I get the feeling your first action is to get booked on a
QF,
JQ or
DJ flight so you can be where you need when you need even if at a more expensive ticket.
- Then you are most likely to write off flying with Tiger ever again... unless you have already done that?
- Third action would be to read all the fine print associated with your purchase with a clear mind to see how correct they are.
- Fourth is to contact your Consumer Affairs office and discuss with them. They sold you one thing and are providing you with something else, if the alternate flight was the same day I would be more generous to Tiger (delays do happen anyway) but the next day.. next evening.. is something else.
As to can they? Well they just did. I think you meant to ask "should they?". From the point of view of the consumer, no they shouldn't, you got a raw deal, throws all plans out the window etc etc. I believe you are probably in a position where they can do it, probably have the correct wording in the documentation provided, but knowing how these things work, if consumer affairs fails, contact Today Tonight or A Current Affair if they are both on the air and you might get a refund from Tiger to shut you up as they are looking pretty bad. They can make the perfect peach smell like sewerage to make the ratings.
Personally, I'm a
QF flyer,
JQ if the price/time is right and
DJ is a good airline to deal with but I want my
FF points
. I would probably only book Tiger a day or two out and only if the price was that much better, I am yet to feel comfortable with them.
