UA857
Why did UA retire the L-1011?
Mon Mar 16, 2020 3:50 am
When did UA retire the L-1011 just 3 years after acquiring it from PA?
janders
Re: Why did UA retire the L-1011?
Mon Mar 16, 2020 4:21 am
6 orphan L-1011s in the midst of 60+ DC-10s hardly made sense to keep.
"We make war that we may live in peace." -- Aristotle
FLALEFTY
Mon Mar 16, 2020 4:34 am
After United took them over from Pan Am, the sub-fleet of just 6 L-1011-500's were eventually replaced with DC-10-30's, which maintained substantial commonality with the rest of United's legacy fleet of DC-10-10's. This move rationalized maintenance and training costs, as well as simplified the crew seniority ladder. However, these L-1011-500's did live on with Delta, who obtained UA's sub-fleet to go with their L-1011-1 & 200 fleet.
AA747123
Mon Mar 16, 2020 4:36 am
Did United put their own interiors in the L10's? Or a hybrid PA/UA or did they keep PA colors? Never found a picture of UA L10 interiors
United1
Mon Mar 16, 2020 5:26 am
UA kept the same seating configuration as PA used on the L1011s. I’m not 100% sure if they swapped out the seat covers for UAs style or not.
I know the voices in my head aren't real but sometimes their ideas are just awesome!!!
blacksoviet
Mon Mar 16, 2020 6:26 am
I’m pretty sure the DC-10-30 has more range than the L1011-500.
blacksoviet
Mon Mar 16, 2020 6:28 am
Were these three-class aircraft?
hoons90
Mon Mar 16, 2020 7:14 am
Some interior shots of the UA L-1011 can be found in this video:
https://www.youtube.com/watch?v=Jgk7fCP5om0
Flown: 2L 7C 9E 9L AA AB AC AF AY AZ BA BR BX B6 CA CO CP CX DL EK EY JL KE KL LA LH LX MQ NW OZ PD RW SQ TG TP TR TS US WG WN WS XE XJ
deltacto
Mon Mar 16, 2020 7:30 am
yes .... seat map from 1987
http://departedflights.com/UAL1587.html
this is the exact same configuration that Pan Am had
http://www.departedflights.com/PAL151085.html
these aircraft had mid-cabin lavs .... and 3x4x3 seating in coach
Sevoair
Mon Mar 16, 2020 8:08 am
A comment on the video says this was Pac Day—the day that United took over from Pan Am. I read in an old article that United took over planes (obviously here the L1011s) and employees from Pan Am as part of the sale. So, were employees for Pan Am specifically in a Pacific, Atlantic or domestic division? Or how they chose which employees went to United. I assume in the video these had been Pan Am employees who were now United employees.
Does anyone recall how that integration went compared to some more modern ones? I vaguely remember, as a child, seeing the Pan Am 747s at SFOs central terminal and then a couple years later (i didn’t fly much until later) seeing mostly United 747s there. I always wanted to fly international as kid! Took me until my 20s!
UA857
Mon Mar 16, 2020 9:06 am
When was UA´s last L-1011 flight?
cedarjet
Mon Mar 16, 2020 9:21 am
Three years after Pac Day
LAX772LR
Mon Mar 16, 2020 9:45 am
Which is sorta ironic, as DL had temporarily leased some of the DC10s intended for UA, while waiting for its L1011s.
Cody
Mon Mar 16, 2020 11:24 am
Not sure if the L1011s received United interiors, but I know the 747sp's ( they arrived at the same time ) did rather quickly.
They got the same grey economy seats, with orange and magenta checkerboard squares, that the DC-8s and most of the DC-10s had.
Cointrin330
Mon Mar 16, 2020 11:48 am
Did the PA L1011's in UA colors see TPAC service in 1986 and 1987 before they left the fleet?
Cody
Mon Mar 16, 2020 12:11 pm
Yes, from SFO to Osaka.
superjeff
Mon Mar 16, 2020 12:40 pm
This video was obviously filmed shortly after the takeover of PA's Pacific routes by UA and the interior is definitely Pan Am. Note that Pan Am's configuration of the L10 was denser than the norm back then. The original L10's on most carriers in Economy was 2-4-2; later they went to 2-5-2 on most airlines. I believe that a few airlines (CX, NH, and PA come to mind) operated a ten abreast confirguration in Economy, which must have been painful.
SpaceshipDC10
Mon Mar 16, 2020 1:31 pm
Well in a way that's true, however the L15s were mostly used on long-haul flights whereas UA's DC-10 fleet was essentially made off domestic aircraft, except the eight DC-10-30s/-30CFs. Since with the acquisition of the Pacific network came all of PA's 74L, they fitted better in their fleet than the Lockheeds.
MIflyer12
Mon Mar 16, 2020 3:13 pm
Wikipedia says no DC-10-30 to L-1011-500, but if you want to cite a source, great.
SpaceshipDC10
Mon Mar 16, 2020 3:21 pm
It might be that the DC-10-30s from around 1979/80 have a little longer, not by much, range than the L15. This with more capacity. Wikipedia indicates the early variants engines and MTOW.
FLALEFTY
Mon Mar 16, 2020 5:07 pm
The L1011-500 carried 246 passengers (multi-class) at a MTOW of 510,000 lbs. for a max range of 5,345 nm; the DC-10-30 carried 270 passengers (multi-class) at a MTOW of 555,000 lb. for a max range of 5,100 nm. (Source: Wikipedia)
ltbewr
Mon Mar 16, 2020 5:18 pm
Did any of these PA L-1011's after UA and DL go to other operators like ATA ?
kaitak
Mon Mar 16, 2020 7:35 pm
I presume no UA crews ever trained on the L1011? All ex-PA until they presumably converted to whatever their seniority would allow (767s? DC10s?) once the L1011s were retired?
Was there bad feeling; did PA crews feel that they were treated well by UA? Did UA make an effort to make them feel welcome?
deltacto
Mon Mar 16, 2020 7:58 pm
Of UA's 6 L15's ... Delta acquired 5 and LTU acquired 1 .... none went on to fly for any other carrier after Delta and LTU retired them
https://rzjets.net/aircraft/?parentid=1 ... frstatus=3
Initially Delta kept their L15's at 10 abreast in coach and flew them on transpacific routes. Once DL acquired enough MD11's, they reconfigured the L15's to 9 abreast and flew them transatlantic
SpaceshipDC10
Mon Mar 16, 2020 9:14 pm
I know, hence what I said about early variants. For instance, Laker Airways DC-10-30s had a MTOW of 580,000 lb. and CF6-50C2 engines producing 54,000 lb. thrust.
DL_Mech
Mon Mar 16, 2020 11:59 pm
Some sort of UA interior made it to the L10s. I remember seeing used UA airplane carpet at the TOC in ATL in the early '90s (presumably from a UA L10).
This plane is built to withstand anything... except a bad pilot.
UA444
Tue Mar 17, 2020 1:04 am
The SP stayed until 1995 or so. Which is why they were repainted quickly and refurbished quicker.
Cody
Tue Mar 17, 2020 1:21 am
Was it the charcoal grey carpet with little red and white squares?
Someone above asked if the 1011s were all crewed by former Pan Am folks. I believe UAL put some new hire flight engineers into the L1011.
UA857
Tue Mar 17, 2020 9:31 am
What routes did UA fly the L-1011 on during its career I want the full route list from 1986-1989.
BravoOne
Tue Mar 17, 2020 2:56 pm
The aircraft were crewed by those Pan Am flight crews that transferred to UAL with the sale of the Pacific division.I suppose that if UAL increased utilization there would e some additional slots open up that in turn would be available to the UAL pilot group. Would be surprised to see any off the street new hires migrate to the L1011 as it would require pay protecting a significant group of UAL pilots. I guess anything was possible.
DL_Mech
Wed Mar 18, 2020 5:18 pm
Yes, that was it.
Cody
Wed Mar 18, 2020 5:57 pm
If that was the case I assume the seats were like the DC-8. I have a picture here but I have no idea how to post it.
Users browsing this forum: BC77008, MSN [Bot] and 50 guests
