UA857
Planned range for the 777-9?
Sat Apr 17, 2021 5:05 pm
What is the planned range for the 779 can it be able to fly ULH routes such as JFK/EWR-SIN, JFK-SYD and LHR-SYD with a full payload or can it only fly routes that the 744/77W/748 can fly? If so will the 778 be cancelled if the 779 can be able to do ULH routes? Any thoughts?
mig17
Re: Planned range for the 777-9?
Sat Apr 17, 2021 9:41 pm
Per Boeing (https://www.boeing.com/commercial/777x/ ... ical-specs) the 777-9 design range is 7,285 nmi (13,500 km) with 426 pax (~43t). And the 777-9 doesn't seems to be a good ULH plane.
A30B IW/TG, A313 EK, A318/9/20/1 AF/U2/VY, A332/3 EK/QR/TX, A343 AF, A35K QR, A388 AF, AT72 A5/TX, B722 AT, B734/8 UX/SK/TO/SS, B742/3/4 UT/AF/SQ/BA/SS, B762 UA, B77E/W AF/QR, C-150/72, CRJ1/7/X A5, E145/70/90 A5/WF, DH8D WF, PC-6.
UA857
Sun Apr 18, 2021 2:46 am
Isn't the 779 designed to fly further than the 77W?
flipdewaf
Sun Apr 18, 2021 6:48 am
It appears to have the same spec range and, with the greater spec payload, the same MZFW range too. It does appear to have a large cabin floor area and so may well be very suited to high premium airlines where space matters more than weight.
Fred
Sent from my iPad using Tapatalk
mig17
Sun Apr 18, 2021 11:05 am
Fred
It seem the 779 has the same payload/range than the 77W. It is heavier and longer but also with more efficient engines and wings.
Lingon
Sun Apr 18, 2021 12:45 pm
Forgive an ignorant person, but I am really curious what 7285 nmi design range means. When the plane has flown the 7285 nmi distance (under some specified set of conditions), do the motors flame out, does the plane still have fuel to hold and land with contingency fuel intact, is it even possible to reach some alternate? Shorter said - how long can a viable route typically be when the design range is 7285 nmi?
mig17
Sun Apr 18, 2021 3:49 pm
An aircraft performance is known and described in the technical documentation of the type. For exemple, take off performances.
For range and payload, both are linked, the manufacturer define a payload range curve giving max nominal range of the aircraft depending of the payload.
The max range of an aircraft can be limited
- by MTOW and for each given payload how much of the MTOW is left for fuel.
- by max fuel if the tank are full whatever the payload is under MTOW.
Lingon
Mon Apr 19, 2021 6:56 am
Thank you, I understand that much. But is the range defined as the absolute maximum the plane is able to fly under the specified conditions (until fuel exhaustion), or as the useful distance you can operate the plane (landing with prescribed spare fuel)?
If I am to operate a route that is 7200 nmi long, can I use a plane with range 7285 nmi (under the specified conditions regarding take off weight, fuel load, weather...) ?
VSMUT
Mon Apr 19, 2021 7:12 am
In practice there is no specific maximum range. It depends on actual conditions, availability of alternate airports at the destination and payload. 85 nm longer should be possible if you tweak the flight a bit, reducing payload, flying at a more economical level etc., but if conditions turn out to be worse than expected, you could also end up having to divert.
Users browsing this forum: Bing [Bot] and 27 guests
