cduluk
JT8D variants for MD80/Super727 - need opinions!!
Tue Jan 10, 2017 5:00 pm
Hi all:
I need your input and specs for the JT8D engines on the MD80 and Super 727.
I collect 1:400 aircraft models, and am in the process of converting a regular 1:400 B727 to a Super 727. To do this, I need to swap the #1 and #3 JT8D-100 engines with JT8D-200 engines from the MD80. I need a 1:400 MD80 to serve as a donor model.
The problem is that only two "model manufacturers" make the MD80 in 1:400, but the engines aren't the same size. Either one of the model manufacturers messed up, or they both did. I need your help picking the correct one.
I'm posting this in the tech/ops section because I'm looking for actual real-life dimensions of both the JT8D-100 engines (for the 727) as well as dimensions for the JT8D-200 engines of the MD80. I was able to google "fan diameter" but not the actual cowling diameter. I also can't find length dimensions from cowling-reverser bucket. Can you guys help me with that info?
Here are some pictures comparing the two model manufacturers' renditions of the DC9-51, and MD-80, compared to images of the real thing. The DC9-51 engines are of the correct scaled size and it's used for reference.
Which manufacturer (GeminiJets, or JET-X) do you think has the correct JT8D-200 engine size? I feel like the GeminiJets model is WAY too wide, while the Jet-X is too short.
What do you think? Can you guys help me find actual engine dimensions so I can simply divide by 400 and measure it? ANY and all input is appreciated!!
VSMUT
Re: JT8D variants for MD80/Super727 - need opinions!!
Tue Jan 10, 2017 5:34 pm
Just curious, could you make a comparison shot with a 727 and an MD-80 placed end-to-end too?
cduluk
Tue Jan 10, 2017 9:24 pm
Here are more pictures comparing the two MD80s to a 727.
cduluk
Tue Jan 10, 2017 9:58 pm
I pulled the GeminiJets engines off of the MD80 and put them on a 727 to give me an idea of what it would look like. Is it just me, or are they WAY too big?
tb727
Wed Jan 11, 2017 2:21 am
Too big.
Dalmd88
Wed Jan 11, 2017 4:23 am
The JetX looks about right. I think the Gemini are way to big.
richcam427
Wed Jan 11, 2017 5:39 am
Jet-X for sure. What you've got going there with the other one is almost like a 727 with MD-90 engines (*cough* wouldn't it be awesome *cough*)
LH707330
Sat Jan 14, 2017 1:31 am
I'd advice cross-posting this on airlinercafe.com, I'm sure a few of the posters there can help you with the answer.
bhill
Thu Jan 19, 2017 9:54 pm
...bit it WOULD haul ass!!
Carpe Pices
Users browsing this forum: No registered users and 42 guests
