dc10lover
Funny: My version of the 737 MAX and I do mean MAX
Tue May 28, 2019 7:48 pm
A 737 using the GE90 - 115b jet engine. You like being pulled back in your seat? You ain't seen nothing yet. :-)
Why endure the nightmare and congestion of LAX when BUR, LGB, ONT & SNA is so much easier to fly in and out of. Same with OAK & SJC when it comes to SFO.
atomicstar
Re: Funny: My version of the 737 MAX and I do mean MAX
Wed May 29, 2019 4:19 am
If it were to be a freighter for transporting high density items such as car frames, metal beams, ore, etc. But you will need very high wings as the engine diameter is close to the diameter of the fuselage.
But this freight stuff usually rather belongs on trucks and ships. Also, I’m actually not sure, are there 737 MAX freighters?
And then I was thinking, what about a 737 unijet (one engine airplane)? I would be worried if the engine fails.
Aurantiaco
Thu May 30, 2019 7:51 pm
It would also be controlled by an XBOX controller. Will you crash? Who knows. Just hope the high speed wouldn’t dissipate the entire aircraft.
triple3driver
Sat Jun 01, 2019 12:59 am
Previous generation of engines. If you want to be competitive, go with the GEnx or GE9x.
If you can walk away from it intact, it was a good landing!
sketch
Wed Jul 24, 2019 8:30 pm
I have a better idea.
AirKevin
Wed Jul 24, 2019 8:57 pm
Talk about serious FOD. Better hope the wings don't get sucked off the fuselage.
Captain Kevin
Armadillo1
Mon Aug 12, 2019 9:35 am
on other hand lift from root section tripled.
and i still thinking future planes will be with one big cruise engine and one for take-off and backup.
mfranjic
Tue Aug 13, 2019 7:33 pm
From the very beginning my idea of powering the 4th generation of the Image.737 aircraft was including GTF engine ( 737 FOUR ); four (4) Image.PW1600G, ‘2,5’-shaft, high-bypass, geared, turbofan engine (fan diameter: 56,0 in / 1.422,4 mm; BPR: 9,0:1, gear ratio: 2,409:1; eng. architecture: 1F-]G[-2LPC–8HPC〧2HPT–3LPT), OPR: 50,0:1, rated between 59,14 kN / 6.031 kgf / 13.295 lbf and 77,14 kN / 7.866 kgf / 17.342 lbf.
The Image.PW1600G, ‘2,5’-shaft, high-bypass, geared turbofan engine is a custom designed and specially tailored version of the small-core Pratt & Whitney.PW1000G GTF engine (previously known as the PurePower Geared Turbofan™), already applied on the Image.SpaceJet ( MRJ ) powered by P&W.PW1200G GTF engine and also predicted for the Image.E175-E2 ( ERJ190-500 ) aircraft, foreseen to be powered by P&W.PW1700G GTFs.
Those four engines would not bring a significant weight penalty to the aircraft, and in the same time these are more propulsive efficient engines in the comparison with the Image.LEAP-1B, twin-shaft, high-bypass turbofans (fan diameter: 69,4 in / 1.762,8 mm; BPR: 9,0:1; eng. architecture: 1F+3LPC–10HPC〧2HPT–5LPT), OPR: 43,68:1, rated between 119,15 kN / 12.150 kgf / 26.786 lbf and 130,41 kN / 13.298 kgf / 29.317 lbf. Besides, due to the noticeably smaller (23,9 %) fan diameter (69,4 in / 1.762,8 mm vs 56,0 in / 1.422,4 mm) those engines could be far easier placed on a much more appropriate place under the Boeing 737’s wings. The wings should probably need some modifications to deal with somewhat higher, but differently distributed weight of the two smaller and lighter GTFs...
...Image
Image above: flydubai’s Image.737 MAX 8 aircraft; MSN 60966 / LN 6326, reg. A6-MAX, originally powered by two Image.LEAP-1B28, twin-shaft, high-bypass turbofans (fan diameter: 69,4 in / 1.762,8 mm; BPR: 9,0:1; eng. architecture: 1F+3LPC–10HPC2HPT–5LPT), OPR: 43,68:1, rated at 130,41 kN / 13.298 kgf / 29.317 lbf, here, just for this occasion as the Image.737 FOUR 8, powered by four Image.PW1615G, ‘2,5’-shaft, high-bypass, geared, turbofan engine (fan diameter: 56,0 in / 1.422,4 mm; BPR: 9,0:1, gear ratio: 2,409:1; eng. architecture: 1F-]G[-2LPC–8HPC2HPT–3LPT), OPR: 50,0:1, each rated at 66,04 kN / 6.734 kgf / 14.847 lbf ...
...Except the installation of the GTF engine on the Boeing 737 aircraft would mean, by my opinion, a large technological stride, in the same time it would represent a historical reunion of the Boeing 737 aircraft and Pratt & Whitney’s engines, since the first generation of this aircraft - Image.737 Original ( Boeing 737-100/200 ) was powered by Image.JT8D series of the low-bypass turbofan engines. It would be so special to see how it all started so it can come to the end … ‘ The Unfinished Story about Boeing 737 and Pratt & Whitney ’…
...Image
Boeing 737 - the engines through its four generations
In a somewhat, but not essentialy, modified form this was part of the initial post of the thread I opened the other day thinking it might be interesting to see which specific solution would the forum’s members offer in this particular situation with the Image. 737 MAX aircraft and where do they see the way out from the current situation with the grounded aircraft …
viewtopic.php?f=3&t=1428321#p21553623
Mario
P.S. chiad, thank You very much for Your support! I was trying to send You reply, but that PM, and after ten days had passed, is still staying in the Outbox ...
"Only a life lived for others is a life worthwhile" - Albert Einstein
triple3driver
Tue Aug 13, 2019 8:30 pm
...Image
...Image
Mario
I don't know, seems like it would be the next A340-300, aka a plane with 4 hairdryers :duck:
PacoMartin
Sun Nov 24, 2019 8:04 am
The original B737 engine used in the 1960's and 1970's was just the B727 engine.
The last B737 with a Pratt and Whitney engine was a B737-200 delivered on 8. Aug. 1988, only a few months after the first A320 was delivered to Air France on 28 March 1988. You have a long sense of nostalgia.
Users browsing this forum: No registered users and 28 guests
