jacobchoi
What replaces LH 346?
Fri Jun 19, 2020 1:58 pm
Hello! I am interested in what LH decides to put on its FRA-HKG routes during summer 2020. I am scheduled on LH 797 in J and as of today, it remains a 346, which AFAIK, are all stored indefinitely. Being on the route at least once a year, anecdotal evidence suggests high loads in F. Post Covid, the only F remaining planes with F are 747-8 and 333. The former might be too big and the latter lacking range. All the 359s are based in MUC. Would LH just surrender one of its post premium markets with F to CX? LH796 for my flight to HKG in July is now an A343 which is as old as it gets with LH, can't imagine it being a long term solution.
lightsaber
Re: What replaces LH 346?
Fri Jun 19, 2020 2:12 pm
If you are talking the fleet, it is shrinking (reduced frequency and some cut routes). HKG will fly, probably on an A359, eventually that route is probably going 779. Some A346 routes will become 789 routes. Possibly HKG until it recovers.
Lightsaber
I cannot wait to get vaccinated to live again! Warning: I simulated that it takes 50%+ vaccinated to protect the vaccinated and 75%+ vaccinated to protect the vac-hesitant.
seahawk
Fri Jun 19, 2020 2:21 pm
Which demand?
Speedbird96
Fri Jun 19, 2020 2:27 pm
LH’s A333 no longer have F cabins.
"To most people the sky is the limit. For those who love aviation, the sky is home." - Unknown
Speedbird96
Speedbird96 wrote:
LH’s A333 fleet no longer have F cabins.
Speedbird96
Fri Jun 19, 2020 2:28 pm
jacobchoi
Fri Jun 19, 2020 2:30 pm
It's the MUC based A333s that don't have F AFAIK
seahawk
Fri Jun 19, 2020 2:41 pm
Nobody flies F at the moment. If you would fly F and need to fly you use a private jet.
RvA
Fri Jun 19, 2020 2:49 pm
Since when?
InnsbruckFlyer
Fri Jun 19, 2020 2:54 pm
All LH A330s are FRA based, and none have F.
Last flown aircraft: DH8D OE-LGN < DH8D OE-LGI < E195 OE-LWE < DH8D OE-LGI < A320 D-AIUR < A320 D-AIZM < B738 PH-HZJ < B737 PH-XRD < B772 N766AN < B738 N855NN < B788 N45905 < A319 N808UA < A320 N482UA < B752 N19117
InnsbruckFlyer
Fri Jun 19, 2020 2:58 pm
RvA wrote:
Since when?
The last time I flew on an LH A330 with F was in 2014. The last aircraft to get the F cabin removed was D-AIKM, which was reconfigured in March 2018.
LHA320
Fri Jun 19, 2020 3:02 pm
Easy answer. Some routes are cancelled, the rest will be flown by a mix of A333/A343 from FRA and A359 from MUC.
Long term 789 from FRA and A359 from MUC.
AB6 - A319 - A320 - A321 - A333 - A388 - AT42 - 733 - 734 - 735 - 73H - 738 - 752 - 753 - 763 - 772 - DC10 - MD83
MIflyer12
That sounds like a self-imposed constraint quite readily overcome. Among other solutions, observe that lots of carriers with bases at XXX fly XXX-YYY-ZZZ to avoid having bases at YYY.
Users browsing this forum: klm617 and 11 guests
