dl757md
Farthest Distance Between 2 Airports U Have Been 2
Sun Jan 13, 2008 7:51 am
To get an idea of how far apart the 2 most distant points on earth you've visited, tell us the two airports that you've been to that are the farthest apart.
For me it's OGG and AMS. 7265 NM according to the GCM.
DL757Md
Analog
RE: Farthest Distance Between 2 Airports U Have Be
Sun Jan 13, 2008 8:01 am
This is an interesting math problem. If we limit to N airports, there are N chose 2 combinations. So for 100 airports there are 4950 pairs. I'm too lazy to check for my own travels.
threefourthree
Sun Jan 13, 2008 8:08 am
For me, its only SYD-KUL which is 4088 miles.
andz
Sun Jan 13, 2008 8:13 am
If non-stop then it is JFK-JNB which is 7,969 miles.
If from start to finish of a trip then JNB-LHR-LAX which is 11,076 miles
ag92
Sun Jan 13, 2008 8:23 am
In memory e.g. Past 7 years would be SIN - LHR however in whole life it would have to be I think SIN - JFK or whatever the airport was in New York in around 1996-1999
Analog
Sun Jan 13, 2008 8:26 am
Among my visited airports I've found EZE-ICN at 19,483km (12,106mi, 10520nm). That's probably pretty close to the maximum distance between two points on Earth (about 20 megameters).
Quoting Andz (Reply 3):
If I interpret the original question correctly, your answer is LAX-JNB at 10,385mi (9024nm).
dl757md
Sun Jan 13, 2008 8:31 am
My query was meant to address the two most distant airports that you have EVER visited. For example, the two airports I listed in my thread starter, I visited almost 20 years apart. Non-stop and same trip pairs are also welcome, of course.
DL757Md
dl757md
Sun Jan 13, 2008 8:33 am
Quoting Analog (Reply 5):
Your interpretation is correct.
D328
Sun Jan 13, 2008 8:41 am
Edit:
Marathon, FL MTH. and Anchorage, AK ANC. 3511NM is my farthest.
MTH-ANC 11NM farther than my other EYW-ANC.
[Edited 2008-01-13 00:54:19]
andz
Sun Jan 13, 2008 9:52 am
okay then in that case the answer would be LAX-MRU, 11,470 miles
LHRjc
Sun Jan 13, 2008 9:55 am
I guess for me then it'd be EDI and CHC which are 11,550nm apart.
"Our 319's are very reliable. They get fixed very quickly."
Analog
Sun Jan 13, 2008 10:06 am
Quoting LHRjc (Reply 10):
That would be a neat trick, seeing that 11,550nm is a bit more than half the Earth's circumference.
You meant 11,550mi = 10,037nm = 18588km
kiwiandrew
Sun Jan 13, 2008 10:36 am
for me I am pretty sure that ZQN and LIS would have to be the two furthest apart out of all airports I have used - 19290 km ( or for those of you in the dark ages 11986 miles ) separate them according to GCM
Gemuser
Sun Jan 13, 2008 12:39 pm
CHC-LHR 10246 nm (11791 mi, 18976 km)
Gemuser
DC23468910;B72172273373G73873H74374475275376377L77W;A319 320321332333343;BAe146;C402;DHC6;F27;L188;MD80MD85
Sun Jan 13, 2008 2:21 pm
For me it is 5045 nm between FRA and LAX!!1
Sun Jan 13, 2008 2:41 pm
Mine is FRA-HKG. On LH.
9vswa
Sun Jan 13, 2008 3:35 pm
AKL and LHR for me. 9910nm (11404mi, 18354km)
teo747
Sun Jan 13, 2008 4:10 pm
PHX & ATH for me, I think...6766 miles (5880nm).
a380us
Sun Jan 13, 2008 6:29 pm
mine is
BKK- PTY
10,866 mi
www.JandACosmetics.com
Analog
Sun Jan 13, 2008 6:53 pm
Somebody who's been to NZ and Spain or Morocco will probably win. AKL-XRY is 19940km.
Are there any two airports with regular commercial service that are at least 20,000km apart? TNG-WRE is 19,998km apart and can be done with three stops (four flights) in about 35 hours.
Wheee. I'm still winning. even though it's not relevant for this "contest", I actually went from ICN to EZE within a week. ICN-LAX-IAH on a Friday, IAH-EZE on the next Friday.
With apologies to Dl757md for taking over, so far we have (I added the number of stops needed if one were to actually try to get from one to the other):
19,998km: ???: TNG-WRE (three stops needed)
19,483km: Analog (yay!): EZE-ICN (one stop needed)
19,290km: Kiwiandrew: ZQN-LIS (three stops flights needed)
18,588km: LHRjc: EDI-CHC (two stops needed)
18,354km : 9VSWA: AKL-LHR (direct one-stop, single aircraft service!)
Paddy
Sun Jan 13, 2008 6:55 pm
DCA and TPE: 7877mi. That will probably change substantially when I fly to CPT for The Cup in 2010. CPT is "out there!"
LO231
Sun Jan 13, 2008 7:36 pm
LHR and CPT
LHR and MRU?
LO231
Got both LO 788 frames already, next LO E95 and 734 BRU-WAW-BRU
NWADC9
Sun Jan 13, 2008 7:40 pm
RSW and PUS - 7738mi.
I get paid to convert dead dino juice into noise.
PGNCS
Sun Jan 13, 2008 7:42 pm
I would have to go back and look to make sure (which I am far too lazy to do), but I am guessing HNL to FCO at 8042 NM.
HNL (21°19'07"N 157°55'21"W) FCO (41°48'16"N 12°15'03"E) 8° (N) 8042 mi
scouse
Sun Jan 13, 2008 7:59 pm
the furthest apart I can find of my travels is NRT and GRU at 9984nm, 11489miles or 18490km according to great circle mapper.
Love to fly
AllegiantAir
Mon Jan 14, 2008 1:31 am
HNL-SXM is 6,076 miles.
Live to Fly.
bok269
Mon Jan 14, 2008 1:35 am
HNL-TLV at 7531 NM.
The message you were about to post is too short and probably not of any higher value to the topic at hand. You should think long and hard before posting a message in this forum and make it detailed and a valuable addition to the topic discussed.
Avoid posting "Me Too" messages. These are messages that are posted by people who agree to a point being discussed and post a one liner, "me too!", "Good post Jim!", "I disagree" or similar message. This takes up time as readers must sort through these messages which have no real value to the group at large. Any message containing nothing more than a line or two of text is probably not worth posting.
If you have an opinion on a topic, you should in detail express why you have the opinion and what made you come to that conclusion.
Your post should be relevant to the topic discussed.
"Reality is wrong, dreams are for real." -Tupac
sw733
Mon Jan 14, 2008 1:47 am
Anchorage, Alaska (ANC) and Pt Elizabeth, South Africa (PLZ) are 10,541 miles/16,965 kilometers apart. Think that's my max...
Viscount724
Mon Jan 14, 2008 2:19 am
A few of mine that exceed 10,000 nm:
PEK-EZE 10,413 nm (11,983 mi)
OGG-JNB 10,401 nm (11,970 mi)
LHR-CHC 10,246 nm (11.791 mi)
YHZ-PER 10,025 nm (11,537 mi)
dl757md
Mon Jan 14, 2008 2:40 am
Quoting A380US (Reply 18):
No apology needed. By all means run with it!
DL757Md
WildcatYXU
Mon Jan 14, 2008 2:50 am
My farthest pair would be ANU-NRT; 7399 nm
310, 319, 320, 321, 321N, 332, 333, 343, 345, 346, 732, 735, 73G, 738, 744, 752, 762, 763, 77L, 77W, 788, AT4, AT7, BEH, C402, CR2, CRA, CR9, DH1, DH3, DH4, E45, E75, E90, E95, F28, F50, F100, MD82, Saab 340, YAK40
Jeremy
Mon Jan 14, 2008 4:07 am
HNL-JNB
gcm shows it as 11,927 miles
You are now free to be sexually harassed and then terminated for filing a complaint--Southwest Airlines to me.
Evan767
Mon Jan 14, 2008 5:01 am
Quoting Jeremy (Reply 31):
HNL-JNB
Pretty much same here except:
OGG-JNB
11,970 miles
PanAm747
Mon Jan 14, 2008 5:15 am
My farthest points travelled:
North: Lake Itasca, Minnesota, 47.22 degrees North Latitude
South: Ka Lae, South Point, Big Island of Hawai'i, 18.9 degrees North Latitude
West: Jermaine's Luau on O'ahu, 158.105 degrees West Longitude
East: Dartmouth, Massachusetts, 70.97 degrees West Longitude
The distance between the farthest airports I have travelled to would be HNL and PVD, 4419 nm.
Going north-south, Bemidji (the closest airport to Lake Itasca, MN), BJI, to Morelia, Mexico, MLM, is 1683 nm.
Pan Am:The World's Most Experienced Airline - P(oor) S(ailor's) A(irline): San Diego's Hometown Airline-Catch Our Smile!
flymia
Mon Jan 14, 2008 6:11 am
LGW-AKL 9927 nm
STN-AKL 9880 nm
vhqpa
Mon Jan 14, 2008 11:05 am
HKT and MEL 3781nm
J
"There you go ladies and gentleman we're through Mach 1 the speed of sound no bumps no bangs... CONCORDE"
columba
Mon Jan 14, 2008 11:13 am
Either AMS-DTW or Brussels-ATL
It will forever be a McDonnell Douglas MD 80 , Boeing MD 80 sounds so wrong
kiwiandrew
Mon Jan 14, 2008 11:30 am
Quoting Kiwiandrew (Reply 12):
actually I am wrong , I forgot about a flight I did into MFN a few years ago in Twin Otter Big grin
distance between MFN and LIS 19308km (11997 miles for those stuck in the Stone Age ) - can anyone beat that ?
Genius12
Mon Jan 14, 2008 12:29 pm
For me, Vancouver-London Heathrow.
AlexPorter
Mon Jan 14, 2008 3:21 pm
Having only visited three airports outside of North America (all in Europe) this was easy for me to figure out! For me it is CDG and PVR, which are 5140 NM apart.
Last Flight: SCX701 MSP-PHX B738 8Jan2008
Analog
Mon Jan 14, 2008 7:16 pm
Quoting Kiwiandrew (Reply 37):
Yes:
The only possible ones that I can think of that can beat this are combos between the North Island of NZ and Southern Spain/Northern Morocco.
kiwiandrew
Mon Jan 14, 2008 7:28 pm
Quoting Analog (Reply 40):
DOH! it never even occurred to me to check between my home town of AKL and LIS or SVQ , I guess it seemed counterintuitive since DUD and ZQN are further south forgetting of course that the planet is (nearly ) a sphere . AKL and SVQ at 19939 km ( 12389 miles for all those  old  people out there ) seem to be my new 'furthest pair'
Yellowstone
Mon Jan 14, 2008 8:05 pm
For me, it's BOS and AYQ. The two are separated by 10,714 miles, which is 1,737 miles short of the maximum possible distance between two points on earth (12,450 miles).
Hydrogen is an odorless, colorless gas which, given enough time, turns into people.
LXM83
Mon Jan 14, 2008 8:24 pm
Mine is:
Qingdao (TAO/ZSQD) - Buenos Aires-Ezeiza (EZE/SAEZ): 19'821 km / 10'702 nm / 12'316 mi
So we have the following ranking (only one entry per person):
1 AKL SVQ 10766 nm 19939 km 12389 mi Kiwiandrew
2 TAO EZE 10702 nm 19821 km 12316 mi LXM83
3 EZE ICN 10520 nm 19483 km 12106 mi Analog
4 PEK EZE 10413 nm 19285 km 11983 mi Viscount724
5 OGG JNB 10401 nm 19263 km 11970 mi Evan767
6 HNL JNB 10365 nm 19195 km 11927 mi Jeremy
7 CHC LHR 10246 nm 18976 km 11791 mi Gemuser
8 EDI CHC 10037 nm 18588 km 11550 mi LHRjc
9 NRT GRU 9984 nm 18490 km 11489 mi Scouse
10 LAX MRU 9967 nm 18459 km 11470 mi Andz
11 LGW AKL 9927 nm 18384 km 11423 mi FlyMIA
12 AKL LHR 9910 nm 18354 km 11404 mi 9VSWA
13 BKK PTY 9443 nm 17488 km 10866 mi A380US
14 BOS AYQ 9311 nm 17243 km 10714 mi Yellowstone
15 ANC PLZ 9160 nm 16965 km 10541 mi SW733
16 SIN JFK 8288 nm 15349 km 9537 mi Ag92
17 HNL TLV 7531 nm 13948 km 8667 mi Bok269
18 ANU NRT 7399 nm 13703 km 8515 mi WildcatYXU
19 HNL FCO 6989 nm 12943 km 8042 mi PGNCS
20 DCA TPE 6845 nm 12677 km 7877 mi Paddy
21 RSW PUS 6724 nm 12453 km 7738 mi NWADC9
22 OGG AMS 6313 nm 11692 km 7265 mi Dl757md
23 PHX ATH 5880 nm 10889 km 6766 mi Teo747
24 HNL SXM 5280 nm 9778 km 6076 mi AllegiantAir
25 LHR MRU 5273 nm 9765 km 6068 mi LO231
26 CDG PVR 5140 nm 9520 km 5915 mi AlexPorter
27 FRA LAX 5045 nm 9343 km 5806 mi B747forever
28 HNL PVD 4419 nm 8183 km 5085 mi PanAm747
29 YVR LHR 4104 nm 7601 km 4723 mi Genius12
30 BRU ATL 3846 nm 7123 km 4426 mi Columba
31 HKT MEL 3781 nm 7002 km 4351 mi Vhqpa
32 SYD KUL 3552 nm 6579 km 4088 mi ThreeFourThree
33 MTH ANC 3511 nm 6503 km 4041 mi D328
Great game, keep your entries coming....
Analog
Mon Jan 14, 2008 11:53 pm
Quoting LXM83 (Reply 43):
 white  I've been dethroned.
Now the question is what is the most distant pair of airports that you can connect with one ticket? AKL-XRY is 12390mi (one more than AKL-SVQ).
AKL-SVQ and TAO-EZE can be done with two stops. EZE-ICN can be done with one stop.
Yellowstone
Tue Jan 15, 2008 1:20 am
My two cities, BOS and AYQ, can be connected with 2 stops: BOS to LAX (or SFO) to SYD to AYQ.
Avianca
Tue Jan 15, 2008 3:07 am
lim-ayt 12395 km
 Smile
FlyOakland2IAH
Tue Jan 15, 2008 6:06 am
Farthest for me is OGG (Maui, Hawaii) and AUB (Abu Dhabi) - 8683 nm, according to GCM.
aerorobnz
Tue Jan 15, 2008 6:15 am
AKL (37°00'29"S 174°47'30"E) PGF (42°44'27"N 02°52'11"E) 316° (NW) 10300 nm
KIX (34°25'38"N 135°14'39"E) EZE (34°49'20"S 58°32'09"W) 95° (E) 10131 nm
SIN (01°21'01"N 103°59'40"E) LIM (12°01'19"S 77°06'52"W) 174° (S) 10161 nm
are the top ones for me.
Flown to 147 Airports in 62 Countries on 83 Operators and counting. Wanderlust is like Syphilis, once you have the itch it's too late for treatment.
Users browsing this forum: No registered users and 38 guests
