KTPAFlyer wrote:Hello A.net,
But the question I have is how exactly how did he recover?
https://youtu.be/bnBr3enzW1I
Stitch wrote:Maybe the pilot wasn't an incompetent idiot and he knew what that bird could do and operated it within it's performance envelope?
Revelation wrote:Stitch wrote:Maybe the pilot wasn't an incompetent idiot and he knew what that bird could do and operated it within it's performance envelope?
True, but maybe also he was an idiot pushing a very expensive piece of equipment to the edges of its performance envelope for no particularly good reason.
Just sayin'...
flyinTLow wrote:Not taking any side here, but one thing everyone here is missing: a stall has nothing to do with speed. It is only dependant on the angle of attack. And that again is not only dependant on the pitch.
flyinTLow wrote:Not taking any side here, but one thing everyone here is missing: a stall has nothing to do with speed. It is only dependant on the angle of attack. And that again is not only dependant on the pitch. Good examppe for that is AF447. In the deep stall, their pitch was fairly normal, but the angle of attack was around 40 degrees at some point if I am not mistaking. A big influence is also the position if zhe ailerons which, to make it simple, also increases the angle of attack of that particular portion of the wing significantly. And then don't forget the roll spoilers which do their part in disturbing the airflow over the wing. I am not saying he stalled at some point, but I am fairly positive at least one part of either the wings at some point reached a very critical angle of attack.
The 747, just like all other airplanes, requires an airflow over the wing to fly. A fighter can fly vertically with basically just its thrust as lift, but the 747, no matter what the lift to weight ratio, cannot unless you put it almost vertically, especially not that close to the ground.
So even though I am not saying he stalled, I am more with the thread starter KTPAFlyer here that he might habe been a little overconfident on his flying there!
flyinTLow
sandyb123 wrote:flyinTLow wrote:Not taking any side here, but one thing everyone here is missing: a stall has nothing to do with speed. It is only dependant on the angle of attack. And that again is not only dependant on the pitch.
That really isn't very accurate. An aerodynamic stall has everything to do with the speed of the lift surfaces through the air surrounding them. Speed = lift. Agree that pitch is part of the picture, but only if the pitch angle is so extreme that the forward momentum (provided by engines) is unable to maintain speed. So it comes back to relevant airspeed (lift).
Sandyb123
rcair1 wrote:you cannot tell from the video what the angle of attack was
Sandyb123
CaptainKramer wrote:Wasn't the Captain of a Cathay Pacific, B777-300ER on her delivery flight, sacked after performing, a low level, high speed, flypast of the Tower/Runway after departure from Paine Field? IIRC there was no briefing, or clearance by the Tower, a totally spontaneous/stupid act. I think the flyby was caught on camera as well.
rcair1 wrote:It is overstating it to say a stall has "nothing to do with speed."
sandyb123 wrote:Agree that pitch is part of the picture, but only if the pitch angle is so extreme that the forward momentum (provided by engines) is unable to maintain speed.
timz wrote:Can't tell accurate to a degree, you mean. But we can see the aircraft is pointed... probably less than 20 deg above horizontal, and its climb angle is likely to be... what, 5 deg?
Florianopolis wrote:Assuming he was empty and had ~200k lbs of gas for a flight to Luxembourg, he weighed 670k or 700k lbs, tops.
Let's compare that 747 to an F-35...
That 747:
Thrust/Weight: 0.4
Wing Loading: 117 lbs/sqft
F-35 at MTOW:
Thrust/Weight: 0.6
Wing Loading: 152 lbs/sqft
So, basically, that 747 would probably outmaneuver an F-35
mmo wrote:That's the thing I love about Airliners.net, everyone is an expert!
Not having flown the 747-8, I am not an expert. However, I have over 23,000 hours of which over 10,000 are in the 747 (SP to 400), I do feel I am somewhat qualified to jump in.
1) The PIC was not (sic) reckless, irresponsible and unsafe. How can one possibly make a statement such as that? That is just idiotic! There were no excessive bank angles used, no excessive pitch angles used. The aircraft was not even close to MTOW. It was nothing more than a wing wave. Get over it.
2) The aircraft did not stalll, as the OP states. It was no where near a stall. He was not, as the OP writes, a "few knots" away from a stall. There is plenty of buffer just between V2+10 and the stick shaker activation, let alone initial buffet. So again, Get over it!!
3) Again, he did not push the aircraft to "the edges of its performance envelope " as another learned poster writes. It wasn't even close to it. Again, Get over it.
Finally, I will admit it was certainly a bit "energetic" but it wasn't unsafe or dangerous or eyewatering. It was merely someone showing off, nothing more, nothing less. Was it a smart move, probably not. Will it end his career, I doubt it. It probably did earn him a one to one chat with the Chief Pilot. Again, get over it.
But please do keep all the "expert" opinions rolling in. That's about the only thing left that is worthwhile in the "new and improved" Airliners.net!!
itisi wrote:It's topics like this that make people leave these forums.....
mmo wrote:But please do keep all the "expert" opinions rolling in. That's about the only thing left that is worthwhile in the "new and improved" Airliners.net!!
OzzyPirate wrote:Well said mmo.
If you want to restore a tiny bit of faith in this forum, just read a few of the expert YouTube comments on the OPs vid.
Accidentally wrote:There used to be (years ago) an Aerolineas Argentinas 747 classic captain on here, seemed to be an older gentleman, that posted the most informative, interesting things I've ever seen online in regards to commercial aviation and the 747. Chased away by the shenanigans. I don't know the specifics, but I miss his posts. Hope life has gone well for him.
FrmrKSEngr wrote:itisi wrote:It's topics like this that make people leave these forums.....
While the original poster may be uninformed, I don't think it is a bad topic. Hopefully the original poster is coming away with some added knowledge.
Max Q wrote:An interesting and surprising opinion from you.
Let me put forward just one scenario you seem to have discounted in your unusual defense of this Pilot, how do you think his 'airshow'
would have turned out if he had lost power in an outboard engine while in that bank so close to the ground ?
This is just one possibility to consider, jet transport planning is not about 'throwing caution to the wind' throwing out all the built in safety factors just to show off, it's designed to provide safeguards in case something goes wrong, not to protect you from your own stupidity and recklessness.
He was reckless and irresponsible , as his supervisor I would not trust him again, i'd be surprised if he hasn't done this sort of thing before, a previous poster pointed out the comparison to the B52 Commander that wouldn't listen to anyone about his increasingly reckless maneuvers close to the ground, no one did anything and he killed his whole crew.
We've had a few cowboy Pilots try this sort of thing at my airline, they are no longer with us.
If nothing else gives you pause remind yourself that Cathay Pacific, an airline of the highest standard terminated a senior Captain
for a (by comparison) fairly sedate low pass.
Max Q wrote:What he did was reckless, irresponsible and unsafe, if I was his supervisor I would seriously consider ending his employment.
Max Q wrote:The key word here is 'normal' your comparison is not valid because this idiot started his turn when barely clear of the ground and he initiated the turn aggressively, you can clearly see the spoilers come up rapidly on the down going wing. This is NOT the same as a turn initiated at 400' when you are safely clear of the ground, he was not clear, an engine failure at that point would be challenging, he had basically thrown all his performance margins out the door.
Stitch wrote:Max Q wrote:The key word here is 'normal' your comparison is not valid because this idiot started his turn when barely clear of the ground and he initiated the turn aggressively, you can clearly see the spoilers come up rapidly on the down going wing. This is NOT the same as a turn initiated at 400' when you are safely clear of the ground, he was not clear, an engine failure at that point would be challenging, he had basically thrown all his performance margins out the door.
Assuming just ferry fuel aboard, he was probably in the neighborhood of 200,000kg below MTOW. I would think that would significantly improve the performance on three engines.
pvjin wrote:He was just having a bit of fun, nothing wrong with that.
prebennorholm wrote:If there is a pilot, who feels the slightest uncomfortable copying this on a sunny summer day, then I would really hate to be a passenger on his plane when he has to land in gusting sidewind, in the dark, in rain, fog, snow, wind shear, and God knows what other nasty stuff. That's what the pilots are paid for every day until the day they retire.
Max Q wrote:Stitch wrote:Max Q wrote:The key word here is 'normal' your comparison is not valid because this idiot started his turn when barely clear of the ground and he initiated the turn aggressively, you can clearly see the spoilers come up rapidly on the down going wing. This is NOT the same as a turn initiated at 400' when you are safely clear of the ground, he was not clear, an engine failure at that point would be challenging, he had basically thrown all his performance margins out the door.
But that's not the most critical issue here, if you have an engine failure at 400' or above you are well clear of the ground , even if you don't apply corrective rudder immediately you have the altitude to sort things out, apply rudder, keep the wings level climb to a safe altitude and start the appropriate checklist(s)
The secondary effect of yaw is roll, if this Pilot had suffered a #1 engine failure with the left wingtip that close to the ground it's quite possible induced roll would have him into the ground before he could stabilize the aircraft.
Reckless, irresponsible, cowboy behavior, Airline Pilots are held to a higher standard than this, or should be, if you admire this sort of display you'd be better off (and safer) going to an airshow.
CaptainKramer wrote:On the B748 in question only carrying enough fuel for delivery flight or first sector. I can't remember where I heard this, may have been in a Documentary, but doesn't Boeing provide the Airline with a full tank of gas for "Free" for the delivery flight, which would make the B748 aircraft in question a lot heavier, but still within take off limits, minus Cargo and Pax. Still presumably, reducing margins in an engine out, bird ingest scenario while wing waving at take off.
chimborazo wrote:https://www.airliners.net/forum/viewtopic.php?f=5&t=768989
Post 12. Max Q: what's changed your view?
(FYI I didn't search for this specifically, I just like reading back the older tech-ops threads as many are "pre-nasty" a.net: good information sharing and posts written with respect for other users and colleagues in the industry).
