OSDIman wrote:Could/would Boeing do it, do you think?
Noshow wrote:Unfortunately the final 747 assembly has happened already. Just for the fun you could go to Victorville or Marana and have them build it for ground use only?
hOMSaR wrote:Understanding that this isn’t a question of economic viability, but rather what configuration mixes work: The 747-400 and -8 already came with both short and long upper decks (purpose-built freighters with short ones, and the pax built ones with the stretched upper decks. But the 747SP couldn’t “easily” get a stretched upper deck because, from an engineering perspective, its upper deck is already a stretch. Basically, the upper deck on the SP extends over the wingbox, vs. ending around the start of the wing on the -100/200. Boeing carried this concept over to the -300/400/8. If you wanted to stretch the upper deck on an SP, you’d be doing significant additional redesign at that point. The SP also requires a modified tail design to accommodate a taller fin, which is necessary because of how short the fuselage is. Also, since there isn’t as much room between the trailing edge of the wing and the actual tail for the tapering that would be present on a normal 747, the SP had to have the weird shape at the rear where it suddenly narrows and has awkward angles, vs. the more graceful design of a standard 747.
