LeCoqFrancais wrote:Student pilots are taught very early on to recognize that when an airplane approaches its minimum flying speed, the airflow over the wing will begin to separate or break down, creating turbulence over the tail. The degradation of lift and the associated turbulence over the tail causes the airplane to buffet and alert the pilot to a deteriorating and dangerous situation. The recovery is rather basic – lower the nose some, apply full power to the engine and let the airplane fly out of it. As it accelerates, the buffeting will end and the aircraft will safely regain both flight and controllability.
In the 1930’s, military and large civilian airplanes were being equipped with supercharged and turbocharged engines. These engines enabled the planes to fly higher and faster than airplanes with normal engines. However, these “boosted” engines required a pilot with a delicate hand on the throttles. Whereas a normally aspirated engine could run at full throttle continuously without much more than some added wear, the supercharged and turbocharged engines would run beyond the normal power limits creating excessive heat which, in minutes, would damage the engine. Only when the situation was critical could a competent pilot consider “firewalling” the throttles by pushing them to the stops and exceeding the manufacturers’ limits.
http://www.nycaviation.com/2014/10/disa ... 8GSYbWi3bF--
What is everybodies opinion on this?
While I'm not an ATP and have never flown big jets (any jets), my understanding is that stall recovery in a large airline transport aircraft is not as simple as the small GA aircraft most students stall and spin (like I did). This is even more important at high altitude - where a recovery is much more difficult and different.
A few reasons
- Under-slung engines create a upward nose moment when 'firewalled' - you push the throttle forward and the aircraft will pitch up. I believe that at altitude that moment can be greater than elevator authority to pitch down, or will require nose down trim in addition to nose down elevator.
- A swept wing stalls in a very different fashion with the most rear part stalling first. That also creates a nose up moment.
- At high altitude the margins between overspeed and stall are very small - and engines don't have as much power - meaning recovery at high altitude is harder.
Check out this video from Aviation Week on a simulated full stall in a 737. Notice how the, as the pilot pitches up out of the dive he re-stalls the wing several times. Pitch control is critical. (Start about 3:30 in the video).
https://youtu.be/zCJco59tqoQNote - the issue here is why the FAA is mandating more training on recovery from unusual attitudes and why airlines are starting to do it. The video above is a simulator certified for this type of training.
WIederling wrote:Stall: not all types exibit benign stall behaviour. That is the reason why "artificial stall behaviour" aka "stick shaker" was introduced.
diesels and turbocharged machines are suicide designs.
i.e. uncontrolled the engine will over rev and destruct.
In diesel engines this is fixed via a governor. ( thus with a basic diesel engine the throttle controls rpm in first order and not power)
in turbocharged engines you need to limit boost pressure otherwise the increase in energetic exhaust will increase boost pressure for even more and hotter exhaust in an accelerating spiral until things separate
[/quote]
That is correct, the approach from the airlines and pilots have been "Avoid the stall." There has been little emphasis or training on recovery because "you never get there". As we all know, that is not the case, and changes in training requirements reflect that.
WIederling wrote:diesels and turbocharged machines are suicide designs.
This cracked me up. Never thought of them as "suicide designs", but you have a good point.
I used to have a tractor with a Detroit Diesel 3-73 engine (3 cylinders, each 73 cubic inches). The engine was a supercharged 2-cycle diesel design and it had an 'emergency cutoff' in case it over-ran. That cutoff was a spring loaded plate that slammed against the air intake when you pulled a release cable. Instantly shut down the engine.
That engine was a riot. Because it was a 2-cycle it fired every rotation and sounded like it was screaming along at twice the speed of normal 4-cycle engines. It just howled along.
This type of Detroit Diesel was quite common for many years - but rare now. They were specified in terms of number of cylinders and size of each cylinder and also the configuration, inline, flat, V
Here is a video of a Detroit Diesel 6V92 powered truck. 6 cyliners, V-configuration, 92 cubic inches per cylinder. That's a big engine and because it is 2 cycle, produces lots of power.
https://youtu.be/m4Vw9v0khIY
