UnitedFlyer
UA Business And First Class
Wed Dec 11, 2013 2:56 am
Next July, I will be flying MFR-DEN-EWR-YYT and then YYT-EWR-SFO-MFR. DEN-EWR and EWR to SFO is in First class and EWR-YYT and YYT to EWR is in Business class. What can I expect and what will be the difference between the First class and Business class products?
gigneil
RE: UA Business And First Class
Wed Dec 11, 2013 3:46 am
There will be no difference. The canada business class service, is like domestic first.
NS
UnitedFlyer
Wed Dec 11, 2013 3:50 am
Ah, sounds good! What kind of service can I expect?
MaverickM11
Wed Dec 11, 2013 4:00 am
This is a perfect example of how UA can overcomplicate anything; it's all domestic first, but why not call it 2-3-4 different things?
Quoting UnitedFlyer (Reply 2):
A veritable mountain of explus snackboxes
http://www.united.com/web/en-us/Cont.../travel/inflight/first/dining.aspx
I don't take responsibility at all
tyler81190
Wed Dec 11, 2013 4:02 am
Basically economy service, with real glasses, with an actual meal if you flight falls during a specified meal time, and is over 2 hours, depending on the aircraft...
srbmod
Wed Dec 11, 2013 11:15 am
Quoting MaverickM11 (Reply 3):
UA isn't the only one that does this. Delta is much the same way, as they have First Class, which is domestic-only, Business Class, which is applied to domestic flights that are a tag-on leg to an international flight (although more often than not, gate agents still refer to it as First Class).
roseflyer
Wed Dec 11, 2013 2:14 pm
Basically you get a meal and free drinks on all of your flights and a wider seat except on the Medford segments. You can do priority check in, although I doubt it makes much of a difference in small airports like MFR and YYT. No lounge access.
Quoting UnitedFlyer (Thread starter):
You will not get anything on MFR-DEN or SFO-MFR since those are CRJ routes without a first class cabin. DEN-EWR should provide a lunch. EWR-YYT should provide dinner. Likewise on the way back YYT-EWR should be breakfast. EWR-SFO always has a meal.
I don't think any of those flights would have snack boxes. They are all over 900 miles on mainline. I didn't think there were snackboxes on flights over 900 miles.
