mustiturnright
Longest small island to small island flight ?
Tue May 16, 2023 10:47 am
Does anyone know what the longest flight has ever been either scheduled or in an emergency diversion for a commercial wide body ? From one small island to another ?
No charters.
Can anyone come up with the longest possible flight time for a scheduled commercial route from a small island on a wide body that could be diverted realistically to another small island ?
I’m guessing SIN to somewhere ?
T54A
Re: Longest small island to small island flight ?
Tue May 16, 2023 10:57 am
SIN-NAN
qf002
Tue May 16, 2023 11:00 am
Depends a bit on how you define "small island"... There are quite a few major airports that are on "islands".
Technically HKG and YVR are both on islands. HKG-YVR could divert to somewhere like KIX which is also on an island.
SIN-NAN might be more along the lines of what you are thinking and could divert to somewhere like NOU.
davidjohnson6
Tue May 16, 2023 11:03 am
London Heathrow to Perth, Australia. Non-stop and both are on islands.
aj4evur
Tue May 16, 2023 11:47 am
Australia and Great Britain certainly arent small islands though.
aj4evur
Tue May 16, 2023 11:53 am
Figure id put a different combination out there since SIN is a small island but not actually far from mainland
NAN-HNL
PatrickZ80
Tue May 16, 2023 12:24 pm
Azores Airlines flies Ponta Delgada to Bermuda, I think that qualifies.
nicode
Tue May 16, 2023 1:06 pm
IPC-PPT maybe ?
Mortyman
Tue May 16, 2023 1:48 pm
Honolulu, Hawaii to Papeete, Tahiti is around 5 hours and 50 minutes
Rapa Nui, Easter Island to Papeete, Tahiti is around 21 hours and 45 minutes ( This is not a direct flight and has 2 stops, however it is 21 hours and 45 minutes actual flight time )
GalaxyFlyer
Tue May 16, 2023 2:19 pm
I’ve done it, nothing like 21 hours, more like 5
PatrickZ80
Tue May 16, 2023 4:13 pm
There have been direct flights on that route in the past. Apparently the route has been scrapped but back when it was still flown I believe 5 hours flight time sounds about right.
PatrickZ80
Tue May 16, 2023 4:17 pm
PS I found another fun one, Blue Islands operates a seasonal flight Jersey to Palma de Mallorca. Not as long as those pacific routes but it does connect two small islands.
And in the Indian Ocean there are direct flights from Mahé (Seychelles) to Mauritius, Reunion and Malé (Maldives).
PlymSpotter
Sat May 20, 2023 9:43 pm
There are flights from FAE to PMI and the Canary Islands - the latter must be approaching 5 hours of flying time.
Cubana used to operate HAV-TFN (IIRC) with the Il-62 - that's 4,086 miles
Air Tanker are currently operating SID-MPN, which is 5,181 miles
bfitzflyer
Sun May 21, 2023 1:32 am
JFK to SIN.
Max Q
Sun May 21, 2023 2:03 am
Honolulu to Guam and an unusual example years ago was a non stop from the Falkland Islands to London, I think that was a BA 744
MartijnNL
Mon May 22, 2023 9:54 am
Only if the flight is operated on a widebody.
MartijnNL
Mon May 22, 2023 10:04 am
bfitzflyer wrote:
JFK to SIN.
Are JFK and SIN build on islands? As far as my knowledge goes you can drive your car to both airports. In my opinion islands can only be reached by ferry or airplane. When you connect the land by bridges to the mainland, it's no longer an island.
bfitzflyer
Mon May 22, 2023 10:58 am
MartijnNL wrote:
bfitzflyer wrote:
JFK to SIN.
Even with a bridge it is surrounded by water, therefore by definition it is an island.
AirKevin
Tue May 23, 2023 4:05 am
MartijnNL wrote:
bfitzflyer wrote:
JFK to SIN.
So would you consider SXM to be on an island or not, given that you could drive a car to the airport.
MartijnNL
Wed May 24, 2023 5:57 pm
Of course. Sint Maarten / Saint Martin is way out in the ocean. Singapore and New York not so much.
You can't drive to SXM from the mainland.
AirKevin
Wed May 24, 2023 10:33 pm
You also weren't specific with your initial statement, hence my inquiry.
afterburner
Thu May 25, 2023 4:00 pm
Is New Zealand's North Island small enough? AKL-HNL is 3814 nm.
AntonioMartin
Fri May 26, 2023 3:23 pm
bfitzflyer wrote:
JFK to SIN.
Technically you are right..
Years ago there was a British Caledonian 747 from Puerto Rico to LGW. Also BA flew this route in the 90s with DC-10s I think.
afterburner
Sat May 27, 2023 7:14 am
Great Britain, the island where LGW is located, is not quite small. In fact it's the 9th largest island in the world. :mrgreen:
AntonioMartin
Sun May 28, 2023 11:00 pm
Wow I didn't know that! There is always something new too learn, lol! Thanks for the fact!
CarlosSi
Sat Jun 03, 2023 7:18 pm
Clearly “small island” needs to be defined better, or categorized.
I.e., smallest island not to exceed X square miles in size and also not less than X miles from the nearest shore with a coastline greater than X miles in length.
Oh yes, and have you ever heard of the coast line paradox? Even before this it is very much a problem figuring out a very subjective question.
DocLightning
Sat Jun 03, 2023 9:32 pm
bfitzflyer wrote:
JFK to SIN.
JFK is not on a small island. It is on a Long Island. :duck:
CarlosSi
Sun Jun 04, 2023 2:41 am
Kansai also sits on an island. Therefore KIX-HKG would be an option(though not very long distance of course).
blandy62
Mon Jun 05, 2023 3:19 am
not the longest but HNL-MAJ is fairly long too
seat1a
Tue Jun 06, 2023 2:03 am
FHR-ESD. :lol: Kidding.
RyanairGuru
Tue Jun 06, 2023 3:11 am
MartijnNL wrote:
bfitzflyer wrote:
JFK to SIN.
Drive your car from where? Of course you can drive your car from Singapore city to Changi Airport, they are both located on the island of Singapore (which is not a large island in terms of land mass). If you meant that you could drive from the Malay peninsular to the island of Singapore, then I guess you’d need to define how far off-shore you would need to go to consider a land mass an “island”.
eta unknown
Wed Jun 07, 2023 5:58 pm
Air Mauritius, Port Louis to Rodrigues.
Mortyman
Wed Jun 07, 2023 9:42 pm
Papeete - Nuku Hiva 3 h 15 min
Users browsing this forum: PatrickZ80, socaljoeyb and 30 guests
