70-E190-319-320-321-733-734-735-737-738-752-753-763-764-772-744-380
SFODXBFRALHRBLR
Mon Oct 01, 2018 10:47 pm
FlyRow wrote:
A380MSN004 wrote:
What about DWC?
Wait, why did this thread change topics? How does this topic have any relevance to the thread?
e38
Tue Oct 02, 2018 1:44 am
SFODXBFRALHRBLR, I noticed you joined two months ago.
With reference to your question above, " why did this thread change topics? How does this topic have any relevance to the thread?"
It happens all the time on Airliners.net.
e38
SFODXBFRALHRBLR
Tue Oct 02, 2018 2:10 am
e38
Oh ok. Thanks.
FlyRow
Tue Oct 02, 2018 11:11 am
FlyRow wrote:
A380MSN004 wrote:
What about DWC?
I don't see how my answer was Off-Topic.
One poster suggested DWC as the airport with the most A380 gates.
I answered, in the future, it will probably be the airport with most Code-F gates. But for now, I'm not even sure they have code-F stands, they don't have jetway-gates for sure..
All in line with your question.....
SFODXBFRALHRBLR
Wed Oct 03, 2018 3:13 am
I wasn’t talking about the question, I was talking about the whole thread. I accidentally quoted you.
PatrickZ80
Wed Oct 03, 2018 5:59 pm
Not a myth, by far most gates are too narrow for an A380. It does require special gates that are wide enough. Sometimes this is being solved by keeping the gates left and right empty.
However you don't need a gate with three jetways. Sure it goes faster that way, but in fact the number of jetways doesn't matter.
Recently I've been told that Amsterdam has two gates that are capable of handling an A380. They don't need more since very few A380s actually serve Amsterdam. The only airlines that fly an A380 there are Emirates and China Southern.
SomebodyInTLS
Wed Oct 03, 2018 11:08 pm
http://www.boeing.com/assets/pdf/commer ... ngroup.pdf
Code F is 65-80m wingspan. A380 fits within code F.
"Most gates are too narrow for an A380" is just saying "most gates are not code F"... or maybe "some gates were built larger than code E but are not actually code F compliant".
