davidbrok5
Were the 737 Max crashes a first of its kind?
Sat Feb 08, 2020 12:16 pm
Hi there,
Currently doing some research into Boeing centralised around the 737 Max crashes. I really wanted to know if any of you knew of any other commercial aviation crashes like this in commerical aviation history?
i.e. 2+ separate incidents on the same plane as a result of the manufacturer and the same fault?
ChrisKen
Re: Were the 737 Max crashes a first of its kind?
Sat Feb 08, 2020 1:04 pm
The list is fairly long, but the game changers in terms of accident investigation were the De Havilland Comet crashes ~1954.
CosmicCruiser
Sat Feb 08, 2020 1:34 pm
Early 737s had a rudder PCU problem that resulted in several crashes.
BravoOne
Sat Feb 08, 2020 3:25 pm
Check out the Lockheed Electra in the late 50's
WIederling
Sat Feb 08, 2020 4:38 pm
Murphy is an optimist
collectairs
Sat Feb 08, 2020 4:55 pm
The Lockheed Electra, the four engine turboprop version of the first produced in the late 1950s, had a rough start. As I recall, unbalanced propellers caused whirl mode flutter inflight which in some cases caused the engines to rip away from their mount.
BravoOne
Sat Feb 08, 2020 5:20 pm
You could go back as far as the original Constellations and DC6's as I believe they both incurred groundings. The Connie was an electrical problem, and I believe the DC6 had a engine fire extinguishing issue along with a cabin heater problems resulting in catastrophic accidents. Airliners have come a long ways, but it was not a smooth ride in the beginning.
Sat Feb 08, 2020 7:01 pm
The T-tail design was very problematic, e.g. for the BAC1-11:
https://en.wikipedia.org/wiki/1963_BAC_ ... test_crash
dfwjim1
Sun Feb 09, 2020 8:51 pm
Any crash is a bad thing but fortunately safety advances come out of every accident.
Chemist
Mon Feb 10, 2020 12:03 am
Many early 727s crashed on approach/landing, but as I remember the problem wasn't the plane, but differences in handling characteristics versus other airliners.
