Eirules
50mins Enough Time To Connect In DEN?
Sat Aug 31, 2013 8:50 pm
Quick question. I'll be arriving into DEN with UA and departing 50minutes later with AC. Assuming there are no delays, is this enough time?
planeguy727
RE: 50mins Enough Time To Connect In DEN?
Sat Aug 31, 2013 10:11 pm
Plenty of time. You will be just fine.
Boston
Mon Sep 02, 2013 4:19 am
If everything is on time, you should be ok, but you will have to transfer from the B gates to the A gates. Not gonna lie, it's going to be a pretty tight connection since you have to transfer concourses. Luckily DEN has a super easy airport layout which makes navigating a breeze. Just make sure you get the train to A gates and not the C gates.
Users browsing this forum: No registered users and 35 guests
