Starlionblue wrote:IIRC, outlined exits are only a requirement for airliners, not private aircraft.
SEPilot wrote:Starlionblue wrote:IIRC, outlined exits are only a requirement for airliners, not private aircraft.
This is correct. Trump's plane is most likely flown under Part 91, which is what most Cessnas and Pipers fly under. The main requirement is that it is not carrying people or cargo for hire. Airliners usually fly under Part 121, which deals with scheduled passenger service. It is how the plane is used, not its design, which controls what rules apply to it. There are huge differences; for instance in Part 121 all manufacturers' recommendations essentially have the force of law-under Part 91 they are only advisory unless they get elevated to an AD. ADs apply to all planes, regardless of their use, but service bulletins and other manufacturers' recommendations are only mandatory on planes used commercially. Part 135 applies to charter services and I believe air freight; maintenance requirements are essentially the same as 121. Planes used commercially under Part 91 (rentals and other commercial uses) are subject to stricter maintenance requirements than privately owned and used aircraft, but Trump's plane again does not qualify. His plane, since he is not using it for any commercial purpose (using it for his own businesses does not count, nor does using it in his own campaign) is only subject to the same requirements as my 182 when I owned it. He does not have to adhere to any time limits on any part unless it is subject to an AD; a mechanic merely has to certify it is airworthy. It does have to pass an annual inspection, however, and Boeing will establish the standards which must be followed.
chornedsnorkack wrote:What shall happen to the applicable regulations when, on 20th of January 2017, the said 757 turns into Executive One?
BravoOne wrote:SEPilot wrote:Starlionblue wrote:IIRC, outlined exits are only a requirement for airliners, not private aircraft.
Actually this airplane is flown under Part 125m not 91.
BravoOne wrote:The Trump 757 is a very nice airplane but no where worth the 100 million he has claimed in the past.
chornedsnorkack wrote:How would you compute its cost?
chornedsnorkack wrote:chornedsnorkack wrote:How would you compute its cost?
Found a decent review:
http://www.bjtonline.com/business-jet-n ... ings-757-0
SEPilot wrote:IIRC, outlined exits are only a requirement for airliners, not private aircraft.
rcair1 wrote:SEPilot wrote:IIRC, outlined exits are only a requirement for airliners, not private aircraft.
