ExpatVet
BUD-FRA-VCE, 50 minute connection
Sun Dec 09, 2018 7:53 pm
So, boss booked my flights for a trip in January (I asked for a different itinerary with a longer connection, but there you go) - in a nutshell, what are my chances? Flying LH.
Thanks in advance!
L101, 733/4/5/8, 741/2/3 (never managed 744!), MD 80/2/3/8/90, MD11, DHC8/3/Q4, E170, E195, 757, 77W, 763/4, Travel Air 2000. A300/310, A319/320/321, A333, probably a few others I forget. Passenger, not pilot, alas! BUD based.
steveinbc
Re: BUD-FRA-VCE, 50 minute connection
Mon Dec 10, 2018 2:51 am
My personal opinion. At FRA you will never do it.
A319 320 321 330 340 380 B707 727 737 747 757 767 777 787 BAe1-11 Trident 1, 2, 3B Viscount Lancaster VC10 HS748, ATP DHC-1, 3 Dash-8 Dash-400 Shorts 330 360 Embraer Banderiante Brasileria 175 190 BAe146 Saab 200 DC-3 -8 -9 -10 MD-11 ATR42-72
masi1157
Mon Dec 10, 2018 6:24 am
Of course he will. It is LH I assume?
Gruß, masi1157
503 different segments on 98 airlines to 208 airports in 55 countries
EricAY05
Mon Dec 10, 2018 6:17 pm
A couple of weeks ago I had a similar 65min connection and even had time to enjoy the lounge for about 25min. On the outbound journey I had 55min and (unfortunately) made it just barely after the first flight was a little late. Would have loved to receive compensation and spend some time in the lounge.
PatrickZ80
Mon Dec 10, 2018 7:22 pm
That's a tight connection. If all flights are on time, you should be able to make it. However if the first flight is delayed, good chance you'll miss your connection.
An alternative might be a direct flight on Ryanair to Treviso (there are no direct flights from Budapest to Venice, this is the closest available). You could suggest this to your boss. From Treviso airport there is a direct bus connection to Venice. Since Ryanair is most likely cheaper than Lufthansa your boss will be glad since it will save him money.
LTU932
Mon Dec 10, 2018 9:59 pm
It could be doable since it is a Schengen flight, but I wouldn't bet on it. Get at least 90 minutes of connection.
upperdeckfan
Tue Dec 11, 2018 9:24 am
I connect through FRA a lot and if BUD-FRA is on time you should make it. As both flights are schengen you just have to walk from one gate to the other. Gates are normally open until 10 minutes prior to scheduled departure.
To be more relaxed I hope you don't get a remote stand in FRA, then you might have to run off the bus.
Final note, try to get a seat as forward as posible, it could be up to a 10-minute advantage to deplane.
748,744,742,741,772,773,762,763, 732,733,735,737,738,739,752,722, 717,74M,DC10,DC9,M82,M83,M87, M88,310,319,320,321,332,333,343, 346,359,388,L1011,CR2,CR9,CR10,
E175,E190,ATR42,DSH8,CS1,CS3
Tue Dec 11, 2018 10:30 am
If you miss your flight due to a delay which is not out of control for LH, you might be entitled for full compensation under EU law. If so, you can invite your boss for a beer for booking this tight connection! :highfive:
ExpatVet
Tue Dec 11, 2018 12:58 pm
It would be cheaper, yes, but I am going for company training, and the Ryanair flight to Trevizo is only twice a week at the wrong time of day. (afternoon flight on Tuesday, I need to be there Tuesday morning)
Would prefer a direct flight, absolutely! Thanks :)
IAHWorldflyer
Tue Dec 11, 2018 8:39 pm
For what it's worth, I've been on a slightly delayed ( 15 minutes) flight into FRA, and I've seen LH call passengers with a tight connection ( they know who you are) to deplane first, and provide a car or minibus shuttle directly to that person's onward gate.
LH748
Fri Dec 14, 2018 12:40 am
Doable but you need a bit of luck that both gates are close to each other
306 310 318 319 320 321 333 343 388 ATR72 733 737 738 739 743 744 748 752 753 763 764 772 77W 788 CRJ7 CRJ9 E170 F100 MD11 RJ1H
AA AB AC AF AK AZ BA DE DL EW FD FR HF HG IB IR MF KU LH LT LX OD TG TK TP UA VJ VN WN W6 YP YW
ExpatVet
Sat Dec 15, 2018 7:23 am
Yep, i’m packing the running shoes :)
RamblinMan
Wed Dec 19, 2018 3:57 pm
As with anything work-related, you offered your advice to your superior, he chose to ignore it, so the consequences are on him. At this point I'd hop on the plane as booked and hope for a misconnect.
dangerhere
Thu Dec 20, 2018 5:09 pm
I'm always amazed when people book such dog-legged routes. Surely it's possible to do a connection with a more logical routing, like Vienna or? Granted you get there on time, but the flying route is literally double the distance between Budapest and Venice, which is not even so far apart in the first place.
masi1157
Thu Dec 20, 2018 7:19 pm
You know Lufthansa? You know Frankfurt Airport? People don't simply book such connections. These connections are offered for booking by Lufthansa. And they wouldn't continue offering them if a significant percentage of passengers regularly missed the connection. Of course that can happen and it happens from time to time. But in that case they would book you on the next flight, they pay a hotel if necessary, they pay a compensation etc. Personally I made a lot of connections at FRA with only 45', and all of them worked. Some required a bit of running and on some of them my bags didn't make it. But even that was rare.
Gruß, masi1157
dangerhere
Thu Dec 20, 2018 8:24 pm
Gruß, masi1157
I do indeed know both very well. What I mean is more that, that is this was the routing I simply wouldn't book with LH just because they offer it. Of course they will offer it, but most people should not assume that LH or KLM are suddenly the only way to get from A to B or C. Most likey the person booking it for the OP couldn't give two fiddlers about that aspect yet they will be wondering in a few years how the firm needs to find cost savings from somewhere, or why the rate of inflation keeps rising lately.
I get that in this case some HR person / the boss booked this using the company card and without much care. My point is that a bit of due diligence and research would have produced far better results than a detour as far north west as Frankfurt. My attitude would be that if the connection routing is crap, don't book it. There's no reason in Europe for such back tracking unless you are flying long haul and even then it's questionable in some cases. A quick look and I found BUD-VIE-VCE with OS, offering less stress and the same level of service, far less backtracking and a far more efficient route for everyone, just as one example.
masi1157
Thu Dec 20, 2018 8:44 pm
I would assume we are talking about the flights BUD 6:20 8:05 FRA 8:55 10:10 VCE. At least that is the only one I can find with a 50' connection at FRA. It was probably booked because of the early arrival at VCE at 10:10 to get the guy to the company training the same day. The only alternatives I found so far around that time of day are BUD 6:00 8:20 CDG 9:35 11:15 VCE on (obviously) AF and BUD 6:20 8:20 BRU 9:50 11:25 VCE on SN. Both get you to VCE an hour or more later and are even worse of a detour. Out of the three, which one would you book or recommend?
Gruß, masi1157
upperdeckfan
Fri Dec 21, 2018 11:44 am
You are simplifying it big time, there are plenty of reasons beyond "stress" and "route efficiency" why a route like this is booked,
Time of departure from origin.
Time of arrival to final destination.
Total time - including layovers - .
Cost
As said in the last post, in this case the earliest arrival time was LH through FRA. If you need be in Venice as early as possible without having to get there the night before it doesn't sound a crap routing to me.
Last week I flew VLC-AMS through LIS, I made a 55 minute conection with no hassle. I had an appointment for dinner in Amsterdam and I bet you it was the shortest total flying time with a reasonable departure time out of Valencia - not having to wake up at 4'00 - .
dangerhere
Fri Dec 21, 2018 2:22 pm
Cost
Perhaps, I suppose my attitude to this is: different strokes for different folks ect.
mchei
Sun Dec 23, 2018 5:11 pm
Been there, done that :)
LH has been paying more attention to these tight connections recently in the context of their excellence program. I don’t recall the name of this service program but after all the issues LH had due to the Air Berlin downfall and the insane growth of Eurowings, it’s getting better. I was picked up at the aircraft and was driven to the bus of my connecting flight twice in the last couple of weeks at FRA and MUC.
I would go for it, to be honest.
F70-F100-E145-E170-E190-319-320-321-735–736-737-738-752-763–742-744-333-343-ATR72-Metroliner-Saab2000-Lockheed Electra-C172-C182-C182RG-MD11
ExpatVet
Tue Jan 08, 2019 12:35 pm
Just as a minor update, the inbound flight was delayed due to deicing, so it wasn't enough...well it would have been,but the departing flight fra-vce decided to close the gate 7 minutes early. (and I ran like hell too!)
Getting from the remote stand to the terminal took forever.
Looking forward to the "I told you so" conversation ;) first flight i've missed in 5 years. Got rebooked on the next flight so no biggie.
upperdeckfan
Tue Jan 08, 2019 3:16 pm
Shame for you...
That's the issue with FRA, chances of a remote stand are bigger than anywhere else...wish you better luck next time
devron
Tue Jan 08, 2019 4:36 pm
Enough delayed to get compensation?
Tue Jan 08, 2019 6:36 pm
No, de-icing or better weather is an act of god, outside of the control of the airline. So, no compensation. However, if LH is living up to its 5star status, they have offered vouchers for food & drinks.
devron
Tue Jan 08, 2019 6:41 pm
Ah correct a free beer, cool (might have been to early for this)
ExpatVet
Wed Jan 09, 2019 6:02 am
Nope, not a thing!
senatorflyer
Tue Jan 15, 2019 2:05 pm
ExpatVet wrote:
Nope, not a thing!
Problem with tight connections is that even if you do make it, sometimes your luggage doesn’t.
VSMUT
Wed Jan 16, 2019 10:39 pm
ExpatVet wrote:
Nope, not a thing!
Did you have to wait over 2 hours?
ExpatVet
Sat Jan 19, 2019 5:09 am
VSMUT wrote:
ExpatVet wrote:
Nope, not a thing!
Yes, a hair under 3 hours.
VSMUT
Sat Jan 19, 2019 9:14 am
ExpatVet wrote:
VSMUT wrote:
ExpatVet wrote:
Nope, not a thing!
Then you are entitled to a meal voucher, no excuses. My experience is that you may have to ask for them at the service desk.
ExpatVet
Sat Jan 19, 2019 10:57 am
Ah well. Will remember for next time. Thanks! :)
Users browsing this forum: FlyingHollander, IADCA, TOGA10 and 40 guests
