Page 1 of 1
Connecting In JFK For The First Time - Advice?
Posted: Tue Mar 09, 2010 1:52 am
by MKP1013
Hi all,
I'm going to be on a Delta routing ATL-JFK-PWM this Friday evening and this will be my first time in JFK, so I have a few questions for you expert JFK flyers.
I'm scheduled to arrive around 8:00pm I believe, have a 47 minute layover until my RJ flight to PWM leaves around 9:00. So - are flights generally on time around this time at night, or is the rush hour still going on? How long do you think I can expect to wait in line for take off around this time? Is it difficult to find the Comair/Delta Connection gates and does it take a long walk to get to them? Actually, I've never even been on an RJ - what's the boarding process like? If you had this connection time, would you recommend checking a bag?
Thanks in advance!
-Mark
RE: Connecting In JFK For The First Time - Advice?
Posted: Tue Mar 09, 2010 2:12 am
by BMI727
Quoting MKP1013 (Thread starter):
I took a 10:00 pm JFK-PWM flight last summer and it was pretty much on time. But there will be tons of people in the area, because they use one gate for a bunch of Connection flights. Listen carefully to the agents to make sure that you line up at the right time in the right place for your flight, since there may be two or three other flights leaving the same gate as yours at almost the same time. Of course, also make sure that you find the right plane, but there are enough agents down in the tent corridors, that this shouldn't be a problem.
As far as food goes, there is a pretty good deli right there near the connection gates, but it is a bit pricey. A pretty good Cuban sandwich, excellent cheesecake, and a Coke cost me $18 there. Too bad you only have 47 minutes, as JFK is a great airport to just walk around. I was lucky that I had enough time to leave security and take the Air Train over to the new JetBlue terminal.
I generally say don't check a bag unless you have to. When I was there an agent with pink tags was standing in the tent area just after they took my boarding pass. I asked for a pink tag, got one, and carried my bag out and handed it to the ramper by the cart near my plane. I of course got the bag back first thing on arrival at PWM, and I personally like gate checking, but that is just personal preference.
No and No. Most, if not all of the Connection gates (at least the ones I used) are located on the southeast corner of terminal 2. If your flight comes in at terminal 2, you'll have no problems, since the terminal is not that large. It is a bit worn out, but functional. Terminal three is connected to T2 by a corridor, so there will be a little bit of a hike involved although there are travelators in some of it. Terminal 4 is connected to terminal 2 via a shuttle bus. None of these options require leaving security.
Edit: Don't forget that your flight may be somewhat delayed due to the fact that JFK is down a runway for a while due to construction.
[Edited 2010-03-08 18:13:52]
Posted: Tue Mar 09, 2010 2:27 am
by Delta763
Hopefully you'll get a real gate when you arrive and won't have to get on one of those mobile lounge things.
Also, it's possible you'll arrive at T3 and your outbound is at T2. That'll require some walking time.
Personally, I would never give myself less than an hour to connect at JFK. Chances are, you'll arrive at T2 and everything will be fine, but it's a good idea to plan for inconveniences just in case, especially there.
As for checking bags, I generally don't if I can avoid it, particularly with a connection. I'd rather take the bag to the next plane myself than trust the guys down below to do it for me (no offense, guys).
Posted: Tue Mar 09, 2010 2:35 am
by RobertS975
Regardless of whether your ATL-JFK flight comes into T2 or T3, there is a connecting corridor inside of security. Your connection is a tight one for JFK, but your ATL flight arrives after most of the gate and ramp congestion has subsided.
Rain is in the forecast for Friday in the NY area but this will be more likely to delay your RJ flight to Maine, making it easier to make your connection.
Most RJ flights leave from Terminal 2 Gates 23 and 25, but there are exceptions. You will gate check anything other than the smallest of carry on bags and you will get the bag back prior to entering the terminal at your destination. Most computer bags can be brought aboard unless they are too plump!
As far as actual checked luggage, that can be problematic with such a short connection time.
Good luck.
Posted: Tue Mar 09, 2010 3:06 am
by foxecho
JFK, home of the $10.50 value meal at the Wendys in T2......
you shouldn't have any issues at that time of night other than the crowds at the Connection gates.... have a great trip!
Andrew
JFK/MEM/MCI
PS also might want to check the Same Day Confirmed Availbility for the nonstop ATL PWM flights that day....$50 to switch to a N/S might be worth it to you.....
[Edited 2010-03-08 19:08:09]
Posted: Tue Mar 09, 2010 4:16 am
by MKP1013
Thank you all for the responses! I did not think about the same day confirmed on the non-stop - will def. consider that.
Posted: Tue Mar 09, 2010 5:02 am
by foxecho
let me add that on the same day confirmed that flights open up 3 hours before, and some days it pays to be on top of it, those seats go fast if they are even there....
0898 * ATL PWM 12Mar 10:12AM 12Mar 12:45PM CR9 (opens for Same day confirmed at 7:12a)
0863 * ATL PWM 12Mar 08:25PM 12Mar 10:57PM CR9 (opens for Same day confirmed at 5:25p)
Good luck!
Andrew
JFK/MEM/MCI
Posted: Wed Mar 10, 2010 12:39 am
by MKP1013
Quoting foxecho (Reply 6):
Hi Andrew -
Thanks for your help. I got excited about possibly getting on one of those non-stops, but I can't make the first flight, and my departure to JFK is at 5:30, so I will already be on board the plane before being able to try to get on the 8:25 - oh well!
Thanks again!
Posted: Wed Mar 10, 2010 3:39 am
by jflchantha
Quoting BMI727 (Reply 1):
Striking reality. I have been using the new Terminal 5 and the old terminal for years.
I did hear that Delta has a very old terminal but im not aware of this since I used to only use B6.
