LGAviation wrote:it would be very hard to justify under employment laws here to prescribe no (well-groomed) facial hair unless of course there were genuine safety concerns which I highly doubt there are.
2175301 wrote:The question is how good of a seal is needed. For an O2 mask, you don't actually need a really good seal. For chemical warfare or for certain industrial pollutants you have to have a really good seal.
longhauler wrote:Where I fly, beards are not allowed. The reason quoted is that passenger reaction is not always favorable. The same reason why our uniforms must be buttoned up, our shoes shined and our pants pressed.
longhauler wrote:That is why some very respectable airlines like Qantas, British Airways and Cathay Pacific allow neatly groomed facial hair.
luftaom wrote:Are the oxygen tanks in the cockpit 100% oxygen? Air at sea level is only ~21% oxygen.
gloom wrote:The reason behind operators not pushing for a clean shave could also be somewhere different.
luftaom wrote:Thanks for that.
I know that this isn't TechOps - but it's kind of (maybe) on topic (or at least not too far off topic).
The article you linked to makes mention of a requirement for an oxygen mask to be donned if one of the crew leaves the cockpit. I've seen that mentioned before. Is that right? When one of the crew pops out during cruise to go to the loo, the other has to put the mask on?
Starlionblue wrote:luftaom wrote:Are the oxygen tanks in the cockpit 100% oxygen? Air at sea level is only ~21% oxygen.
Cockpit oxygen systems are bottled oxygen, 100%. Passenger oxygen is either chemically generated or bottled but still 100% oxygen. We breathe air (as in the mix of gases in the atmosphere) in normal operations but that is continually brought in from outside. It is not stored on board in any way.
If we depressurize at 410000 feet, air is useless. At those cabin altitudes, the pilot masks would actively be pushing oxygen into us to pressurize our lungs. If we just aspirated the oxygen "normally" from the mask, there would not be enough pressure difference to move the oxygen into our bloodstream.
Starlionblue wrote:Our ops manual states that beards are not recommended due to the oxygen mask. However there is nothing forbidding them. Modern masks stick to your face like an Alien Facehugger so I think you'd need quite the serious lumberjack beard for it to be a problem.
Picture shows modern cockpit oxygen mask:
benbeny wrote:Starlionblue wrote:luftaom wrote:Are the oxygen tanks in the cockpit 100% oxygen? Air at sea level is only ~21% oxygen.
My physiology textbook shows a diagram that shows 100% oxygen up to around FL300 has O2 partial pressure that is equal (or almost equal) to 21% oxygen at sea level... so that's why you don't need positive pressure oxygen up to FL300 if you inhale 100% O2.
At FL400 and above the oxygen partial pressure and arterial oxygen saturation drops rapidly, so that's why you need positive oxygen pressure at that altitude.
Interesting thing is, at FL400 O2 saturation is still 84%, but drops rapidly to around 50% at FL470. Because normal human being is able to maintain consciousness for short time period with O2 saturation up to 50%, that's why with quick donning mask and emergency descent that brings your altitude up to FL300 quickly can be done without positive pressure supplemental oxygen and from around FL400 pilot is required to wear O2 mask all time, in case of rapid decompression.
But my textbook could be wrong, though
Starlionblue wrote:If we depressurize at 410000 feet
Noris wrote:Starlionblue wrote:If we depressurize at 410000 feet
Blimey! What do you fly?![]()
Rgds.
Starlionblue wrote:Noris wrote:Starlionblue wrote:If we depressurize at 410000 feet
Rgds.
Haha oops!
But you must admit that depressurising at 410000 feet would be quite hazardous.
Rgds.
Haha oops!
Rgds.
Haha oops!
I think such an incident would redefine "explosive decompression." May need to get the ISS to pick up your life rafts...
Starlionblue wrote:77west wrote:Starlionblue wrote:
Haha oops!
I watched a documentary on Chris Hadfield and ISS a while back. Their emergency oxygen masks seemed to be the same ones as we have in the cockpit.
I suppose the facehugger design is pretty robust... that said on a decompression on the ISS I would be more concerned with the fact my blood is boiling out of my orifices, than how tight the mask fits. Just a personal preference, really.
The masks aren't just for explosive decompression. In the instance I saw them wearing the masks, they were conducting a smoke drill.
You can actually survive a surprisingly long time exposed to a vacuum if you have oxygen. Explosive decompression is also just one of the scenarios. Slow decompression (in both aircraft and spacecraft) would still mean you need oxygen, but you won't get that boom effect.
