  • 1
  • 4
  • 5
  • 6
  • 7
  • 8
  • 24
Einheitsdesign
Re: How to find Tail Number from old Flight Thread
Thu Nov 04, 2021 6:12 pm
Lowcountryflyer wrote:
Thank you so much again! I have done some sleuthing using Flightstats and old Acars data to identify a few different tails including the ones I posted. I cannot be 100% certain but i found a few. I still have a few more if you can help:
Either Delta 92 (ICN-ATL) on 6 Jun 2009 or Delta 200 (ATL-JNB) on 6 Jun 2009. Based on arrival departure gates, this plane turns into the one I want on 7 Jun 2009 (Delta 201)
Delta 65 on 31 Dec 2001 (MAN-ATL)
EY418 on 25 Nov (left at 240AM local time) on AUH - KUL. I think it is A6-ETB based on a picture but it could also be A6-ETD
AF 1970 on 17 Oct 2004 (LHR-CDG) - I can't find it on LHR/LGW
AF 1571 on 15 Oct 2004 (CDG-LHR) - same as above
OZ 318 on 9 Mar 2009 (TAO-ICN)
DL 463 on 29 Dec 2005 (ATL-YVR) and DL 464 on 30 Dec (YVR-ATL redeye)
FR 9156 on 30 May 2006 (SDR-CIA)
NZ 15 on 14 Jul 2002 (LAX-SYD) and NZ14 on 4 Aug 2002 (SYD-LAX)
JL 745 on 15 Mar 2008 (NRT-MNL)
DL 100 on 21 Dec 2001 and DL 101 on 19 Dec 2001
DL 100 on 9 Jun 2002 and DL 101 6 Jun 2001
DL 109 on 30 Jul 2001 (MAD-ATL)
DL 108 on 27 Jun 2001 (ATL-MAD)
DL 5426 (operated by ExpressJet) on 6 Oct 2014 (ATL-YUL)
Not that much findings from my side
Delta 65 on 31 Dec 2001 (MAN-ATL) N860DA S. North Atlantic Tie-Ups
AF 1970 on 17 Oct 2004 (LHR-CDG) - I can't find it on LHR/LGW F-GFKA S. Lhr-Logs
AFR1970 FGFKA A320 LFPG 1501 215 27R
AF 1571 on 15 Oct 2004 (CDG-LHR) - same as above F-GFGK S. Lhr-Logs
AFR1571 FGFKG A320 LFPG 1216 211 27R
Lowcountryflyer
Thu Nov 04, 2021 8:30 pm
Thanks as always. Every flight helps. What about this one - DL 91 ATL-ICN on 5 Jun 2009
Einheitsdesign
Fri Nov 05, 2021 10:02 pm
Exceptionally a question from my side. ;) These are the last flights where I am missing the reg. Does anyone have maybe a solution or suggestions where I have not yet looked? Many thanks in advance.
1991-07-21 KL0643 AMS JFK 1800 ----
1991-08-03 KL0642 JFK AMS 1735 ----
1993-10-17 DL0073 FRA JFK 1130 1500 L15
1993-10-31 DL0106 JFK FRA 1945 0835 763
1999-08-14 AF1607 DUS CDG 1345 1455 737
1999-08-14 AF7730 CDG NTE 1635 1735 F100 (op.by DB, Brit Air)
1999-08-19 AF1906 CDG DUS 1305 1415 (737 o. 320)
1999-08-19 AF7725 NTE CDG 1050 1155
2002-05-25 SK0467 OSL CPH 1430 1535
2004-03-31 CE0802 JNB CPT 1515 ----
2004-03-31 EK0761 DXB JNB 0340 ----
2004-04-08 CE0801 CPT JNB 0945 ----
2004-04-08 EK0764 JNB DXB 1900 ----
Lowcountryflyer
Tue Nov 09, 2021 10:55 pm
I wish I could directly help since you have been so helpful. The only trick that I have had on my side is the following (which you have already thought of):
Use available sources on tails & schedules (e.g. LHR/LGW ACARS and Departed Flights, respectively) to build a table of flights in and around your days. You can piece together some and might be able through process of elimination figure out which tail it could be. I did this for some flights from 2000-2010 where I combined flights stats for time/gate, whatplane.com for US domestic flights, ACARSD, LHR/LGW and old schedules to narrow down what registrations it could be and what the rotations look like (knowing that they change). This might help you on DL 73 and DL 106 as there are only so many L15 flights and 763 flights into out of JFK. The rotation could easily be DFW-FRA-JFK-FRA-ATL or something like that. I know the LHR/LGW Acars data sometimes picks up some of these flights so you could potentially figure it out or narrow it down via process of elimination.
I also wonder if the FAA or others keeps old flight records. If you are a US citizen, a FOIA request might work. Its likely not there but could worth a shot. Do you have your old boarding passes by chance? It is easier with Cirium flight stats post 2006, but you could try and reverse engineer the potential tails that fed something like EK761 because most likely it came from a plane that arrived 1-3 hours before your departure. If you can figure out any of those tails, you could maybe figure it out. Hope this helps - the last few registrations are definitely the hardest.
Speaking of which, any chance in figuring out these:
DL 7 on 4 Jun 2009 DXB ATL (leaves DXB at 2230 on 4 Jun so 5 Jun ACARS might have it)
DL 8 on 3 Jun 2009 ATL DXB (leaves ATL at 2140 on 3 Jun so 4 Jun ACARS might have it)
MH 78 on 12 Jun 2015 KUL HKG
MH 765 on 12 Jun 2015 REP KUL
MH 408 on 30 Aug 2014 KUL TPE (leaves at 0125 KUL time)
CM 498 on 26 Aug 2015 PTY MSY
Einheitsdesign
Wed Nov 10, 2021 9:01 am
I really appreciate your suggestions. Thank you. I will try them in the dark winter months.
Regarding your request here my findings
should be the same reg as DL8. According to Acars DL8/DL7 were always same reg in June 2009
DL 8 on 3 Jun 2009 ATL DXB (leaves ATL at 2140 on 3 Jun so 4 Jun ACARS might have it) N707DN
N707DN (unknown ) 1211 20090604 DL0008 (IAH-ATL-DXB) S. Acars CPH
Did you really fly from ATL to DXB to return with the next flight back to ATL?
MH 78 on 12 Jun 2015 KUL HKG 9M-MXV S. Planefinder
MH 765 on 12 Jun 2015 REP KUL 9M-MXQ S. Planefinder
MH 408 on 30 Aug 2014 KUL TPE (leaves at 0125 KUL time) 9M-MLN S. Planefinder
InnsbruckFlyer
Wed Nov 10, 2021 9:29 am
Might anyone be able to find the registration of UA941, FRA-ORD, on August 31st, 2008? Would be much appreciated!
InnsbruckFlyer
Wed Nov 10, 2021 9:55 am
TK33 IST-IAH on September 4th, 2013, would also be appreciated :)
Einheitsdesign
Wed Nov 10, 2021 9:58 am
N220UA (B772 UA) 1311 20080831 UA0941 (FRA-ORD-LAX) [[+01:00] somewhere [1.70RC2]]
TK33 IST-IAH on September 4th, 2013, would also be appreciated!
TK33 IST-IAH on September 4th, 2013 TC-JJG S. Planefinder
InnsbruckFlyer
Wed Nov 10, 2021 10:18 am
Dankeschön, Einheitsdesign! :)
Lowcountryflyer
Wed Nov 10, 2021 10:37 pm
Thanks - and haha no, I did not fly ATL-DXB-ATL. However, I am 95% sure that the plane I flew on 7 Jun 2009 from JNB to ATL was that plane. I traced using Cirium Flight Stats and departure arrival gates that the plane l flew on from JNB did ATL-DXB-ATL-ICN-ATL-JNB in the days before. I figured somewhere along the way that Acars would pick up the tail.
Quick question - how do you get the planefinder data? I have tried that data but I cannot get anything old. I have a bunch of flights from 2011 to 2016 that I would love to find the registration using planefinder or Acars (or anything)?
Anyone else have any ideas on how to find registrations for Delta Connection / ExpressJet and Delta Connection / Comair flights in the 2011 and 2012? I have tried the usual sources (WhatPlane/BTS, FlightStats, Flightaware), but none of them have registration.
Einheitsdesign
Thu Nov 11, 2021 5:05 pm
Ok, that makes sense but to be honest I've heard about so many crazy trips that this travel seems not to be impossile. 8-)
To use planefinder for flights between mid of 2011 until today you need a premium membership and the app only works on IOS systems back that far. So if you have an Ipad or Iphone then it could make sense but please be aware that the small planes are seldom tracked back in 2016 and older.
InnsbruckFlyer
Fri Nov 12, 2021 12:06 pm
Got a couple of more flights that I'd like to find the registrations for:
LH2229 - CDG → MUC - December 16th, 2010
LH1704 - MUC → SOF - December 16th, 2010
LH1427 - SOF → FRA - January 1st, 2011
LH1042 - FRA → CDG - January 1st, 2011
TG662 - BKK → PVG - January 1st, 2013
NH920 - PVG → NRT - January 1st, 2013
UA876 - NRT → SEA - January 1st, 2013
OS797 - VIE → SOF - July 29th, 2013
TK1028 - SOF → IST - August 30th, 2013
VY1518 - NCE → BCN - December 23rd, 2013
CA1517 - PEK → SHA - March 15th, 2014
Many, many thanks in advance to anyone who can find out at least one of them!!
Einheitsdesign
Fri Nov 12, 2021 2:12 pm
LH2229 - CDG → MUC - December 16th, 2010 EANS CDG shows callsign DLH57P D-AIQK DLFD MUC shows DLH57P as incoming flight. stated times fits to STD and STA
LH1427 - SOF → FRA - January 1st, 2011 D-ABWH S. DLFD
LH1042 - FRA → CDG - January 1st, 2011 D-AISK S. DLFD
TG662 - BKK → PVG - January 1st, 2013 HS-TBB S. Flightaware
NH920 - PVG → NRT - January 1st, 2013 JA610A S. Flightaware (via outgoing flight NA919)
UA876 - NRT → SEA - January 1st, 2013 N229UA S. Flightstats
TK1028 - SOF → IST - August 30th, 2013 TC-JFH S. Flightaware
VY1518 - NCE → BCN - December 23rd, 2013 EC-LML S. Planefinder
CA1517 - PEK → SHA - March 15th, 2014 B-2090 S. Flightaware
For the follwoing flight I only found the callsign but maybe it can help you in the future or when you search in other forums:
LH1704 - MUC → SOF - December 16th, 2010 should be callsign DLH8JW E190 Augsburg Air
InnsbruckFlyer
Fri Nov 12, 2021 2:44 pm
I can't thank you enough, Einheitsdesign!!! Very much appreciated!!
danvs
Sun Nov 14, 2021 3:43 am
Hi,
I've been trying to find the regs of these flights for many many years, to no avail. I'd appreciate if anyone can help me find them.
I'm also looking for the flight number of a few of them.
I know they're quite old and really hard to find out... thank you in advance!
DATE--------FLT # -------------- ETD EQPT REG
2005-11-27 AZ882 MXP CAI 1030 321 (------)
2005-11-25 AZ673 GRU MXP 1710 772 (------)
2005-08-07 AC427 YUL YYZ 2000 762 (------)
2004-09-25 AM576 CUN MEX 1125 M87 (------)
2004-09-14 AM15 GRU MEX 2355 762 (------)
2002-01-04 TP1575 LIS GRU 0950 343 (------)
2002-01-04 TP5711 MAD LIS 0825 319 (------)
2001-12-19 TP5712 LIS MAD 1125 319 (------)
2001-12-18 TP1576 GRU LIS 2005 343 (------)
2001-07-13 LH502 FRA GRU 2230 343 (------) * LHR/LGW Acars indirectly gave me D-AIGZ ??? (by using rotation, flt LH503 GRU-FRA caught on July 15)
2001-07-13 LH3295 SVO FRA 1910 --- (------)
2001-06-24 LH3250 FRA SVO 0825 320 (------)
2001-06-23 LH503 GRU FRA 1305 343 (------) * LHR/LGW Acars gave me D-AIGV for this date. However, considering I overflew Europe and landed in the early morning of Jun 24th, may be it is D-AIGY?
1999-07-31 (or 07-30) SN---- BUD BRU ---- 146 (------) departed late afternoon or early evening
1999-07-28 MA--- FCO BUD ---- F70 (------)
1999-07-19 MA--- BUD FCO ---- 73S??? (------) departed morning or early afternoon
1999-07-04 MA--- BCN BUD ---- 73S (------) departed morning or early afternoon
1999-06-30 VP784 SSA BCN 0145 M11 (------)
1998-12-22 AR1160 EZE GRU 2130 742 (------)
1998-12-15 AR1161 GRU EZE 0755 742 (------)
1997-12-28 VP821 AUA GRU 0850 M11 (------)
1997-12-21 VP820 GRU AUA 0100 M11 (------)
1997-08-02 BA2245 LGW GRU 2130 744 (------)
1997-08-02 BA2833 CDG LGW ---- 734 (------)
1997-07-15 BA2509 LIS LGW ---- 73S (------)
1997-07-12 BA2508 LGW LIS ---- 73S (------)
1997-07-11 BA2244 GRU LGW 1915 744 (------)
1996-02-06 RG833 LIM GRU 0130 743 (------)
1996-02-05 RG833 LAX LIM 1330 743 (------)
1995-12-07 RG836 GRU LAX 0110 743 (------)
1995-07-23 RG863 JFK GRU 0915 743 (------)
1995-07-16 RG862 GRU JFK 1110 743 (------)
1995-04-25 VA945 CCS GIG 2330 D10 (------)
1995-04-25 VA--- PUJ CCS ---- 72S (YV-126C)
1995-04-19 VA--- CCS SDQ PUJ ---- ---- 72S (YV-126C)
1995-04-19 VA945 GRU CCS 1050 D10 (------)
Einheitsdesign
Sun Nov 14, 2021 11:49 am
danvs wrote:
Hi,
Unfortunately I can't provide lots of help.
2001-07-13 LH502 FRA GRU 2230 343 (------) * LHR/LGW Acars indirectly gave me D-AIGZ ??? (by using rotation, flt LH503 GRU-FRA caught on July 15) should fit. LH503 flighttime 1325 -0605
2001-06-23 LH503 GRU FRA 1305 343 (------) * LHR/LGW Acars gave me D-AIGV for this date. However, considering I overflew Europe and landed in the early morning of Jun 24th, may be it is D-AIGY? LH503 flighttime 1325 -0605, so it's a hit.
24/06/2001 04:52 D-AIGY LH0503 Airbus A340 SBGR - EDDF
1999-07-31 (or 07-30) SN---- BUD BRU ---- 146 (------) departed late afternoon or early evening could be SN272
1999-07-19 MA--- BUD FCO ---- 73S??? (------) departed morning or early afternoon could be MA400
danvs
Tue Nov 16, 2021 2:42 am
That's awesome, thank you so much for your help!
Thank you! I wish I had at least the timetables of these airlines...
Einheitsdesign
Tue Nov 16, 2021 4:37 pm
I don't have the timetables for 1999.
My suggestion for MA400 based on the timetable for 1997 and then I searched Flightmemory if there are flights with that flightnumber in 1999.
https://airline-memorabilia.blogspot.co ... results=20
For BUD-BRU I can't remember how I got this number but on Flightmemory you can find flights in 1999 BRU-BUD-BRU with flightnumbers SN271 til SN274.
BWIAirport
Wed Nov 17, 2021 7:21 pm
Is someone able to find these two flights for me?
March 18, 2012 UA1438 IAH-SJD
March 25, 2012 UA1453 SJD-IAH
Einheitsdesign
Thu Nov 18, 2021 4:56 pm
March 18, 2012 UA1438 IAH-SJD N26226 S. Flightaware
March 25, 2012 UA1453 SJD-IAH N27724 S. Flightaware
I really hate it when an airline has so many aircrafts of the same type. It's so much typing until you find the right reg, because the one you're looking for is always at the end of the list. :shock:
BWIAirport
Thu Nov 18, 2021 9:21 pm
Wonderful, thank you so much!
pilatus
Wed Nov 24, 2021 1:08 pm
Is there any chance to get data from the 1990's? Within the US I was able to find regs, but flights leaving the US seems tricky. If anybody has an idea:
- 06 AUG 1995: IAD-CDG, United Airlines B747-100 (or -200), arriving in CDG on 07 AUG 1995
Chris
Einheitsdesign
Sat Nov 27, 2021 9:54 pm
2010-12-16 LH1704 MUC-SOF 1305 1600 E95 D-AEMB (op.by Augsburg Airways) S. VFT
N626AA
Sat Nov 27, 2021 10:09 pm
Could anyone help me verify that Spirit Airlines #735 on 06/26/2008 FLL-SAT was operated by A319 N507NK? This is the only flight in my Flight Memory page I have a question mark next to.
Thank you
InnsbruckFlyer
Sat Nov 27, 2021 10:44 pm
Thank you!
Dolf1
How to confirm airports (LHR vs LGW and JFK vs EWR)
Mon Nov 29, 2021 5:21 am
Have a flight on PAN AM on 6/13/90 B747 N737PA London to New York, but not sure if it is LHR or LGW and JFK or EWR. I presume it's the first options in both cases, but can anyone confirm? Thanks!
Einheitsdesign
Re: How to confirm airports (LHR vs LGW and JFK vs EWR)
Mon Nov 29, 2021 9:22 am
This ist what I found.
Seems impossible to attached files.
According to Pan Am timetable eff. 24.05.1990 the flights were LHR-JFK
PA0101 1140 1340
PA0001 1300 1540
PA0011 1800 2040
Here the link the to the timetable
https://digitalcollections.library.miam ... 277/rec/73
Lowcountryflyer
Thu Dec 02, 2021 8:21 pm
LX 1104 ZRH MUC on 1 Oct 2004
LX1104/01Oct04 ZRH-MUC was A319 HB-IPR, scheduled departure 12:20 lt, actual departure 12:49, runway 28.
Thanks again - since you seem to have the connection on LX, could you help with the following:
LX1105 3 Oct 2004 MUC ZRH
LX 464 3 Oct 2004 ZRH LCY
Czm
Hunting down planes with weird tail numbers
Fri Dec 03, 2021 5:21 am
I’m trying to find some details on planes I flew on in the 1990s. I have the flight numbers and dates, and I was able to look up the tail numbers. I’m trying to find what type of plane they were. The problem is that the tail numbers are nonstandard: N067AA and N072AA. Every source I can find says there shouldn’t be leading zeros. None of the aircraft registries I can find have any record of them, although they have other planes from that era. Looking up those tail numbers without the zeros gives me planes that aren’t airliners, clearly the wrong ones. The tail numbers seem right, since I’ve found them in several databases, but always without details on the actual planes. Anyone know what’s up with these odd tail numbers?
KLMatSJC
Re: Hunting down planes with weird tail numbers
Fri Dec 03, 2021 6:44 am
Those are AA fleet numbers. 067 is N8067A and 072 is N70072. Both A300s.
Einheitsdesign
Fri Dec 03, 2021 8:03 am
KLMatSJC was so nice and delivered already the tail numbers but if you are interessed in the how to solve, please find as follows an instruction that I found in another forum;
[i][i]Looking Up Tail Numbers for Historical Flights
Here is one approach to identifying tail numbers for a historical flight:
Query the BTS Database Detailed Statistics by Departures or Arrivals for your airport, airline (AA or MQ), and date(s) - select "All Statistics". Note that this will only work for domestic flights back to 1995. For recent international flights, you can try querying the ACARS databases listed in the next section. There is also a dedicated site with historical flight information to and from LHR and LGW.
Identify your flight number and the corresponding tail number. Here's the catch - AA actually reports fleet numbers to the BTS, in the format N###AA, where ### = fleet number. So, you may see what are invalid registration numbers. Some older American Eagle flights are also reported in the format N###MQ, where the two trailing letters are actually not MQ.
Query rzjets.net by fleet number (and airline if necessary) to identify the true tail number for your aircraft. For American Eagle flights, you can query rzjets.net by registry, omitting the last two characters. Also note that Embraer 140 (ERD) and Embraer 145 (ER4) aircraft are both registered under Embraer ERJ-145; Embraer 140 (ERD) aircraft have registry numbers N8##AE while Embaer 145 (ER4) aircraft have registry numbers N6##%% and N9##%% (where %% is often AE, but not always). N800AE was the first E140 aircraft delivered to American Eagle, the launch customer.
Example 1 - AA1 JFK-LAX 1/1/08
• A query of BTS Detailed Statistics - Departures for All Statistics, New York - Kennedy, American Airlines, Jan, 1, 2008 returns AA0001 as N321AA.
• In this case, the tail number is accurate, and a query of rzjets.net for registry N321AA returns the same tail number, a Boeing 767-223(ER). Interestingly, this tail number was previously assigned to a Douglas DC-7, the Flagship Rhode Island.
Example 2 - AA375 JFK-DFW 1/1/08
• The same BTS query above returns AA0375 as N4YNAA. Obviously, this is an invalid tail number and the fleet number is 4YN
• In this case, the tail number is invalid, so a query of rzjets.net for fleet number 4YN returns N979TW, which was formerly operated by TWA Trans World Airlines prior to the merger with AA in 2001.
Example 3 - AA4465 LGA-CLE 1/1/04
• This is an American Eagle flight, so a BTS query for All Statistics, New York - LaGuardia, American Eagle, Jan, 1, 2004 returns MQ4465 as N718MQ.
• In this case, the tail number is inaccurate, so a query of rzjets.net for registry number N718 and operator American Eagle Airlines (EGF-MQ) returns the real tail number, N718AE, an Embraer ERJ-135LR. This aircraft previously had a registration number of PT-SJR, which was used temporarily during delivery from Embraer, with PT designating a Brazilian aircraft.
[/i][/i]
LXM83
Fri Dec 03, 2021 7:59 pm
Hello Lowcountryflyer
These are the results:
LX1105 03Oct MUC-ZRH STA 15:10, ATA 15:06, RJ100 HB-IXW
LX464 03Oct ZRH-LCY STD 16:00, ATD 16:21, RJ100, HB-IXQ
Always a pleasure to help someone complete their logs.
Einheitsdesign
Sun Dec 05, 2021 9:45 pm
danvs wrote:
Hi,
Got two more for you:
2001-07-13 LH3295 SVO FRA 1910 2235 319 D-AILU
2001-06-24 LH3250 FRA SVO 0835 1135 320 D-AIQB
S. VFT
AdamCSmith
Sun Dec 05, 2021 10:38 pm
Hello all,
After many years of being an occasional reader of a.net, finally signed up to post in this thread :)
Thanks to all who have shared tips on where to find information or data on old flights! Einheitsdesign and george77300 seem to have been particularly helpful, but many others as well.
I'm hoping you guys may be able to help me with a few missing data points of my own. I first started tracking my flights back in 2015, but have dug up a lot of data using FlightAware, Acarsd.org, and other resources, but a bunch have still eluded me. I'm wondering whether the community here might be able to help with some of these (list below).
By the way, for someone who commented on Acarsd.org's 2009 files all being missing, this had driven me nuts until recently, when I realized I could use the Wayback Machine to potentially dig them out, and that worked. If you go back to an image from early 2010, all of the 2009 files should be accessible from there.
Here are the flights I'm hoping to find the registration numbers for:
2014-02-21 DEN-ABQ UA3856 (op by YX) DH4 - this flight does not appear in the USDOT database that was mentioned above, unfortunately. But I'm certain of the flight # etc - it checks out with FlightStats
2012-09-03 YYC-IAH AC8106 (op by QK) CR9
2011-10-14 YUL-YTZ AC7523 (op by RS) DH4
2011-07-31 YQR-YYC AC8439 (op by QK) CRJ
2011-07-30 YYC-YQR AC8430 (op by QK) CRJ
2011-07-15 TIA-MUC LH1739 (op by IQ) E95
2011-07-11 MUC-TIA LH1736 (op by IQ) E95
2010-08-20 IAH-YYC AC8105 (op by QK) CR9
2010-08-18 YYC-IAH AC8104 (op by QK) CR9
2010-07-17 INN-FRA OS285 (op by VO) DH4
2010-05-10 HZP-YYC 5T??? 73L - I know this one is a long shot, same with the next one, which was the outbound
2010-05-10 YYC-HZP 5T??? 73L
2010-04-06 YYC-YYZ AC134 E90
2010-03-13 EWR-YYC AC585 E90
2010-03-09 YYC-EWR AC584 E90
2009-12-08 YYZ-YYC AC145 321
2009-10-22 YVR-YYC AC224 320
2009-10-20 YYC-YVR AC225 319
2009-09-09 YYC-YUL AC1144 E90
2009-08-25 YXE-YYC AC8591 (op by QK) CR9
2009-08-20 YYC-YXE AC8139 (op by QK) CRJ
2009-04-12 LAS-YYC WS979 73G
2009-04-07 YYC-YVR WS545 736
2009-03-25 YYC-YVR WS545 736
2008-12-07 YYJ-YYC WS502 736
2008-12-03 YYC-LAS WS950 73G
2008-11-24 YYZ-YYC AC117 319
2008-11-24 YUL-YYZ AC7783 (op by QK) CR9
2008-11-21 YOW-YUL AC632 319 - there should also be a YUL-YYT leg with same flight number, that would also work
2008-11-21 YYC-YOW AC118 E90
2008-11-18 YVR-YYC WS212 736
2008-06-18 ORD-YYC UA5821 (op by OO) CR7
2008-06-18 VCE-FRA LH4091 AB6
2008-06-05 FRA-VCE LH4084 AB6
2008-05-13 YVR-YYC WS570 736
2008-05-13 YYC-YVR WS545 736
2008-04-25 YYC-YVR WS80 73G
2007-11-25 YYZ-YYC AC141 320
2007-11-23 YOW-YYZ AC467 321
2007-11-23 YYC-YOW AC118 E90
2007-10-16 YXE-YYC AC8587 (op by QK) CRJ
2007-10-16 YYC-YXE AC8582 (op by QK) CRJ
2006-06-14 YYC-YVR AC201 E90
2007-04-30 YUL-YYC WS655 73G
2007-02-14 YUL-YYC WS655 73G
2006-12-20 YUL-YYC WS667 73G
2006-10-09 YYC-YUL AC186 E90
2006-10-05 YUL-YYC AC155 320
2006-09-01 YYC-YUL WS80 73G
2006-02-16 YUL-YYC AC155 320
2006-01-02 YYC-YUL WS??? - sorry, I don't have the flight number. Probably only 1 WS non-stop YYC-YUL that day, but if there's more, I'd take them all
2005-12-07 YOW-YYC AC??? - also don't have the flight number, although it should be 113 or 167. I'm looking for the afternoon flight
2005-08-30 YYC-YUL AC144 321
2004-06-07 SFO-YYC UA810 733
2004-05-29 FLR-MXP AZ??? - I'm still trying to figure out exactly which flight I took, would be interested in whatever data was available
2003-08-24 YYC-YUL AC1150 319
2003-07-24 YYZ-YYC AC141 320
2003-07-23 YYC-YYZ AC134 319
Thanks in advance to anyone who's able to provide any of these!
Einheitsdesign
Mon Dec 06, 2021 12:10 pm
AdamCSmith wrote:
Hello all,
Since you seem to have searched many sources yourself, it was really difficult to find at least a few For some days I have found logs, but then unfortunately only the reg was recorded and not the flight number.
But I could solve a few or help you with the flight numbers.
C-GWCY B736 35113 WestJetW S0545 (YYC-YVR) 0650 20090407
C-GXWJ B736 WestJet WS0545 (YYC-YVR) 0716 20090325
C-GWCQ B736 WestJet WS0212(YVR-YYC-YQR) 1709 20081118
C-GXWJ B736 WestJet WS0570 (YVR-YYC) 1611 20080513
C-GXWJ B736 WestJet WS0545 (YYC-YVR) 0643 20080513
C-FFWM (A320 ) 2106 20071123 AC0467 (CYOW-CYYZ)
2006-06-14 YYC-YVR AC201 E90 Since all other days are sorted correctly, is this a typo and you mean 2007-06-14?
0639 20070614 C-FHLH AC0201(YYC-YVR)
On YYC homepage form 16.01.2006 I found this departure for YYC-YUL directly. Checked it also on some other weekdays and it WJA668 was the only direct flight
11:48 Westjet WJA 668 Montreal
AC0167 1730 1955 (acc timetable eff 05.12.2005
AdamCSmith
Mon Dec 06, 2021 6:00 pm
Thanks for your help! Depending on the day/flight, registrations could be useful. For instance, for some of the missing AC flights between YYC and IAH, I've been able to eliminate most of the options (they only had 16 CR9s at the time), but not all... If there were more hits on some of the other tails elsewhere, I might be able to track them down. (I'm happy to do the research if you can point me to where I can find the files - don't expect you to do all the work ;))
Thanks for these!
Correct! Thanks for noticing :)
Thanks! Where did you get hold of the AC timetable for that time period? I've looked around and haven't found it. For some reason, I thought the flight had departed earlier in the day than that. And did the timetable by any chance show the aircraft type?
Einheitsdesign
Mon Dec 06, 2021 8:14 pm
I have some backup from former yahoo.groups. I'll try to upload them (1,2 GB) tomorrow to an ondrive folder so that you can do all your research. I'll provide the link then by direct message.
I got them via Wayback on Air Canada website. One of the few airlines that have a lot accessible via wayback. If you have any problems I can also upload the ones I have (not that much because I only download them in case of need)
AdamCSmith
Mon Dec 06, 2021 8:54 pm
Cool, thanks!
Yeah, after posting that, I realized I should have checked there, and went and found it.
Do you happen to have any old Alitalia timetables? I'm trying to figure out that FLR-MXP flight, and the Wayback Machine doesn't seem to function with their timetable.
orycdglbg
Tue Dec 07, 2021 7:42 am
Hello,I’m looking to find tail number of the following flights
BOD-ORY AF6267 28JUL2005 A/C TYPE A320
ORY-SXB AF7302 03NOV2007 A/C TYPE A319
SXB-ORY AF7303 04NOV2007 A/C TYPE F100 (CCM)
AdamCSmith
Tue Dec 07, 2021 8:58 pm
Einheitsdesign, thanks for the PM. Apparently because my account is too new, I can't yet PM you a reply.
I've been going through the files you made available. Can I get your thoughts on data quality issues? For example, by 2005-12-07 flight, AC167 YOW-YYC, in one of the files from WorldACARSLogs, 23932, a Toronto-area ACARS receiver picked up C-GAPY supposedly operating AC167 YHZ-YYZ. Clearly something is off in that data point - either it was doing YHZ-YYZ and not operating AC167, or it was doing AC167 YOW-YYC and not flying YHZ-YYZ. Or, I suppose it's possible it was doing neither YHZ-YYZ nor AC167 and both of those are wrong.
I've noticed other issues like that with files I've gotten on acarsd.org, where it seems the route was perhaps drawn from an out-of-date database of the airline's flights but everything else made sense, including the time/location it was picked up, so I'm inclined to think it's more likely the route is just wrong. But in this case, I'm also wondering how likely it is for an ACARS receiver in the Toronto area to pick up a flight from YOW to YYC? That route would normally be fairly far north of Toronto, although I don't know exactly what track it flew that day, or how far the ACARS signals can be picked up. (All of the above applies to the 2006-09-01 YYC-YUL WS80 that I was looking for - also picked up by a Toronto receiver with the right flight number and wrong route).
Einheitsdesign
Wed Dec 08, 2021 9:06 am
I see your point and in my opinion the data concerning flight number and tail number are reliable.
Regarding the routes, I have also often found that they do not fit, so for me they are always indicative and never proof.
I explain the deviation in the routes as follows: As I understand it, the program that creates the logs is fed from several sources: Acars reports of the aircraft, route files, aircraft types and possibly some more. Then, if the route files are not updated, the log will output the wrong route. I have often noticed this with Acars.org and LHR logs (Acars Reports from UK).
I have only very rarely experienced incorrectly displayed flight numbers and that really only when the aircraft does not send the flight number but the callsign (e.g. DLH03F instead of LH0145) and the flight number/callsign file is not up to date.
Concerning the ranges of the receivers: I have looked at http://www3.sympatico.ca/scos/dailylogs.htm, the former homepage of the log manufacturers, and there it is said that the logs are a combination of several receivers. This would then also explain why the range of the logs is greater than only YYZ and surroundings.
But to be honest, as long as you have not written down the reg yourself when boarding, all logs and other information are never 100% sure. I remember a case where the airport had a mixed letter in the tail number in the reply to a query. :)
Einheitsdesign
Thu Dec 09, 2021 6:48 pm
Got this from the FLR page 06.06.2004. Maybe your flight is in this list.
Flight To Departure
AZ 01687 MILANO Mxp 06:35
AZ 01699 MILANO Mxp 07:40
AZ 01693 MILANO Mxp 11:20
AZ 01691 MILANO Mxp 14:50
AZ 01695 MILANO Mxp 18:15
AdamCSmith
Sat Dec 11, 2021 5:42 am
Einheitsdesign, thanks so much for your help. I've spent a bunch of time digging through those files, and have found a few more. I also found the BOS logs to be helpful in eliminating the last few candidates for one of the flights.
Some of it has been frustrating though! For instance, the YGK ACARS logs can be very helpful in finding flights to/from YUL, but often the logs are missing from days on which I flew, even though they may be available the day before and after...
It's a shame that Antonakis no longer seems to be around, as I suspect he would have a lot of that information, and it would be a lot quicker to search than going through all those group logs manually. Even though his website is still up and running, I've sent him several e-mails over the years and he has never answered.
Thanks for the information. That's what I figured, but useful to have some corroboration.
Definitely! I've been amazed at how much info is out there though. Some of it has required some real detective work, but I've found hundreds of flights over the last couple of years. Now I've even managed to find some information where I don't have the flight details! For instance, in July 1999, I did YYC-LHR-NCE; CDG-LHR-NCE. If only I knew the dates, the LHR/LGW site already has the registrations! So I have my mother looking through her old calendars to see if she can figure out the dates :)
Dolf1
Sat Dec 18, 2021 8:21 pm
Thank you so much!
Dolf
PA0101 1140 1340
PA0001 1300 1540
PA0011 1800 2040
Lowcountryflyer
Sun Dec 19, 2021 2:56 am
Got a question for the group in this thread (who have been incredibly helpful) - how do people look up old flight times and aircraft types for different market pairs? I know there is departed flights, but I can’t figure out how to get specific times or aircraft for flights.
Also, I see people reference flightmemory to check on flights - how does that work?
I have pieces together 90% of my registrations which is awesome, and I think I could solve another bunch with some help.
A few examples:
What are the departure and arrival times for Delta 100/101 ATL-EZE-ATL in both December 2001 and June 2002? I have a bead on a few tails but want to check against schedules to see if it works timing wise.
How can I look up even older schedules like delta from atl-lgw in 1986 and 1987
Einheitsdesign
Sun Dec 19, 2021 8:27 am
A few examples:
For flightmemory you have to open a membership. When you open it then you will find a menu "ribbon". There click on "flight date", then a new row will open and there click on "search in all flights". Then you can search by Registration, Flightnumber and flightroute. Only Flightnumber will give all results, for both other chioces the results are limited to 100.
Here you should find the requested timetables
https://deltamuseum.access.preservica.c ... 2dd1883be/
Lowcountryflyer
Sun Dec 19, 2021 8:13 pm
As always, THANK YOU! Are there similar websites for AA, UA, and BA?
A few examples:
silentghostx
Sun Dec 19, 2021 10:48 pm
Oh wow! I didn’t see this thread before I posted a topic earlier
But if anyone could help with
CX107 HKG - AKL 04JUL1997 A340-300
Thank you!
Einheitsdesign
Mon Dec 20, 2021 5:03 pm
Unfortunately I don't know any resource that provide these data. I have some UA timetables from 2003 on my disk but that's all.
Lanorge
Mon Dec 27, 2021 10:07 am
Great work, Einheitsdesign! I've followed this post with interest. I startet searching for old regs in 2011 and have found surprisingly many during these last ten years. However, some of the sources I used before are sadly no longer available. The following should be impossibles but I try anyway, looking for regs:
23.12.2010 IT4302 UDR DEL
11.4.2005 OZ132 ICN FUK
6.4.2005 OZ131 FUK ICN
14.2.2005 MU531 PVG FUK
14.2.2005 MU5558 FOC SHA
8.2.2005 MU5561 SHA FOC
8.2.2005 MU518 FUK PVG
2.8.1999 SK1325 OSL SVG
29.7.1999 SK1320 SVG OSL
8.7.1996 BU35 FBU SVG
4.7.1996 BU22 SVG FBU
19.2.1995 BU135 FBU SVG
17.2.1995 BU42 SVG FBU
9.5.1991 BU2056 SVG FBU
I am also trying to help others tie up their flights, perhaps easier to find, perhaps not:
4.7.2013 QF2317 CNS TSV
10.12.2009+1 JQ58 SIN DRW CNS
6.12.2009 JQ57 CNS DRW SIN
10.7.2009 DJ1519 SYD TSV
17.10.2006 OS335 VIE OSL
7.10.2006 OS336 OSL VIE
28.6.2004 SK794 NCE CPH
21.6.2004 SK793 CPH NCE
21.6.2004 SK457 OSL CPH
17.4.2004 LH691 TLV FRA
17.4.2004 SK1860 CPH SVG
18.4.2003 SK908 EWR OSL
9.4.2003 SK907 OSL EWR
4.4.2002+1 NW54 DTW AMS
4.4.2002 NW429 MCO DTW
19.3.2002 NW47 DTW MCO
19.3.2002 NW47 AMS DTW
25.9.1991+1 SK938 SEA CPH
11.9.1991 SK937 CPH SEA
11.9.1991 SK1865 SVG CPH
  • 1
  • 4
  • 5
  • 6
  • 7
  • 8
  • 24
Users browsing this forum: WesternDC6B and 40 guests
