Classa64 wrote:So why have an AOA indicator at all?
It seems it's limited then in telling a pilot, (that cant see out the window) his AOA unless he is pitched up or down to a certain point that's within its mechanical limit correct?
Classa64 wrote:In some vehicle stability assist systems that I work on now days, and for a while now, they have a built in Yaw rate- acceleration sensors that measure vehicle inclination and acceleration for VSA operation and Brake hold functions( on steep hills to prevent roll back ).
Is such a sensor used in Aircraft to measure AOA?
From what I have seen its always a mechanical device measuring AOA( please correct me if wrong), instead of a mechanical device why not use a Sensor that's not affected by Temp and Ice build up. Or is it simply not that easy.
Chris.
Woodreau wrote:The wing stalls at the same AOA.
Since most aircraft you can't see the AOA value directly we have to use airspeed to determine what the stall speed is. The problem is that airspeed only works at 1g. As soon as you change g loading the airspeed at which the aircraft stalls changes. But the AOA remains unchanged
On carrier aircraft I don't believe they set speed bugs. Instead they use AOA through the AOA indexer for the approach speed for landing.
benbeny wrote:Woodreau wrote:The wing stalls at the same AOA.
Thanks! So the AoA is independent from airspeed then...
Florianopolis wrote:Some of the Airbus gurus on here can probably explain it in detail, but I believe the late-model Airbus's can use an inertially derived AOA (like the OP hypothesized) based on pitch, g-load, and the velocity vector.
77west wrote:Classa64 wrote:So why have an AOA indicator at all?
It is not strictly necessary - on the 737NG it is optional and Boeing chief pilot John Cashman said he does not think it is nescessary. For the pilots that is. The flight computers need it though.
Classa64 wrote:The explanations are great as well as the picks, I really thought it was simpler than all this. I guess you really do need a wind vane out in the airflow to properly and accurately measure AOA then. So can the AOA change with wind speed over the wing or is it totally based on the wings design and its angle through the flow, for instance if you increase the AOA at low speed or high speed its always going to stall at the same point.
benbeny wrote:Sorry to drag this a bit, but I have a question. When you're doing more than 1G maneuver, wing loading increases, thus increasing the risk of stall.
Does the wing stall at still same AoA, or at lower AoA when the wing is loaded more than 1G?
Classa64 wrote:And with Planes without an AoA sensor would you just rely on your Pitch to determine what your AOA is, how critical is it to know?
C.
