sergegva wrote:The noise inside the cabin depends on the aircraft model, but also on the type of engines installed, and there are several possible ones for all these aircraft.
No, not really. In case of different engine options (of the same generation) on the same A/C model, cabin noise will be rather similar. Along most of the cabin the engines are not the dominant noise source anyway, it is the boundary layer (on the fuselage skin) and on some models even the cabin air distribution. Only in the aft of the cabin the engines play a role, but there it is not the engine itself but its exhaust jet. Latest generation engines tend to be quieter here, but that is again not due the engine itself but mostly its exhaust velocity and bypass ratio.
sergegva wrote:As for the location of the seat inside the aircraft, I would say, the closer you are to the engines, the louder it gets, no matter what the front or back.
Again: No, not really. During takeoff and climb you will have some buzz saw noise in the fwd cabin in front of the engines. During cruise it will be exhaust jet noise (far) behind the engines. The middle of the cabin above the wings (and closest to the engines) is often the quietest part of the cabin during cruise.
In the fwd and mid cabin the ranking is (quiet to noisy) A330/B787 - B777, in the aft cabin it is rather B787 - B777 - A330. But in any case I wouldn't make my decision depending on cabin noise, they all are far too noisy for your health and comfort during a 10h flight.
Gruß, masi1157
