LOWS
IAH Customs/Immigration
Sun Dec 14, 2014 11:02 am
Hello All!
I am flying in on LH 440 on Tuesday (16th Dec). It's been almost 14 years since I flew International into IAH.
My connecting time is 1hr 30m and I'm seated in 60C. How are my chances of making the connection? How bad is IAH Customs in Terminal D?
I will be using the US Citizens line at immigration.
[Edited 2014-12-14 03:03:48]
FriscoHeavy
RE: IAH Customs/Immigration
Sun Dec 14, 2014 4:52 pm
If you have Global Entry, no issue at all.
Whatever
Sun Dec 14, 2014 6:39 pm
Hi, I arrived on the same flight and used the non US line.we had an hour delay or so and there was no lane at all (we debarked among the first ones). We were lucky though as right after us a AF 77W docked and the area got pretty crowded.
I guess you should be fine. I found the recheck of the bag in IAH pretty effecient, as you just drop it on a belt after you passed immigration and they have a dedicated security check for transfer passengers. Much better thani i.e. in EWR where you need to go landside, take a train from B to C and clear general security there.
However IAH is pretty big,. If you are connecting to a regional plane departing in A or B you need to add a few minutes as you will need to take the terminal train. C and E is pretty close from D though and walkable.
TWA772LR
Mon Dec 15, 2014 2:20 am
Only an hour and a half? Fat chance. Not only is immigration long, but clearing TSA can be dicey as well. Honestly, I give you a 25% chance of making it if your flight is in Terminal B or A, 35% for Terminal C, and 40% for E.
God speed and good luck!
When wasn't America great?
AR385
Mon Dec 15, 2014 7:14 am
Quoting LOWS (Thread starter):
I´m not sure at what time does that flight arrive, but if it arrives at rush hour you may not cut it. IAH is among the best places in the US to connect arriving internationally, officers are courteous and customs is pretty relaxed. The problem is the amount of people during peak hrs. At those times, 1:30hr is below he minimum I would consider for a connection. At any other time, IAH is great.
Hope you make it.
LOWS
Mon Dec 15, 2014 12:53 pm
Quoting AR385 (Reply 4):
LH 440 arrives at 2pm. Apparently it is delayed today because it has to fly around Belgium (general strike).#
What times do you consider peak?
My connection is in C, and there are three more flights after mine (to OKC).
TWA772LR
Mon Dec 15, 2014 6:41 pm
Quoting LOWS (Reply 5):
Most of the European arrivals arrive within an hour-and-a-half yo two hours of each other. So from around 12:30-2:00pm. Couple that with UA Intl traffic arriving around the clock from 10am to 8pm, and you have some pretty long lines. If you have Global Entry, its not problem; the longest part of having GE is just waiting for your bag.
LOWS
Mon Dec 15, 2014 6:57 pm
Quoting TWA772LR (Reply 6):
Well, I'll look forward to finally getting a chance to try a UA A320 an hour and a half after my scheduled flight.
AR385
Mon Dec 15, 2014 7:16 pm
That´s peak. If you are in 60C you should consider asking the FA to let you move as forward as possible before landing so you can bolt out among the first. Although LH holds everybody for the F passengers to deplane first. Other than that, there´s not much you can do. If the lines are huge sometimes some ICE agents walk the line, try and tell them of your situation and they may let you move forward. Sometimes there are also UA employees. Try them too.
Good luck.
Mon Dec 15, 2014 7:36 pm
Quoting AR385 (Reply 8):
60C is as close to the exit he can be.
http://www.seatguru.com/airlines/Lufthansa/Lufthansa_Airbus_A380.php
777Jet
Tue Dec 16, 2014 12:29 am
I've only entered the USA at IAH once, a few months ago on a CA flight but as a non-US resident. I was in the first row of Y to get off as quick as possible. When we reached the immigration hall, it was basically empty and there were 4 empty counters to pick from - all of the others just had one or two pax at each! I couldn't believe it as I was prepared for a 2hr plus marathon... I guess our flight just hit the jackpot when it came to arrival timing. The bags took 20 mins to arrive though and then another 5 mins in the final queue before exiting. I guess from the time we stepped off the plane until the time we were curbside was about 40mins total - as that was with zero queus at immigration. I have read IAH terminal D can take hours if your plane arrives at the wrong time...
[Edited 2014-12-15 16:33:04]
[Edited 2014-12-15 16:34:51]
TWA772LR
Tue Dec 16, 2014 1:49 am
Quoting B747forever (Reply 9):
No. Row 50 is the closest he can be. LH uses the L1 door in IAH.
TWA772LR
Tue Dec 16, 2014 3:52 am
Quoting 777Jet (Reply 10):
CA has a great arrival time into IAH. It is after the European rush, but before the TK and ME rush. Like I said earlier, the only thing you'd have to worry about is the UA rush. (I think the north side of the FIS building is for UA arrivals and US residents/citizens and the south side is for all foreign flag non-US/Canada customers.
LOWS
Thu Dec 18, 2014 3:41 pm
Just a brief update:
We got in a few minutes late, but the bag delivery was atrocious (my bag arrived at 14:45). I was also selected by a lovely little beagle for an additional customs inspection. They took a small packet of Landjäger
By the time I got to the TSA check, it was a total mess. At about 15:40, I finally cleared the checkpoint and made it to the Train. But, this is where something strange happened:
In the train, a United Pilot asked me how I was doing, what I was up to, where I was going. We had a really pleasant, if short conversation. And at the end, he said "thanks for flying with us today!"
In fact, every interaction I had with UA crew on Tuesday was really quite pleasant. I was totally shocked. The customer service people were really helpful.
I ended up on the UA A320 at 5.50pm, the UAx at 3:30 that I was booked on originally, was delayed almost two hours.
So, in closing, great job, United. I'm impressed.
Thu Dec 18, 2014 4:08 pm
Quoting TWA772LR (Reply 11):
So they dont have those 3 jetway gates at IAH?
777Jet
Fri Dec 19, 2014 1:39 am
Quoting LOWS (Reply 13):
Great to hear!
How cool would it have been if the pilot said: "thanks for flying the friendly skies"
LOWS
Fri Dec 19, 2014 3:06 am
Quoting 777Jet (Reply 15):
I think the FAs on IAH-OKC said it about 50 times...
Quoting B747forever (Reply 14):
I guess not.
TWA772LR
Fri Dec 19, 2014 5:27 am
Nope. The new A380 gate D9 only has one bridge for each deck also.
Its because you were in Houston, we are nice unlike our neighbors up I-45.
But I'm glad you had a good experience.
Fri Dec 19, 2014 7:47 am
Quoting TWA772LR (Reply 17):
Got it, thanks.
Users browsing this forum: AirStudentLboro, michael478, WAC and 27 guests
