LondonXtreme
US Pre-clearance in LHR?
Wed Oct 10, 2018 6:40 pm
If both DUB and SNN have right now. Will US Pre-clearance ever come to LHR? The demand is way higher than Irish airports in terms of the number of passengers and daily flights.
rutankrd
Re: US Pre-clearance in LHR?
Wed Oct 10, 2018 6:48 pm
Not any time soon, although it is planned at Manchester in the T2 rebuild subject to inter government agreements in next few years
At Heathrow with US departures across three terminals it would cost a fortune and need so many US border agents on station it just won’t be worth it imho.
LupineChemist
Wed Oct 10, 2018 7:17 pm
I think maybe in the long term once the toast rack is complete it might be possible to have 1 pier shared between airlines and dedicated to US flights. But that'd be many years in the future and who knows.
LondonXtreme
Wed Oct 10, 2018 7:21 pm
That's what I think, it's easier to have 1-2 pier specifically designed for US flights.
Wed Oct 10, 2018 7:30 pm
I doubt BA would want that now that they have most of their flights under one roof. It just causes too much inconvenience for connecting passengers and makes it more complicated for BA to turn around aircraft if they have to tow them between terminals.
Cubsrule
Wed Oct 10, 2018 7:33 pm
I’m not necessarily advocating preclearance for LHR, but do note that YYZ has two preclearance facilities, one for AC and UA and one for everybody else. I assume that would be the most sensible setup at LHR given the volume.
codc10
Wed Oct 10, 2018 7:36 pm
Less a pier and more an entire terminal... it would need to serve literally dozens of widebody departures per day, and royally (no pun intended) muck up what BA has finally established at T5, which is some semblance of a coherent connecting facility.
LupineChemist
Wed Oct 10, 2018 7:37 pm
The idea would be in the future where there aren't really separate terminals as such any more and the transit train would go all the way across the airport ATL style. Obviously this will have to be well after T3 is history.
LAXintl
Wed Oct 10, 2018 7:43 pm
Back in the day(1980s) LHR used to have pre-clearance.
As far as it happening today, back in 2015 DHS announced both MAN and LHR were selected for preclearance pending negotiations with the UK government. In 2016 Edinburgh was also added to the list pending final negotiations with the UK side.
OMAAbound
Wed Oct 10, 2018 7:46 pm
There just isn’t the space or man power available for such operations.
They would have sacrifice gate/stand space, then in peak hours they wouldn’t have enough space to sell the pre-clearance as a product and during the off-peak hours that space would have to sit empty and idle.
The other thing to take into consideration. The likes of SNN/DUB/AUH to name but a few, want too entice you to use their facilities. LHR on its own has such a huge pull on customers (pax & Airlines), it doesn’t need Pre-Clearance.
OMAA
That just sounds overly complicated and mighty expensive. So someone traveling with BA to the US would check in at T5, take a train to preclearance and then a train back to T5. The whole train system would need to be segregated and only dedicated to those traveling to the US. Also, you would need to keep those pax segregated in each terminal after preclearing. I dont see that working.
DobboDobbo
Wed Oct 10, 2018 8:00 pm
And since 2015/16 the political compass in the USA and U.K. has changed significantly - I can't imagine it is too high on the list of priorities right now...
PatrickZ80
Wed Oct 10, 2018 8:01 pm
Heathrow is just too big and too complicated to have every flight to the USA pre-cleared. However you could have a partial pre-clearance, where some flights to the USA are pre-cleared and others are not. Pre-clearance would only be available at a certain part of the airport which might be far away from the rest of their flights. Each airline decides if they want to make use of the pre-clearance or not, both options have their advantages and disadvantages.
Speaking of that, at Dublin there currently is pre-clearance and all airlines flying from Dublin to the USA make use of it. However, suppose an airline wants to fly from Dublin to the USA without using pre-clearance. Would that still be possible? Or is pre-clearance mandatory?
747megatop
Wed Oct 10, 2018 8:15 pm
In addition to too big and complicated i would add "cramped". The place is a cramped mess during peak hours...add to that the pre clearance hassles and delays as a bottleneck with a long line of passengers building up at the bottleneck? May be just offer it out of a separate terminal at LGW for O&D passengers (is there space?)...or perhaps a separate terminal in LHR (where is the space?).
Arion640
Wed Oct 10, 2018 9:18 pm
I don’t think pre clearance is mandatory, I’m assuming any flights not wanting to make use of it would just depart the other area of DUBs terminal.
AmricanShamrok
Wed Oct 10, 2018 9:29 pm
Preclearance is not mandatory and some airlines do not avail of it at preclearance airports (e.g. ET at DUB and KU at SNN).
Themotionman
Wed Oct 10, 2018 10:09 pm
I'd say that regarding the UK side, the changes make it more likely.
VS11
Wed Oct 10, 2018 10:33 pm
Correct me if I am wrong but I thought the host country would have to pay for a pre-clearance facility. I also thought the pre-clearance in Ireland had to do with immigration levels in the past - better for the airlines to have pax denied admission before they fly them and back messing their seat inventory.
MIflyer12
Wed Oct 10, 2018 10:52 pm
You can argue it's a facilities issue. It's not a manpower issue. YYZ is the #2 foreign gateway and had 12.5 million non-stop passengers to the U.S.
LHR had 14.6 million for the 12 months ended Sept. '17. CUN and MEX each had more than #5 NRT.
Malayil
Wed Oct 10, 2018 11:00 pm
I’m against it unless the US is willing to build UK preclearance facilities at the top 10 gateways from the US to the UK.
fbgdavidson
Wed Oct 10, 2018 11:26 pm
Really? Where and for which airlines?
LAXintl
Wed Oct 10, 2018 11:36 pm
No problem. The agreements are reciprocal and the UK is within its rights to staff such facilities in the U.S.. Considering however that not even Canada is willing to take on such a costly venture, doubt the UK will when its Border Force is so understaffed.
LAXintl
Wed Oct 10, 2018 11:38 pm
T-3 and briefly T-4. PA and BA participated. Maybe also TW, but I don't have first-hand knowledge.
TWA772LR
Wed Oct 10, 2018 11:47 pm
Does the UK have preclearence?
When wasn't America great?
Bhoy
Wed Oct 10, 2018 11:52 pm
I would suggest the difference is at YYZ, where I used pre-clearance at Terminal 1 in 2011 is that there is a dual purpose gate area which can be segregated depending on amount of cross border flights from the rest of the International departures. at Heathrow, that's not really possible, as already domestic and international Passengers are mixed at both Terminals 5 (BA) and 2 (BE and EI), so having an extra segregated area in an already tight space is probably difficult (and Ferrovial would hardly want to stop customers- sorry, passengers, accessing some retail areas of the Terminals).
As B747forever pointed out, it would potentially mess up BA Aircraft arriving from Asia/Africa/Canada/South America that were due to turn around for flights to the US, as they would arrive at Gate areas for non-US arrivals, and would have to be towed to Gates for US arrivals. This wouldn't be so much an issue at YYZ (where only AC and WS are affected, as AA, DL und UA just turn round to where they came from), for example, where I'd suggest half of AC's narrowbody departures are to the US (the other half are domestics) [admittedly I don't know enough about WS' operations] - for all BA have a lot of flights to the US, it can't be as high a proportion of longhaul departures. The same issue would apply to VS (albeit they have very few non US flights any more) - again, AA, DL, NZ and UA turn round so would stay at the same gate. This could even cause issues for AI should they wish to use pre-clearance, as their flight would arrive from AMD on a non US gate, and through Passengers would have to collect bags and clear US Immigration and recheck bags whilst the Aircraft was being moved to a US Gate, all within the 2 hours 15 minutes until scheduled departure to EWR.
Bhoy
Thu Oct 11, 2018 12:04 am
In Calais for the Ferry to Dover and for Eurotunnel. But at Airports is another matter...
To be honest, there's not many places it would make much sense to have staff stationed fulltime - probably only JFK, but again only if all departures (AA, BA, DL, DY and VS) could be grouped in one Terminal.
It's not like departures to the States from Europe or Canada that are spread out over the day, as apart from 2 or 3 day time flights, most departures from almost all Airports Stateside are within a 4 or 5 hour window due to night curfews at either end, which doesn't really mandate having fulltime staff on a Station.
B752OS
Thu Oct 11, 2018 12:10 am
Who pays for these such facilities in say YUL?
LondonXtreme
Thu Oct 11, 2018 12:12 am
Maybe they can do partial preclearance at Heathrow.
For example, US3 and VS flights can all gather in the same terminal, whereas BA don't use preclearance.
ramzi
Thu Oct 11, 2018 12:37 am
It would be pretty interesting to have DL, VS, and UA have a concourse with preclearance, while AA and BA have a joint concourse which includes all US-bound BA flights that also has preclearance. Maybe this is something that can happen in the coming 10 years.
There will come a time when you believe everything is finished - that will be the beginning.
PatrickZ80
Thu Oct 11, 2018 6:11 am
Norwegian doesn't fly from Heathrow, only from Gatwick.
londonistan
Thu Oct 11, 2018 7:03 am
No room. Period. And too complicated.
jfk777
Thu Oct 11, 2018 8:17 am
Too complicated and too many terminals involved. You would have to rearrange all of Heathrow airport. Who is going to pay for this fantasy project ? People who say this should happen have no clue how many flights go from LHR to the USA.
haynflyer
Thu Oct 11, 2018 9:25 am
The host airports pay for the facilities and the US CBP pay rent as far as I can tell. As an example, on January 15, 2015, Incheon International Airport announced that it would not introduce the U.S. preclearance after an in-depth analysis concluded that U.S. preclearance could lead to decreased sales at duty-free shops, despite the potential income from usage fees remitted for the use of preclearance space.
"Nearly all men can stand adversity, but if you want to test a man's character, give him power." - Abraham Lincoln
DobboDobbo
Thu Oct 11, 2018 9:58 am
Quite right, and in the long term I agree.
In the short run, the most pressing issues raised by the change in the UK's political compass will occupy the majority of government bandwidth, kicking things like USPC down the list (assuming USPC is not a priority).
LupineChemist
Thu Oct 11, 2018 10:12 am
Rearrange Heathrow you say?
https://www.heathrowexpansion.com/the-expansion-plan/
Nothing to do with US preclearance.
tonystan
Thu Oct 11, 2018 11:04 am
It would be a substantial investment but really would not be that difficult to implement. Only three terminals have Atlantic operations, T2, T3 and T5.
T5, one of the satellites would need converting (or construct a new one) and I would use C as an example simply because it has the space above departures where no lounges have been installed as an ideal spot for the hall. I simple swing gate system could be installed much like T2 in Dublin.
Likewise something similar could be done at T2 with perhaps one end of the satellites pier being allocated to USPC and again a simply implemented swing gate system so the gates could be used more efficiently.
T3, well this Terminal is a mess on a good day. It’s had its day and would probably require a major overhaul but perhaps annexing the gates 16-22 pier or the 30-40s would be the best option but I’m not 100% familiar with this terminal.
The other option is to simply convert T4 to purely USPC departures and move all flights to there but not sure how either HAA or the airlines may feel about that!
My views are my own and do not reflect any other person or organisation.
Bhoy
Thu Oct 11, 2018 11:31 am
I was talking about potential UK preclearance at JFK. Otherwise I'd have substituted UA for DY if I was talking about LHR rather than JFK.
EIDL
Thu Oct 11, 2018 11:36 am
The old immigration only precheck was brought in as the rejection rate was getting so high as to endanger Ireland's visa waiver programme membership. By refusing them in Ireland it didn't count for those purposes.
JibberJim
Thu Oct 11, 2018 12:09 pm
You state that as if there are lots of terminals, those "only three" terminals represent 75% of the terminals and 88% of the passengers.
I don't think terminal 4 handled enough passengers last year for all LHR-USA traffic, even despite the fact the US traffic is heavily biased in the time it goes out?
Bhoy
Thu Oct 11, 2018 12:30 pm
Oh, and another thought - lots of traffic ex-LHR is connecting traffic through the Joint Ventures, so it wouldn't be as easy as at YYZ or DUB where connecting Pax will (for the most part) all be under one roof.
Pax arriving at Terminal 2 on an EI or BE codeshare connecting to a T3 VS (BE) or T5 (BA) flight - would they have to claim luggage at T3, and carry it to wherever preclearance was, or would there be a YVR style video link to identify their bags?
Likewise BA Pax arriving at T5 connecting to an AA flight out of T3, or even AF, KL or AZ passenger arriving at T4 connecting to VS or DL in T3?
T2 would be the only terminal that offered guaranteed under same roof JV connections (UA-LH/LX/SK/OS), which would mean a lot of extra segregation for keeping arriving Pax, transiting Pax who weren't security cleared, transiting Pax to US waiting for preclearance, precleared departing US Pax and security cleared departing Pax separate.
Suddenly all Terminals ARE involved, to some degree, and you can bet your bottom dollar none of the Alliances want their JV to be without a preclearance that others enjoy for marketing reasons.
tonystan
Thu Oct 11, 2018 3:29 pm
Doesn’t make my point any less relevant! A costly albeit relatively easy system to implement.
slcdeltarumd11
Thu Oct 11, 2018 3:59 pm
Won't happen. You do understand that building a facility in a place with as little room and as over crowded as LHR would be very difficult and very very very expensive. They were pretty easy to add onto SNN and DUB. LHR would be a 1000x more complicated a project than those airports for so many reasons.
2Holer4Longhaul
Thu Oct 11, 2018 4:16 pm
It's logistically impossible in Heathrow, at least until they complete the toast rack in 2396. Likewise for Gatwick.
Maybe Boris Island could've been built with preclearance, maybe.
"You know, if you just set out to be liked, you would be prepared to compromise on anything, wouldn't you, at any time? And you would achieve nothing!" - Margaret Thatcher
Virtual737
Thu Oct 11, 2018 5:19 pm
Don't have pre-clearance anywhere. Have fit for purpose Immigration and Customs at the point of entry.
You know which flights are arriving well in advance.
You know the vast majority of the passengers and their entry requirements well in advance.
Pre-clearance is a bad solution to a problem that shouldn't exist in the first place.
Quit moving your problems to somewhere else.
Yes the UK could learn from this too.
directorguy
Sun Oct 14, 2018 12:51 pm
The UK is more likely to join the Schengen Zone than sign up for US pre-clearance.
Users browsing this forum: Calledonian, Gillbilly and 30 guests
