Sdmccray1984
Fastest Turnaround Times?
Tue Jun 23, 2020 11:52 pm
Back in February(just prior to covid) I spent a couple weeks in Spain. Transiting through BCN, I was impressed at how fast Vueling Airlines could turn their A321s. They use a 220-seat configuration but turned it in 55 minutes! So it has me wondering what are the fastest turnaround times you guys have seen? Which airports do it best?
AA757223
Re: Fastest Turnaround Times?
Wed Jun 24, 2020 12:18 am
I’ve done 10-15 min turns in an EMB145. Granted we weren’t necessarily (and its a tiny airplane!) full nor did we need fuel. I don’t think it’s as airport-specific as it is airline-specific, but that’s just in my experience!
MoKa777
Wed Jun 24, 2020 12:24 am
In South Africa, FlySafair does 25-30 minute turns on 189-seat Boeing 737-800s.
Never be proud. Always be grateful.
Qantas16
Wed Jun 24, 2020 12:25 am
55 minutes is not an impressive turn for an A321... many airlines turn narrow bodies in 25-30min. Whilst it's dependent on factors like whether there is a crew change, level of cleaning/catering required, how much fuel is needed, it is certainly possible to achieve some very impressive turns. The most impressive I've seen is a 47min turn on an A330-200, however this was no crew change and no catering services.
Not sure it's so much airport-based but more airline/GHA based. Some airlines (LCCs/ULCCs in particular) are very focused on turn times so invest in it heavily whereas some are not as focused as they schedule longer turns between flights.
WeatherPilot
Wed Jun 24, 2020 12:38 am
Southwest use to turn planes in 10 minutes.
https://youtu.be/gnFfFRDMd_0
southwest1675
Wed Jun 24, 2020 12:57 am
Southwest Airlines has entered the chat.
Herb Kelleher 1931-2019
26point2
Wed Jun 24, 2020 1:53 am
The plane I fly BBD GLEX limitations require minimum
15 minutes from landing to take off Due brake heating...brakes need time to get to max temp after landing before a take off is considered. Granted a GLEX is not an airliner and we typically carry 1-2 passengers but 15 mins cannot be beaten (on/off) in my world. We have dropped a pax and turned in 3 minutes then taxied out only to wait and watch the 15 minute egg timer for a few more mins before we can depart.
CATIIIevery5yrs
Wed Jun 24, 2020 2:19 am
A long time ago flying the turbo prop commuters we’d do single engine turns. On the EAS routes if no one was getting on or off at a particular stop, the turn time took the length of time it takes to have a new dispatch release handed to you, sign it, hand it back out to the ground crew, close the door, and taxi back out for departure.
aemoreira1981
Wed Jun 24, 2020 4:50 am
For a mainline plane, the gold-standard is 25 minutes. FR can go to extremes with this, as their B738 fleet has built-in airstairs. (If a crew change is needed, then the turnaround time is 40 minutes.) WN and U2 (and related) also seek a 25-minute turn. Stage length might also be an issue with turnarounds, as one has seen being a problem in Hawaii, where one can't do a 25-minute turn on inter-island flights with a non-T-tail aircraft.
Now, a question I have related to the original post is: what's the quickest wide-body turn? When NZ had announced EWR prior to COVID-19, they had planned on a turn-around of less than 2 hours.
qf789
Wed Jun 24, 2020 5:41 am
I have been involved in a 45 minute turn on an A330-200 which included change of crew and catering, both inbound and outbound flights were full as well. This particular flight arrived into PER late and was going back to SYD, late afternoon flight, the one that is time sensitive due to curfew in SYD. Anyway the aircraft arrived on bay at the time it should have left, we got an exemption, however if we had gone by the usual turn time for a A330-200 for domestic which is 70 minutes the flight would have had to be delayed over night.
I have done plenty of trans con turns in 35 minutes on 737-800’s as well
Forum Moderator
PatrickZ80
Wed Jun 24, 2020 5:50 am
Ryanair has scheduled 25 minutes turnaround times, and mostly they make that. Wizzair takes a little more time, 35 minutes. Impressive given that they got near 100% load factors.
sfjeff
Wed Jun 24, 2020 6:02 am
When I worked at MSY in the early 80s, WN indeed had 10-minute turns. IIRC, they operated 18 daily flights at MSY from one gate and only lengthened the turn times when they started getting 737-300s. I heard at the time that this was because the CFM-56 engines needed more time to cool before being restarted.
Jeff in Málaga
FlyingHonu001
Wed Jun 24, 2020 9:21 am
Last year I worked as a AMS ramprat, sometimes even KL 744's full pax had a one hour or less turnaround window with disembarking, cargo, catering swap and cabin cleaning, security check, boarding etc, the whole nine yards, kinda impressive to witness
blandy62
Wed Jun 24, 2020 1:11 pm
I have seen air Asia turning some plane in 20-25 mns
FGITD
Thu Jun 25, 2020 5:54 pm
Are you sure? I've turned KL 744s, both pax and combi, as well as 747s for various other operators. No one has ever come close to doing a full turn in 60 minutes. Matter of fact, I think KLM even gave us a minimum time of something like 2hrs and 10 minutes. I'd believe it for just a departure from a pre-ready aircraft though.
Without fail, every airport I've worked or visited, the fastest widebody turn was somehow Swiss. Narrows is a different story, as the requirements are just so different regarding catering, baggage, crew, fuel, etc.
klm617
Thu Jun 25, 2020 10:32 pm
Back in the day of US regionals 10-15 minute turns were not uncommon on NC, AL, SO, PI, FL and OZ
the truth does matter, guys. too bad it's often quite subjective. the truth is beyond the mere facts and figures. it's beyond good and bad, right and wrong...
Chemist
Sat Jun 27, 2020 6:02 am
I timed a WN 737-700, capacity 149, both flights mostly full, arrival to pushback in 23 minutes at Burbank.
Burbank uses a ramp in front and stairs in the rear, and of course WN uses first come-first serve seating.
I'll also add that at Burbank, due to the old design (tight non-conforming layout of runway and terminal), the taxi distance for the normal landing runway is rollout and turn right and go about 70 meters and you are at the gate.
Many years ago, when I took a day trip, I parked at the parking structure across from the Burbank terminal. Upon laning back at BUR, I timed wheels down to at my car and did that in 5 minutes. I was sitting at the back of the WN flight. We touched wheels on landing, rolled out, turned right to the gate, stairs pulled up, I was out the door and through the terminal and across the street in total 5 minutes, wheels down to at my car.
I love Burbank airport.
opticalilyushin
Sat Jun 27, 2020 11:16 am
I've turned around a 146 in 12 minutes. I tried to beat the record many times on some turboprops, but the slow start up on stand always messed things up.
As a passenger, maybe 3-4 minutes in Africa on a DHC-7, but that was a multi-stop service rather than a completely new scheduled flight
T18
Sun Jun 28, 2020 2:06 pm
I've seen the same a number of times, its amazing how fast a 50 seater can get turned around. I think the normal min turn I've seen planned for the 145 or 550 is a 24 minute turn and crews manage to beat that time too. It really impresses me as most days it take me longer to get out of bed.
“Racing's important to men who do it well. When you're racing, it's life. Anything that happens before or after is just waiting.” ― Steve McQueen (Le Mans) 1971
fessor
Sun Jul 05, 2020 6:34 pm
In 2001 I was booked on TG 747 CPH-BKK-DPS the flight from BKK arrived later very late, all passengers was at gate, when the flight came in about 15.00 the flight was supposed to leave 14.35, if left again at 15.45 so a turn around time in 45 min.
My problem was that I had a transfertime on 1hour 45 min in the old BKK airport I reach the plane as the last one.
Later learned that more didn't reach the plane to Denpassar
SRQKEF
Mon Jul 06, 2020 2:46 pm
Regarding widebodies, FI does some sub-hour turns on the 767 in KEF. For example, the MUC/LHR flights are scheduled to arrive at 16:00 and the aircraft is back in the air to BOS/JFK/SFO at around 17:00-17:15.
Users browsing this forum: mmo and 37 guests
