convair880mfan
Which commercial aircraft manufacturer's flap system do you like best?
Fri Sep 17, 2021 10:05 pm
Some companies use flap hinges on their trailing edge flap system. Others use jackscrews. The Boeing 747 has an interesting cambered lead edge flap system. What do you think are the pros and cons of each?
CMA727
Re: Which commercial aircraft manufacturer's flap system do you like best?
Fri Sep 24, 2021 12:53 am
Boeing´s 727 flaps!!! By far..
classicjets
Fri Sep 24, 2021 5:38 am
DC-8. Slots instead of slats and "exhaust gates" on the flaps. Special!
Sent from my ELE-L29 using Tapatalk
n901wa
For me the L-1011 flap system was good. Would get some Hyd switch can issues, but out on the wing was good.
b4thefall
Fri Sep 24, 2021 6:01 am
Modern flaps are generally boring to look at from an Anutter perspective. My favourites from my own personal experience were BAC 1-11, L1011, 747, 757 & A300B4. I love the huge flap fairings on the B4. Have photo somewhere, takenfrom behind the wing while flying over the French Alps on a TransAer A300B4.
CarlosSi
Sat Sep 25, 2021 7:33 pm
More slots than at a casino!
The classic 737 flaps had some character just by how noisy they were.
DL_Mech
Sat Sep 25, 2021 9:12 pm
Funny! Two of my favorite 727 flap photos (both from Jon Proctors website):
From: https://jonproctor.net/wp-content/uploa ... 60x482.jpg
From: https://jonproctor.net/wp-content/uploa ... 60x519.jpg
BoeingERJ1000
Thu Feb 03, 2022 10:07 pm
The 727's flaps. Very distinctive and interesting.
All other flaps look the same IMO. I wouldn't call them boring because seeing them deploy and retract is still cool to see. They just all blend together.
seat1a
Fri Feb 04, 2022 4:50 pm
The photos of the TWA 727 are beautiful, so thank you for sharing.
Aaron747
Fri Feb 04, 2022 4:54 pm
Favorites: L-1011, 747, 757, 727, DC-8
The 3/4 span flaps on Global Express and G-V are pretty nifty too.
Honorable mention: the C-5 and C-141
GalaxyFlyer
Fri Feb 04, 2022 11:37 pm
C-5 system is pretty simple set-up, slats and single-slot flaps. The Chug 14-1 didn’t have slats. The Global has slats, the Gulfstream uses flaps that extend off the chord line, the Global’s extend perpendicular to the flow. I never understood GLF’s lack of slats and using wing area to make up for their lack. They had a ground effect stall in the GIV program, then the crash in the G650 test. Slats effectively manage the wing flow and are both a performance and safety benefit. That said, the heavier Global needed all it trick stuff to match the GLF in some situations. It’s 5,000 pounds lighter, so where did they take out the weight? Slats, hydraulic flight controls 3, not 1, hydraulic system.
Aaron747
Sat Feb 05, 2022 1:01 am
Both the -5 and -141 look incredible when it's all hanging out. I especially always liked how the -141s outboard was tapered and shorter than the inboard - saw a lot of 141s visiting NUQ as a kid. There's just something about big-Lockheed flap designs.
blandy62
Sat Feb 05, 2022 8:32 am
i have always loved sitting behind the winds of a 747 and see those flaps coming out. I guess I shall never witness that again :(
77west
Sun Feb 06, 2022 1:34 am
I always thought the big long wings on the GLF were more for long range cruise performance
GalaxyFlyer
Sun Feb 06, 2022 4:24 am
Well, yes but also large wing area to make up for the lift that would have been achieved by more sophisticated high lift devices. High aspect ratios are good for range but not larger than necessary wetted areas.
Users browsing this forum: Google Adsense [Bot], ilham123, Tokushima, vatveng and 36 guests
