Quoting flyTPA (Reply 1): In MUC you can go to Airbräu. It is a brewery, beer garden and restaurant in the Munich Airport Center shopping area just outside of Terminal 2 (it can be reached from Terminal 1 as well). http://www.munich-airport.de/en/micr.../speisekarte/fruehstueckskarte.pdf Have a Weisswurst, Pretzel and a Weissbier. A Bavarian classic. |
Quoting Trijetsonly (Reply 2): In FRA I recommend the McDonald's in Terminal 2 right next to the observation platform. It has a great view over the tarmac and runways 25L and 25C. |
Quoting teme82 (Reply 3): They closed that observation platform for renovation opening spring 2015. So I need to check if it's open or not. |
Quoting TurkishWings (Reply 5): There is also a casino at FRA if that is your thing. |
Quoting reifel (Reply 10): What airline will you be flying in FRA? If it's BA, you would use Terminal 2. After passport control head left and you will find a japanese restaurant (as japanese as you can get for German standards at least) called Mosch Mosch. There is the same restaurant in the Terminal 1 A Schengen pier, pretty at the end near Gate A24 or so. Decently priced for an airport and acceptable food in my opinion. I would go for that. |
Quoting ALAfly (Reply 11): |
Quoting teme82 (Reply 17): If some one have info about the non-schengen side of FRA >T1. I would like to know is it any good for plane spotting etc... |
Quoting reifel (Reply 18): So basically it depends where you are flying from. |
Quoting reifel (Reply 18): If it's really about plane spotting, even if you remain air side only, Frankfurt is pretty good no matter where you are in T1 non schengen. |
