MalevTU134
Longest flight where same aircraft turns around in the same calendar day?
Tue Jun 11, 2019 3:58 pm
In another thread, user Melb94 commendably found the following schedule
during 2010-2011 for MH's operations into Argentina:
Kuala Lumpur – Cape Town – Buenos Aires 2 weekly 747-400 service
MH201 KUL0130 – 0715CPT0855 – 1330EZE 744 37
MH202 EZE2220 – 1100+1CPT1230+1 – 0540+2KUL 744 37
As can be seen, the flight leaves on Wednesdays and Sundays from KUL, and not only reaches EZE the same calendar day, but also the returning flight leaves the same calendar day, using the same aircraft. This flight doesn't operate anymore, of course, but I am curious: Is there or was there a longer flight than this, where the outbound and the inbound (from its final destination) flights left on the same calendar day, USING THE SAME AIRCRAFT? This flight was a total of 8601 nm, so longer than PER-LON or any transpacific flight. Logic has it that it must be a flight leaving just after midnight from the Far East or Australia/NZ.
keesje
Re: Longest flight where same aircraft turns around in the same calendar day?
Tue Jun 11, 2019 4:25 pm
I remember KL747s doing AMS-IAH-AMS in a day, the same aircraft 7 days a week.
Just enough time inbetween flights to off-load, check-fix, drain, clean, refuel, cater, load cargo, pax, crew.
Pretty efficient operation :)
Melb94
Tue Jun 11, 2019 4:38 pm
Currently Air China's flights to the South/Central America fits this bill
CA-907 PEK 12.55am 6.55am MAD 8.45am 1.45pm GRU
CA-908 GRU 6.05pm 8.40am+1 MAD 12.00pm 4.45am+2 PEK
CA-879 PEK 12.40pm 1.20pm YUL 3.20pm 7.35pm HAV
CA-880 HAV 9.50am 1.20pm YUL 3.20pm 5.00pm+1 PEK
CA-885 PEK 9.20am 10.00am IAH 12.30pm 4.30pm PTY
CA-886 PTY 6.30pm 10.15pm IAH 1.00am 4.50am+1 PEK
Before Singapore Airlines adjusted their SIN-BCN-GRU schedule service which began in March 2011
(which ended in October 2016), it flew this schedule:
SQ-068 SIN 12.40am 8.20am BCN 9.30am 3.55pm GRU
SQ-069 GRU 1.45am 5.35pm BCN 6.45pm 1.35pm SIN+1 (starting March 2011)
However by October 2012, Singapore Airlines changed the schedule until the route was axed in October 2016. Therefore this route does not apply to MalevTU134's question.
SQ-068 SIN 11.45pm 6.45am+1 BCN 8.05am+1 4.15pm GRU
SQ-069 GRU 5.45pm 7.10am+1 BCN 9.15am+1 5.00am+2 SIN
Melb94
Tue Jun 11, 2019 5:25 pm
[quote="Melb94"]Currently Air China's flights to the South/Central America fits this bill
ET-512 ADD 9.00am 12.15pm ABJ 1.00pm 7.15pm EWR
ET-513 EWR 9.15pm 11.00am+1 ABJ 12.00pm 9.15pm ADD
ET-508 ADD 8.30am 11.00am LFW 12.15pm 7.15pm EWR
ET-509 EWR 9.15pm 11.35am+1 LFW 12.35pm 9.10pm ADD
ET-506 ADD 10.05am 4.15pm GRU 5.35pm 8.30pm EZE
ET-507 EZE 9.30pm 12.30am+1 GRU 1.25am 7.25pm ADD (both QR & TK fly DOH-GRU-EZE & IST-GRU-EZE respectively this similar schedules in both directions)
EK-245 DXB 8.05am 3.25pm GIG 5.10pm 8.45pm SCL
EK-246 SCL 1.15am 6.15am GIG 8.10am 5.10am+1 DXB
EK-247 DXB 8.05am 3.25pm GIG 5.10pm 8.40pm EZE
EK-248 EZE 10.20pm 1.10am+1 GIG 2.55am 11.55pm DXB
aeromoe
Tue Jun 11, 2019 8:05 pm
That second example of the CA flights (Havana) wouldn't fit the bill if the times are correct. 735p arrival in Havana; 905AM departure from Havana. Neither would the first EK example...arrive SCL 845pm...depart SCL 115AM.
AA AC AS BA BD BF BN BR BY B6 CO CP(2) DG DL EA EI EN FL FT F9 HA HP ICX JI JQ J7 KE KS LH MC NW OC OO OZ(1) OZ(2) PA PI PT QF QQ RM RO RV(1) RV(2) RW SK SM SQ S4 TI TS TW UA UK US UZ VS VX WA WN WS W7 XV YV YX(2) ZZ 9K
vhqpa
Wed Jun 12, 2019 3:35 am
For using the same aircraft criteria.
QF15 BNE LAX 1020 0600 789 Daily
QF11 LAX JFK 0820 1640 789 Daily
QF12 JFK LAX 1810 2100 789 Daily
QF16 LAX BNE 2320 0605+2 789 Daily
There is a flight number change for the LAX-JFK-LAX tag on but it is operated by the same aircraft. The total distance BNE-LAX-JFK is 8,374 nm, and BNE-LAX-JFK-LAX is 10,524nm.
If you were to change the criteria to using the same pair of flight numbers then you could say QF11/12 SYD-LAX-JFK-LAX. Which is slightly longer but there is an aircraft change in LAX.
"There you go ladies and gentleman we're through Mach 1 the speed of sound no bumps no bangs... CONCORDE"
zkncj
Wed Jun 12, 2019 4:35 am
NZ26 AKL-ORD is 15hrs same day departs AKL at 2210, and arrives at 1705 at the same day.
Ironically on the ORD-AKL sector which is 16h30m you arrive back in AKL two days after you left e.g leave Friday night and arrive Sunday morning
Users browsing this forum: No registered users and 21 guests
