afcjets
RE: Two Closest Airports Served By The Same Airlin
Thu Dec 24, 2015 5:26 am
Don't you love when people repeat stuff mentioned 10,000 times already? I would like to point out that several airlines fly to LGA and JFK, SFO/OAK and that LAX/SNA/LGB/BUR/ONT are LA metro area airports.
[Edited 2015-12-23 21:28:06]
Andy33
Thu Dec 24, 2015 6:16 am
Quoting RebelDJ (Reply 51):
Thanks - some great replies here. I was looking for close airports that are served by the same airline - from the same origin (I realise now I left that bit out)!
OK, to define airport pairs served by the same airlines from the same departure point: from my previous posts: LPL and MAN both served from DUB by EI; BHX and EMA, both served from BHD by BE.
Should we start on adjacent Greek island airports? obviously we can't measure road mileage between them, have to be as the ferry sails. I can think of quite a few, all served from ATH by OA/A3, but might not be what RebelDJ meant.
migair54
Thu Dec 24, 2015 7:42 am
DWC and DXB, TK and QR serve both.
QR also serve DAR and ZNZ, only 34nm apart.
Few airlines on LHR, LGW and LCY.
PVG and SHA.
ICN and Gimpo.
BKK and DMG.
Does anyone serve SEA, Tacoma and Victoria??
GRJGeorge
Thu Dec 24, 2015 8:05 am
Airlink (SA) serve Pretoria (PRY), 29nm from JNB. While JNB is their obvious main hub, they don't serve JNB-CPT route which is left to bigger brother SAA and loads others, while Airlink do exclusively PRY-CPT flights at the moment.
Both Kulula and Mango serve JNB and Lanseria (HLA), which is 21nm apart.
Many probably don't know that JNB actually isn't under Johannesburg Metropolitan jurisdiction, but under the East Rand metropole of Ekhuruleni...while HLA also falls under a different municipality.
Technically SAA serve all 3 airports as they codeshare on Airlink flights on PRY-CPT and also Mango flights in to HLA.
JNB-HLA 21nm
HLA-PRY 23nm
PRY-JNB 29nm
Another airport not too far away from these are Pilansberg/SunCity (NTY), 55nm from HLA...there is actually a service by SA Express JNB-NTY (75nm) on DH4/CR2 2x weekly...only other service is CPT-NTY
Other destinations served close to each other
DUR-Pietermaritzburg (PZB) 38nm by Airlink
Nelspruit (MQP)-Skukuza (SZK) 36nm by Airlink
George (GRJ)-PlettenbergBay (PBZ) 48nm by CemAir
ilari
Thu Dec 24, 2015 8:29 am
HKG and CAN are some 180km apart but still close-ish. Probably the Guangdong province industry attracts airlines to serve both.
flyiguy
Thu Dec 24, 2015 8:37 am
DAL-DFW , SFO-OAK, LGA-EWR are all 11 miles... They are closest airport pairs I could find that are served by the same airline...The only one that is closer is TPA-PIE in Florida @ 10 miles, but I don't think there is an airline that serves both.
FLY
The opinions I post are of mine and mine alone, not of the airline I work for.
gatibosgru
Thu Dec 24, 2015 9:10 am
Another one to add in Brazil
CNF & PLU - 15 miles
@DadCelo
jsfr
Thu Dec 24, 2015 12:49 pm
Air France has scheduled flights in their timetable to both
BSL - Basel and
MLH - Mulhouse
Two airports, two countries, two ICAO codes, they are separated by a corridor in the same buildinng and share the same runway....
Distance about 10metres, does that count?
kelual
Thu Dec 24, 2015 1:09 pm
In Spain SCQ and LCG are 55km apart, 26 min ride on high speed train
lancelot07
Thu Dec 24, 2015 1:13 pm
Quoting jsfr (Reply 107):
iirc it is one airport with 2 exits
AirGAbon
Thu Dec 24, 2015 1:23 pm
CDG and ORY served both by AF, BA, AZ, IB, EasyJet, UX, AH, AT, VY
As said above, FIH (Kinshasa) and Brazzaville (BZV) less than 10Km separated by the Congo River, both served by:
AF, ET, KQ, SA, Air Cote d'Ivoire, Asky.
BrianDromey
Thu Dec 24, 2015 1:47 pm
Its an interesting conversation, for the purposes of it I will disregard airports considered to serve the same metropolitan area.
EI serve both MAN and LPL from DUB. MAN up to 6 times a day (A320 AT7 mix) , LPL 3 times a day (A320). FR also serve both cities at similar frequency (All 738, of course!). The two airports are 30 miles apart by road, less as the crow flies.
cschleic
Thu Dec 24, 2015 2:54 pm
Quoting Aeroflot777 (Reply 3):
Now of course, this is driving distance. SFO and OAK are much closer to each other than that if drawn a straight line across the water.
And at one time long ago, UA actually had scheduled flights between SFO and OAK. It was probably positioning to move them from the maintenance base at OAK at the time, but was kind of funny to see it in the timetable, listed under San Francisco to San Francisco.
jsfr
Thu Dec 24, 2015 4:10 pm
Quoting lancelot07 (Reply 109):
kind of.
Different airport codes though, and (more importantly for me) you get different mileage depending which you fly to...
If you fly to BSL it is an international flight, if you fly to MLH it is a domestic flight (and normally a fair bit cheaper).
floridaflyboy
Thu Dec 24, 2015 4:59 pm
Quoting ScottB (Reply 31):
IIRC CO/CO Express simultaneously served both EFD & HOU briefly and those two airports are 8 miles/12 km apart.
Quoting RWA380 (Reply 94):
IIRC, CO used to serve EFD from IAH with DC-9-10's back in the day.
Yep, even more recently, they had E145s between EFD and IAH. I always thought it would be fun to fly that one just to have a boarding pass that shows Houston to Houston. Yep, I'm easily entertained.
Even looks like at one point they branded their HOU-IAH service as Continental's Houston Proud Express.
Can anyone else think of any other flights between two airports of the same city?
[Edited 2015-12-24 09:04:43]
Good goes around!
afterburner
Thu Dec 24, 2015 5:09 pm
CGK and HLP are about 30 km apart (straight line). Batik Air and Citilink serve both.
Q
Thu Dec 24, 2015 5:14 pm
In late 1980's Southwest closest DET and DTW. I just had flight to pick some passengers stranded up to MDW from DTW due snowing day. I was in DET. Southwest flew DET-DTW in 9 minutes hop then pick up then flew to MDW. It was fun trip.
Q
czbbflier
Thu Dec 24, 2015 6:48 pm
This isn't going to win any records but it is notable in this area:
Vancouver-YVR and Abbotsford-YXX are both served by Westjet and Air Canada.
59.91 km apart runway threshold to threshold as the crow flies (71.3 km by car).
YXX is way, way more convenient for folks in the eastern reaches of the region. Plus flying out of YXX helps stem the bleeding to Bellingham-BLI in the US which is way closer- and depending on the destination, much cheaper too- just 26 km away as the crow flies, 39 km by car (plus the border crossing).
As a result, rationalization is not going to see this pair of close neighbours see an end. Indeed, if AC goes for the C-Series it's quite possible that YXX will see much more jet service.
neutrino
Thu Dec 24, 2015 6:59 pm
Right, on paper (for the travelers), its two different airports.
Physically, it's just a single one with two different exits as you said.
Many years ago, I was in Basle on a factory visit and as part of a quick city show around, was brought over to the airport by my host to see it as according to him its an oddity and only one of tiny handful in the world (told me another he know of is Geneva) where a person can fly into one airport in two countries. I was told it's totally on French soil right on the border with Switzerland. They just share the costs and operate jointly. I was also told that at the terminal, one can choose which country's immigration to depart from (can anyone confirm that)?
The airport have not two but three IATA codes; BSL (Swiss), MLH ( French) and EAP (neutral).
Potestatem obscuri lateris nescitis
RWA380
Thu Dec 24, 2015 9:08 pm
Quoting migair54 (Reply 102):
Tacoma TIW no longer has commercial service, but at one time Hughes Airwest flew PDX-AST-HQM-OLM-TIW-SEA on F-27's.
Quoting floridaflyboy (Reply 114):
At one time Portlands airport was on Swan Island, at some point in the late 20's the airport was relocated to it's current location on the Columbia River, There was a short time that carriers served both places with hops between, here is one example.
http://www.timetableimages.com/ttimages/wcat30a.htm
707 717 720 727-1/2 737-1/2/3/4/5/6/7/8/9 747-1/2/3/4 757-2/3 767-2/3/4 777-2/3 DC8 DC9 MD80/2/7/8 D10-1/3/4 M11 L10-1/2/5 A300/310/320
AA AC AQ AS BA BD BN CO CS DL EA EZ HA HG HP KL KN MP MW NK NW OZ PA PS QX RC RH RW SA TG TW UA US VS WA WC WN WP YS 8M
directorguy
Thu Dec 24, 2015 11:16 pm
BEY and DAM are very close, at 66m/106km apart.
They're so close that there are no direct BEY-DAM flights, and I doubt there have ever been. Until a few years ago, going from city to city was very easy, with a routine border crossing with minimal checks for Syrian or Lebanese citizens (an ID card was enough). Took 60-90 minutes each way I think.
Both airports are to some extent interchangeable. During the Lebanese Civil War, most Lebanon-bound pax would have flown in through DAM. Today, the situation is reversed, and anyone wanting to visit Syria, or leave Syria, will probably go through BEY airport, as there are more flights/airlines.
During peacetime, many airlines flew into both cities, as there was always sufficient demand to both. BEY had a slight edge though in terms of popularity, and also had the stronger national airline (MEA).
AMM is also relatively close, around 190km to DAM and 237km to BEY.
drerx7
Thu Dec 24, 2015 11:44 pm
I flew HOU-IAH and EFD-IAH many times. EFD was great because it was quick on and off - free parking. IIRC the last foray on the HOU-IAH routes involve 737s as a way to get a little revenue I suppose on the usual ferry flights over to the HOU maintenance base.
HOUSTON, TEXAS
vv701
Fri Dec 25, 2015 12:20 am
Several replies above have mentioned the 1.7 mile (2.8 km) Westray / Papa Westray flights in the Orkney Islands. A feature of these flights flown by a Loganair Islandair is the prime market these flights serve.
On Days 1 through 5 the morning flight that operates Kirkwall - Westray - Papa Westray - Kirkwall is scheduled to depart Westray at 08:56 GMT (08:46 on Day 1) and arrive Papa Westray two minutes later. On weekdays the afternoon flight operates in the opposite direction, Kirkwall - Papa Westray - Westray - Kirkwall. It is scheduled to depart from Papa Westray at 15:21 GMT. The timing and direction of these two flights is so that students resident on Westray can attend the Secondary (High) School on Papa Westray.
There are no flights on Day 6 and just an afternoon flight on Day 7.
This raises a question. Is this service the only school-run flight that is also bookable by the general public?
dcajet
Fri Dec 25, 2015 12:34 am
EZE and AEP are 17.5 miles from each other and are both hubs for AR/AU and both are also served by 4M, LA, JJ and G3.
mandala499
Fri Dec 25, 2015 2:04 am
CGK and HLP in Jakarta are 30km apart. Both served by Citilink and Batik Air.
JOG and SOC, are 47km apart. Both served by Garuda, Lion, Batik, Sriwijaya, Citilink, Air Asia, and probably some other...
Quoting neutrino (Reply 38):
As the crow flies, Batam's Hang Nadim is much closer to Changi Airport. About 20+km versus around 40km (estimates).
And there's more airlines flying into both SIN and BTH as well. Offhand; Batik Air, Garuda Indonesia, Lion Air and Malindo Air; at least
They are 30km apart...
Q
Fri Dec 25, 2015 5:30 am
PIE and TPA are pretty closer. Not sure about same airlines. Allegiant may be charter flight in TPA once a while.
Q
[Edited 2015-12-24 21:33:22]
Q
Fri Dec 25, 2015 5:31 am
TTN and PHL are closer, too. Frontier Airlines both serves.
Q
[Edited 2015-12-24 21:32:16]
AirGAbon
Fri Dec 25, 2015 9:44 am
Also forgot in Saint Marteen: SXM on the Dutch side and SFG on the French side of the island., both served by TX!
DavidByrne
Fri Dec 25, 2015 10:06 am
Several here from New Zealand:
WLG and PPQ are both served from AKL by Air NZ (WLG by 320, PPQ by DH3) and currently also both are served from CHC, though CHC-PPQ is to cease. Distance 49 km.
Also, GBZ (Great Barrier Island) is served by both Barrier Air and FlyMySky from both AKL and NZNE (North Shore). We're talking about the tiny end of airline operations there, though! Think BNI and Cessna Grand Caravan and you'll get the picture. We're talking only 41 km in this case.
Elsewhere in NZ,
* TRG and ROT are served by Air NZ from AKL, WLG and CHC, and they're just 50 km apart.
* BHE and NSN are just 60 km apart, both served direct from AKL, WLG and CHC by Air NZ.
* WAG and PMR are just 64 km apart, both served direct from AKL by Air NZ.
* And WRE and KKE are just 70 km apart, both served direct from AKL by Air NZ.
Until recently, also, ZQN and WKA (50 km apart) were served by Air NZ from CHC
. . . and there are several more airport pairs in NZ between 70 and 90 km apart served from the same point by Air NZ. And, as has been pointed out by another poster, OOL, BNE and MCY in Australia are all served direct from AKL by Air NZ and they're only around 160 km from north to south.
This is not my beautiful house . . . This is not my beautiful wife
ha763
Fri Dec 25, 2015 11:32 am
Mokulele flies from HNL and JRF (Kalaeloa Airport) on Oahu to JHM (Kapalua Airport) and MKK (Molokai Airport). Straight line from terminal to terminal is roughly 9.6mi/15.45km. Driving distance roughly 18mi/29km.
Adipasquale
Fri Dec 25, 2015 1:39 pm
I have a couple I'm not sure were mentioned. AEP and EZE are 51 km apart driving, and both served by many of the same airlines. Also, ELM and ITH are a shade over 60 km driving distance and both are served by DL, AA, UA with regional equipment.
DH8A DH8B CR1 CR2 CR7 CR9 E45 E70 E75 E90 D93 M88 319 320 321 333 343 712 732 733 734 73G 738 739 744 752 753 762 763 77L 77W
Viper911
Fri Dec 25, 2015 1:55 pm
6H and IZ both operate domestically from TLV and SDV, which are 9miles appart (16KM)
Viper911
BasilFawlty
Fri Dec 25, 2015 2:33 pm
Quoting Directorguy (Reply 120):
RB has been flying between DAM and BEY for ages and still do at the moment, it's actually one of the few remaining routes they have currently.
These days the route is also flown by 6Q
[Edited 2015-12-25 06:34:01]
[Edited 2015-12-25 06:34:15]
'Every year donkeys and mules kill more people than plane crashes'
ua900
Fri Dec 25, 2015 9:36 pm
THF and TXL were both served by LH for years, 20km drive and maybe 14km straight line.
As others have said. Bay Area, LA, NY, Chicago, DC, South Florida all have airports served by the same carrier very close to each other.
Places like VIS vs FAT also come to mind where the local VIS equivalent tends to go the way of OXR or CLD in this day and age.
And once you add cargo flights you get places you can get even closer than SFO - OAK I bet.
2020: DEN | DFW | EWR | FRA | IAH | LAX | MCO | MUC | ORD | PTY | SFO | TXL
TPAfan
Fri Dec 25, 2015 11:17 pm
Quoting Q (Reply 125):
TPA-PIE driving distance is just over 14 miles and Silver Airways was destined to serve both this year but pulled out of PIE prior to its inaugural flight.
Viscount724
Sat Dec 26, 2015 1:54 am
AC (including AC Express) serve:
YVR and YYJ, 39mi, 34nm, 63km
YVR and YCD, 33mi, 28nm, 52km
I think YVR-YCD is AC's shortest route (Jazz Dash 8s). I doubt AC would be operating YVR-YYJ or YVR-YCD if YYJ and YCD weren't on an island requiring a time-consuming ferry trip otherwise.
AC/AC Express also serve the following airports (but no service between them):
YYZ and YTZ, 12mi, 11nm, 20km (as the crow flies, about 24km by road).
YLW and YYF, 36mi, 31nm, 57km.
dstc47
Sat Dec 26, 2015 9:46 am
For a time, until the M50 motorway was completed, there was an S 61 service between LHR and LGW, operated by BCal helicopters for the then BAA.
afcjets
Sat Dec 26, 2015 7:09 pm
Has any airline ever offered DCA-IAD?
Viscount724
Sat Dec 26, 2015 10:47 pm
Quoting afcjets (Reply 137):
At least one major carrier once operated DCA-IAD-somewhere on the west coast to get around the DCA perimeter rule. I don't think they sold traffic on the DCA-IAD sector.
OzarkD9S
Sat Dec 26, 2015 11:51 pm
Braniff 2 did on a DCA-IAD-DFW routing. Briefly.
http://www.departedflights.com/BN030184.html
"True, I talk of dreams,
Which are the children of an idle brain." -Mercutio
DocLightning
Mon Dec 28, 2015 1:58 am
How about this? http://www.amusingplanet.com/2013/08...shortest-commercial-flight-is.html
Not only does Logan Air serve both airports, but it flies between them. Now, this does raise the question of why a bridge hasn't been built across such a shallow, narrow channel...
-Doc Lightning-
-Carl Sagan
KBUF
Mon Dec 28, 2015 2:50 am
BGM-ITH: 31mi
ITH-ELM: 32mi
ITH-SYR: 46mi
ELM-BGM: 47mi
AA, DL, and UA serve all four.
Additionally, BUF and ROC are 55 miles apart, and both are served by AA, DL, B6, WN, and UA.
"Starting today, the Buffalo Sabres' reason for existence will be to win a Stanley Cup."-Terry Pegula, February 22, 2011
GRJGeorge
Mon Dec 28, 2015 3:23 pm
Victoria Falls area:
Victoria Falls Airport (VFA), Zimbabwe and Livingstone (LVI), Zambia is 16nm apart, both served by SAA and BA/Comair from JNB.
In the off-peak seasons BA sometimes combine the flights from JNB as one, JNB-VFA-LVI-JNB, doing the 16nm hop across the falls.
Kasane (BBK), Botswana 42nm west of LVI, both served by Airlink (SA) as well.
SAA also serve both FIH and BZV, however not combined like ET, each seperate.
[Edited 2015-12-28 07:27:18]
Viscount724
Mon Dec 28, 2015 8:38 pm
Quoting DocLightning (Reply 140):
Very expensive for a combined population of around 700, and less than 100 on Papa Westray.
ACDC8
Mon Dec 28, 2015 9:02 pm
Albian (JHL/CAL4) and Horizon (HZP/CYNR) are only 15 miles apart and both served by Canadian North. Firebag (YFI/CFG6) is also only 17 miles away from Albian and 28 miles from Horizon and all 3 are served by North Cariboo Air
A Grumpy German Is A Sauerkraut
Viscount724
Thu Dec 31, 2015 2:56 am
Quoting ACDC8 (Reply 144):
However those are charters for the oil sands companies, not scheduled flights. They may operate to a schedule but they're still not bookable like regular scheduled flights.
PlymSpotter
Thu Dec 31, 2015 11:57 pm
Kirkja and Hattarvik - about 1 mile, both served by Atlantic Airways helicopter from Klaksvik.
SDV and TLV - 9 miles, both served by Arkia and Israir from Eilat and possible others.
CWL and BRS - 27 miles, both served by KLM from AMS, plus others.
Tresco Heliport and St Mary's - 2.7 miles, both served by British International from Penzance until a couple of years ago.
The three Aaran Island airports are about 3 miles from each other, all served separately from the mainland by Aer Aaran Islands.
Quoting neutrino (Reply 118):
GVA is an oddball. There is a long 'finger' of France which pokes into Switzerland. To reach the French terminal you drive down this, under the runway which is Swiss territory.
SEAIR operated from MNL to CRK in the Philippines. Also there are lots of intra-London positioning flights on business jets which can be picked up commercially.
I almost booked one of these back in 2007, as BasilFawlty has mentioned they are still operated.
Quoting dstc47 (Reply 136):
M25 perhaps?
Dan
ACDC8
Mon Jan 04, 2016 3:10 pm
Quoting Viscount724 (Reply 145):
I wasn't aware that the OP set specific standards that required our posts to only list commercial services. Perhaps I felt that some members not familiar with the area would find it interesting having 3 airports in very close proximity, each having services that rival many Canadian commercial airports in frequency.
KGRB
Mon Jan 04, 2016 8:16 pm
Quoting B727skyguy (Reply 61):
ATW and GRB are 31.1 miles/50km apart. DL serves both.
ATW and GRB are also currently served by United Express, with ERJ-145 and CRJ-200 service to ORD. Northwest also served both airports prior to the DL merger.
First flight: NW DC-10 MKE-MSP December 1996
Most recent flight: DL/OO CRJ-900 ATL-GRB April 2019
nicode
Mon Jan 04, 2016 10:06 pm
What about Iguassu Falls ? (IGU and IGR 10 miles away)
Users browsing this forum: Mike2k and 132 guests
