AlnessW
Question About UA Boarding Groups
Tue May 03, 2011 1:06 am
In the next couple of months, my sister and I are flying PDX-DEN-BOS on UA. I am curious as to how our boarding groups will be assigned. UA uses the following grouping:
Zone 1 - First Class, Premier Executives, Star Alliance Gold, yadda yadda yadda...
Zone 2 - Windows
Zone 3 - Centers
Zone 4 - Aisles
We have reserved a window seat and an aisle seat on each flight, with an empty seat between us. I have a window on the PDX-DEN flight, while my sister has the aisle. On the DEN-BOS flight, it is the opposite.
I wold assume that I will be in Zone 2 and she will be in Zone 4 for for the PDX-DEN leg, and the same for our connection to BOS.
My question is this - Does UA assign seats purely by what seat you are in, or do they group passengers traveling together in one zone?
Thanks in advance!
genybustrvlr
RE: Question About UA Boarding Groups
Tue May 03, 2011 5:45 am
you can board with the lowest zone in your group.
Boarding order is actually as follows:
1st on the red carpet:
First
Business
Global Services, 1Ks (Me!)
Then on the ordinary line:
Premiere Executives / Star Gold
Group 1 (Premiers)
Now 75% of the plane is boarded if you're at a UA hub
Group 2 Window
Group 3 Middle
Group 4 Aisle
UA gate agents tend to take boarding very seriously and will open a can of whoop @$$ when someone tries to sneak in front of us elite fliers.
AlnessW
Tue May 03, 2011 6:24 am
Quoting genybustrvlr (Reply 1):
So if we have a Zone 2 pass and a Zone 4 pass we can both board in Zone 2 without a problem?
   Yes, looks like I forgot that the higher premiers board before Zone 1, and in their own lane.
You've got that right! One time I was unknowingly standing on the highly-respected red carpet while waiting at the gate and an agent quickly snapped at me and told me that I wasn't allowed there.
Also, off topic from seating but in regards to Premiers vs Economy - Are economy pax allowed to print boarding passes at the kiosks in the premier check-in lobby? Could one do this and go unnoticed?
genybustrvlr
Wed May 04, 2011 3:21 am
Quoting AlnessW (Reply 2):
yes, they announce this. I've had zone 4s walk on with me at premier exec time
I don't believe that there are dedicated check-in kiosks but I haven't used a paper boarding pass in well over a year now. I'd recommend that you use their mobile boarding pass option. A web link gets e-mailed to your phone and it opens in any mobile browser. Greener and cuts five minutes out of the curb to gate time.
AlnessW
Wed May 04, 2011 4:27 am
Quoting genybustrvlr (Reply 3):
Th reason why I ask is because I know that at some UA stations have kiosks in the premier check-in area that print on the nicer colored mag stripe stock, while the economy kiosks simply print on the white flimsy thermal paper.
To each his own... I will be using real paper boarding passes for this trip, as I want a physical document that I can save after the journey. I also do not have internet or email enabled on my phone. The list goes on.
We are checking bags on our trip - no need to try eliminating time at the check-in counters if we are going there to begin with.
roseflyer
Wed May 04, 2011 7:01 pm
UA actually prefers that if you are seated together that you board with the lowest number. Window/Middle/Aisle is in general faster getting people on, but if you are window/middle and in the same row you won't bother anyone. The purpose is to remove the "excuse me, can I get past you to get to my seat". They won't notice a difference with window, but you might end up with someone between you two which is normal with current load factors and the number of non-revs that fly UA nowadays.
If you go to one of the kiosks away from the desk, you can go anywhere that you'd like. However you are not allowed to queue in the premier lane to talk to the agent/check baggage. They usually will check your information to verify that you are premier.
AlnessW
Thu May 05, 2011 12:25 am
Quoting RoseFlyer (Reply 5):
Got it. Thanks for the clarification!
Do you know if there are premier kiosks located away from the counters in PDX?
I figured as much; I am simply looking for a place and/or kiosk to get the colored mag stripe stock. If all else fails, I suppose one could just ask the agent for colored stock.
VC10er
Thu May 05, 2011 2:48 am
If a person flies 200,000 miles or more a year, and most often full fare you will most likely be a Global Services pax. Who whenever enters the Red Carpet along with 1K etc they will stop a 100 person line to board them first. They often take the blank look off their faces and smile big and say "thank you Mr Clooney for your loyalty!"
I am GS and it's a small perk for loosing my life to flying. So don't get angry at the pax who "officially" gets to cut the line. They are tired!
To Most the Sky is The Limit, For me, the Sky is Home.
genybustrvlr
Thu May 05, 2011 2:49 am
Quoting AlnessW (Reply 4):
Ah, I see. On the rare occasion that I check a bag I do it curb side. I try to time my arrival so that I'm hitting security about 10 minutes before boarding and have no wasted time.
AlnessW
Thu May 05, 2011 11:32 pm
Quoting genybustrvlr (Reply 8):
Sounds like that's cutting it a little close if you're checking bags...
jgw787
Fri May 06, 2011 4:19 am
nah not really. Just depends on the airport. PDX has the hardstock and BOS has the flimsy ones.
AlnessW
Fri May 06, 2011 4:52 am
Quoting jgw787 (Reply 10):
Do the economy kiosks in PDX print on the mag stripe stock?
I do know that all of the economy kiosks in BOS do in fact print on the flimsy paper.
AlnessW
Sat May 07, 2011 6:56 pm
Also I wonder - Will I be flying on the real United Airlines on June 20 or will it be some completely new airline? I.E, will UA and CO have become one airline by then? I know UA will pick up CO's nonsensical seat numbering system on June 9, but when exactly will the airlines merge?
jgw787
Sat May 07, 2011 9:40 pm
Quoting AlnessW (Reply 11):
Well I don't know about all, but the ones at the premier line does. When I boarded most people had the mag strips.
AlnessW
Sun May 08, 2011 12:50 am
Quoting jgw787 (Reply 13):
Got it. Thanks. Can economy pax use the premier kiosks?
jgw787
Sun May 08, 2011 3:21 am
Quoting AlnessW (Reply 14):
If you buy Premier Travel on UA.com then yah.
AlnessW
Mon May 09, 2011 3:42 am
Quoting jgw787 (Reply 15):
I was actually wondering more about whether UA has premier kiosks located AWAY from the premier check-in counters:
But if you say that the standard economy kiosks in PDX print on the blue mag stripe stock, then that's all I need.
usflyer msp
Mon May 09, 2011 3:52 am
UA seating areas are going away as on 5.11.11. UA will board by rows just like CO does.
usflyer msp
Mon May 09, 2011 4:04 am
Quoting AlnessW (Reply 6):
Most UA check-in positions do not print on the coloured card stock. UA eliminated this several years ago. You will get cardstock but it will be all white and not have the magnetic stripe on the back.
jgw787
Mon May 09, 2011 4:24 am
Quoting AlnessW (Reply 16):
All UA check in desks are modified with a kiosk, so the desk is like a regular desk just with a kiosk in front of it. Just google easyCheckin
AlnessW
Wed May 11, 2011 1:22 am
Quoting usflyer msp (Reply 17):
Oh no!     Why get rid of the UA method? That said, I would like to know when these seat numbers will board:
23D, 23F (A320)
22A, 22C (752)
The row numbers should actually be 13 D&F, and 17 A&C, thanks to CO's nonsensical seat numbering.
Quoting usflyer msp (Reply 18):
   You have that correct. Most all "behind-the counter" printers used by the agent print on the material you mention. But I was talking about the self-service kiosks. In some airports, these machines print on the colored mag stripe stock, which is what I am looking for.
Quoting jgw787 (Reply 19):
I am familiar with this procedure, but some airports (BOS for instance) have banks of kiosks located away from the counters that are marked "Carry-On Only". You cannot check bags with an agent at these machines. I am curious if the have these banks of kiosks for Premiers in PDX. It sounds like they don't.
jgw787
Wed May 11, 2011 2:00 am
Quoting AlnessW (Reply 20):
Yah pdx doesnt have them.
AlnessW
Thu May 12, 2011 3:42 am
Quoting jgw787 (Reply 21):
That's what it was sounding like. Oh well, at least it seems the economy kiosks print on the blue stock!
Users browsing this forum: No registered users and 28 guests
