blacksoviet
Should Boeing have increased the range of the 717 instead of developing the MAX?
Sun Dec 08, 2019 1:33 am
With the newest engines, could the 717 be stretched to approach the seating capacity of the MAX-8?
The resulting aircraft could be called the 717 Next Generation. Obviously, the range would have to be increased. Which airlines begged Boeing to increase the range of the 717?
Ironically, Boeing refused to increase the range of the 717 because they didn’t want to kill the 737-600. The 737-600 was dead anyway. They kept the 737-600 going for a few more years at the expense of killing the 717. Does Boeing regret this?
Should Boeing have abandoned the 737 and focused on the 717 and MD-90 platforms?
I am sure the range of the MD-90 could have been increased with an NG model. A stretched 717 variant could have been launched to replace the 73G and an NG model of the MD-90 could have replaced the 738.
The 739, 757, 762, and 763 could all have been replaced by the NMA.
I have not received confirmation that the 717 tooling has been destroyed.
afterburner
Re: Should Boeing have increased the range of the 717 instead of developing the MAX?
Sun Dec 08, 2019 2:08 am
No. Resurrecting dead designs is not what Boeing should do.
speedbird52
Sun Dec 08, 2019 6:32 am
No.
vhqpa
Sun Dec 08, 2019 6:34 am
Lol instead of using the 737 let's use the other 1960s designed platform we have at our disposal. The one with an even narrower cross section!
At that point may as well dust of the blueprints for the 727, might be a bit tricky reengining that one though especially #2. Although someone in the 90s (Dee Howard?) managed to shoehorn a RR Tay into #2.
"There you go ladies and gentleman we're through Mach 1 the speed of sound no bumps no bangs... CONCORDE"
KFTG
Sun Dec 08, 2019 7:44 am
Just chiming in. No.
blacksoviet
Sun Dec 08, 2019 10:36 am
What is the advantage of shoehorning a Tay in the #2 nacelle? Increased range?
KFTG
Sun Dec 08, 2019 11:09 am
Next blacksoviet thread: "Why didn't Boeing NEO the 727?"
vhqpa
Sun Dec 08, 2019 12:13 pm
Well the obvious advantages were it was a lot more efficient and quieter than the original JT8D engines. I don't know about range, but having more efficient engines it stands to reason it would fly further on any given fuel load.
GalaxyFlyer
Sun Dec 08, 2019 12:32 pm
UPS did the Tay conversion on the 727; wasn’t terribly successful.
The 717 was already re-engined with a modern RR engine.
VSMUT
Sun Dec 08, 2019 12:33 pm
Just omit the center engine, make it a 2-engined MD-80 style design. They would actually have been able to put a pair of modern turbofans onto a 727 without all the issues the 737 ran into when trying to cram the LEAP onto the MAX. Should achieve a pretty decent range too.
Stretching it, getting the balance correct and tail strike issues would be a bother though.
Obviously never going to happen, but I love the idea.
asr0dzjq
Sun Dec 08, 2019 12:51 pm
Absolutely not. The 717 is a dead design and on its way out everywhere. I'm willing to bet that all 717's will be scrapped (possibly with some going to museums) by 2030 (or 2040 if we're lucky). Might as well try to make a 727 Max 8 and 727 Max 9 with 3 CF34-8C's.
R.I.P.
Pan Am (B 19-10-1927, D 4-12-1991)
TWA (B 1-10-1930, D 1-12-2001)
Douglas (B 22-7-1921, D 23-5-2006)
WesternDC6B
Sun Dec 08, 2019 2:07 pm
Or, WesternDC6B - me - will ask about building a DC6 or DC7 with turboprop engines. If they can do it on a Convair, why not a Douglas?
/please, folks. I know the Convair was engineered with the eventual turboprop conversion in mind where the DCs weren’t.
A big heart is commendable. An enlarged heart is a medical condition.
PSU.DTW.SCE
Sun Dec 08, 2019 2:24 pm
In hindsight, you could make the following argument about 20 years ago but the 717 would never have solved in segment of the market, primarily in the 738/739 150-190 seat capacity and range that led to the decision to for the MAX. The 717, even when stretched at best could be a 150 seat aircraft in most configurations and limited to domestic. Then the A220 would come along now anyways.
- Retain the 717, add the 717-300 variant; add a bit of range and capacity and use that to capture the lower-end of the market up to about 150 seats
- Keep the 737NG cash cow going on 73G/738/739
- Pursue a NSA to cover the 150-200 seat range
ExpatVet
Sun Dec 08, 2019 7:19 pm
I would think the big issue was commonality. A design that has nothing in common with Boeing family would be inherently more expensive to build and support.
L101, 733/4/5/8, 741/2/3 (never managed 744!), MD 80/2/3/8/90, MD11, DHC8/3/Q4, E170, E195, 757, 77W, 763/4, Travel Air 2000. A300/310, A319/320/321, A333, ATR-72, probably a few others I forget. Passenger, not pilot, alas! BUD based.
CowAnon
Mon Dec 09, 2019 12:20 am
There were at least 3 proposals from the 1980s:
Total abandonment seems out of the question because of Southwest Airlines's 737 love, but maybe Boeing could've improved both product families. If you compare the specs of McDonnell Douglas's MD-92 propfan-powered derivative against the current A320neo, the MD-92 still comes out favorably. Rolls-Royce seemed eager to sell an open rotor engine for the 737NG/320ceo successors, so this would've been a way for Boeing to offer product variety in the narrowbody sector instead of just 737s with the lone option of GE engines. (Or maybe Boeing could've put LEAP or GTF engines on the DC9/MD80/717 frame, though I don't think that would've been very attractive.)
On the negative side, the MD-92 range would've been less than for the 737-8 and the A320NEO, but I think the extra range was unneeded or could be successfully increased with higher MTOW. The A220 specs do look slightly better than the MD-91 propfan version, though. That's where the 717/MD-90's smaller wingspan is problematic. A rewing to increase the span by 3 meters would be required unless the newer generation of propfans closed the gap.
GalaxyFlyer
Mon Dec 09, 2019 1:22 am
Why do posters think the CF-34 powered B727 would work—entirely wrong design. Thrust numbers alone don’t describe an engine’s characteristics.
GF
afterburner
Mon Dec 09, 2019 4:10 am
I wonder whether people who are suggesting resurrection of Boeing old aircraft are inspired by the Hollywood? Hollywood is rebooting old movies and tv series likes Ghostbusters, Superman, Hawaii 5-0, Magnum PI, etc.
blacksoviet
Mon Dec 09, 2019 7:08 am
Clearly launching the 737 MAX was a mistake. The wings are too low to the ground for modern turbofan engines. Boeing knew this but they were desperate to appease Southwest. They took a gamble and ended up paying the price.
The 717 and MD-90 designs do not have ground clearance issues. Launching a DC-9 MAX would have been easier than the 737 MAX and it would have bought Boeing more time to develop a clean-sheet 738 replacement.
Boeing should have told Southwest that the 737 is an obsolete platform. It was designed for turbojets. The 737-100 was an excellent design and was loved by Avianca for many years.
rlwynn
Mon Dec 09, 2019 8:49 pm
No it was not. Why do you say that?
I can drive faster than you
aklrno
Tue Dec 10, 2019 12:10 am
Has anyone considered re-engining the Wright flyer with perhaps a 10 foot fuselage stretch and a canopy over the added seats? Threads like this tend to get kind of absurd.
GalaxyFlyer
Tue Dec 10, 2019 12:12 am
You’re gonna have to offer some solid engineering to back up those ideas. Pylon-mounted engine’s in tail most certainly have clearance problem—the fuselage AND a balance problem.
GF
IADCA
Tue Dec 10, 2019 1:06 am
Not enough structure to take the stretch. Now a 189-seat DC-3 with LEAP engines...
TheWorm123
Wed Dec 11, 2019 1:16 pm
Ultimately the same could he argued with the A220 having 0 parts or cockpit commonality with the A320, A330 or A350. However it’s been a lot more successful than I initially thought despite that shortcoming.
752 753 A332
BartSimpson
Wed Dec 11, 2019 1:49 pm
That's not going to work. The tooling is gone...
asr0dzjq
Thu Dec 12, 2019 8:26 pm
GF
As the MD-90 has shown
R.I.P.
Users browsing this forum: longhauler, RushmoreAir, wv399 and 147 guests
