blacksoviet
What happened to Continental's 737-900s?
Thu May 30, 2019 6:23 am
At the time of the merger, Continental had a fleet of 12 737-924s. These are no longer listed as part of the United fleet. Who operates them now?
Re: What happened to Continental's 737-900s?
Thu May 30, 2019 6:26 am
What's your source?
Airfleets.com still shows them as part of the fleet. https://www.airfleets.net/flottecie/Uni ... 7ng-70.htm
I also checked one of the tails at random on FlightRadar24 and it flew today. https://www.flightradar24.com/data/aircraft/n37409
blacksoviet
Thu May 30, 2019 6:37 am
Starlionblue wrote:
What's your source?
Wikipedia only lists the 737-900ER (148).
FlyHossD
Thu May 30, 2019 7:12 am
They're part of the United fleet now - saw one about 2 weeks ago. The UA 739s are numbered 401-412, then 739ERs 413-479(?) and 801-849 and 880-899.
Thu May 30, 2019 7:54 am
blacksoviet wrote:
Starlionblue wrote:
What's your source?
Wikipedia is not a reliable source.
flyboy80
Thu May 30, 2019 12:10 pm
It appears both AS and CO ordered a small amount of 900's before the ER. What are the primary structural differences between the two airplanes? I know the ER is probably heavier with a higher MTW. I did once have a flight in 2012, BOS-PDX, swapped from a 800 to a 900. It had about 20 open seats. I remember being surprised because I thought that leg west bound would be difficult for a standard 900- Which indeed it was, including no winglets.
IAHFLYR
Thu May 30, 2019 1:12 pm
Exactly. They never went anywhere other than to be painted with the new name on the fuselage. They are doing just fine in fact flew SJC-IAH on N75410 (UA1851) a couple of weeks back. They are doing great and still have DTV.
FlyHossD
Thu May 30, 2019 3:36 pm
IIRC, all of the structural weights one the 739ERs are significantly higher than the 739s. For example (again, IIRC), the maximum zero fuel weight for the -9ERs was 10,000 pounds higher than for the -9s; 157,300 lbs vs. 147,300 pounds.
It's just my opinion, but the -9s were fine for flights of not more than 3 hours, so they were useful to CO for flights from EWR to Florida, or IAH to LAS for example. Beyond that time, the trade-offs started, so the -9ERs' higher weights were a really useful improvement especially when an alternate airport was required.
CALTECH
Thu May 30, 2019 9:41 pm
They are all still in United's Fleet, flying along. Big difference is the exit door on the -900ER behind the wing, not there on the -900.
479 is he newest -900ER.
The -800 and -900 have the same MTOW, with the -900 carrying 13 more passengers.
You are here.
blacksoviet
Thu May 30, 2019 9:48 pm
If they have the same MTOW does that mean that the -900 has to leave some bags behind?
Thu May 30, 2019 11:40 pm
There's no reason for that. Just don't use them on the missions where they would be takeoff limited.
Erau82
Mon Jun 03, 2019 4:26 pm
The max taxi gross weight increases on the -900ER to 188,200 lbs from 174,700 for the -900. The MLG is unique to the -900ER due to the increase in taxi and takeoff weights.
strfyr51
Mon Jun 03, 2019 5:52 pm
Maybe? You'd better look again. Those airplanes are still flying. And? For United.
CALTECH
Mon Jun 17, 2019 4:32 pm
United 737-900 MTOW 174,200 Lbs
United 737-900ER MTOW 187,700 Lbs
United 737-9MAX MTOW 194.700 Lbs
You are here.
Users browsing this forum: No registered users and 25 guests
