KICT
Single Jet Bridge Airports Outside of the US
Sun Nov 18, 2018 10:26 am
Single (or dual) jet bridge airports aren't common per se in the US, but they can be found and found fairly often. Some that come to mind here in the US include Elko NV, Sitka AK, Topeka KS, and Ithaca NY to name a few. But what about elsewhere in the world? Are there many single jet bridge airports outside of the US? None come to mind...
People are saying. Believe me.
TheEuphorian
Re: Single Jet Bridge Airports Outside of the US
Sun Nov 18, 2018 1:45 pm
In Thailand:
UTH
UBP
URT
KBV
Cunard
Sun Nov 18, 2018 3:20 pm
BHD Belfast City Airport in Belfast, Northern Ireland, United Kingdom is the only airport in that country that has a single AirBridge.
Do not get confused with BFS Belfast international Airport which is Northern Ireland's principal international gateway which has four AirBridges.
94 Countries, 327 Destinations Worldwide, 32 Airlines, 29 Aircraft Types, 182 Airports, 335 Flights.
PatrickZ80
Sun Nov 18, 2018 3:47 pm
Pisa (PSA) only has one jetbridge, all other gates use bus boarding and airstairs.
Phosphorus
Sun Nov 18, 2018 7:22 pm
IEV, Kiev's city airport (as opposed to KBP, the main airport) seems to have one jet bridge only; rest of flights board via buses.
AN4 A40 L4T TU3 TU5 IL6 ILW I93 F50 F70 100 146 ARJ AT7 DH4 L10 CRJ ERJ E90 E95 DC-9 MD-8X YK4 YK2 SF3 S20 319 320 321 332 333 343 346 722 732 733 734 735 73G 738 739 744 74M 757 767 777
Ceterum autem censeo, Moscovia esse delendam
FlyRow
Sun Nov 18, 2018 9:09 pm
Lelystad Airport (LEY). Although it is a (real) jetway connecting the museum with a 747-200B.
F70-F100-RJ85-RJ70-E190-319-320-321-733-734-735-737-738-752-753-763-764-772-744-380
opticalilyushin
Mon Nov 19, 2018 9:07 am
Mmmm nope, having worked at both i can assure you BFS only has 1. It hasn't had 4 bridges since hmm..The 1990s or perhaps early 2000s?
flyingclrs727
Mon Nov 19, 2018 10:14 pm
My home airport, CRP, had one jet bridge that WN built for its gate for about 25 years before the original terminal was replaced with the new terminal in 2002. The new terminal is much more compact, and all the gates are on the second floor and have jet bridges.
I flew into IEV a few years ago. As I recall they had busses to take passengers between the gates and the aircraft. I don't think I saw the lone jet bridge.
KICT
Tue Nov 20, 2018 1:19 am
It's definitely there: https://goo.gl/maps/282VTRiExx12. How old is that terminal? There isn't much ramp rash. Is it even used?
Though not attached to a terminal per se, BA maintenance at CWL has a jetbridge they use to load/unload cabin fittings: https://goo.gl/maps/Cph7CiRuors.
Bologna seems to have jetbridge piers, but none actually attached.
Cunard
Tue Nov 20, 2018 2:37 am
Thanks for clarifying that as I was under the impression that BFS still had the four AirBridges but to be fair I haven't used the airport since 1999.
Can you also clarify why three were removed?
Cunard
Tue Nov 20, 2018 2:39 am
British Airways also have a single AirBridge at it's maintenance base at LHR for the same use as the one at it's maintenance base at CWL.
KICT
Tue Nov 20, 2018 4:55 am
The AMC terminal at Ramstein has a dual jetbridge terminal: https://goo.gl/maps/FdPVp1xfWL92.
Cunard
Tue Nov 20, 2018 4:59 am
The former USAF Base at Mildenhall in the United Kingdom also had one single AirBridge.
opticalilyushin
Tue Nov 20, 2018 11:40 am
I imagine they were probably condemned! The bridges around the (what is now) stand 14 and 18 areas probably fell out of favour with the low cost airlines that came in, and the one at 27 was a nose loader.
Themotionman
Tue Nov 20, 2018 12:07 pm
LBA has two, CWL has three according to Google Earth
Cunard
Wed Nov 21, 2018 1:22 am
That is absolutely correct and spot on but the topic of the discussion is Airports that have only a ''SINGLE AIRBRIDGE'' not two, not three but a single AirBridge, singular as in ONE.
PanzerPowner
Wed Nov 21, 2018 9:07 pm
Ah but that is where you are wrong, as the OP said "single(or dual)"
Well uh, I obviously decided to refine this but i dont know how.
Cunard
Thu Nov 22, 2018 8:44 am
Then I guess that the OP should change the headline to his thread title from SINGLE to DUAL as it clearly states SINGLE in the thread title even though in his opening post it has single or (dual) in brackets as in (dual).
I'm sure there are many examples of airports with (dual) AirBridges throughout the world but airports with just a singular AirBridge are rather more unique aren't they.
Users browsing this forum: No registered users and 20 guests
