Max Q wrote:Good question, always wondered the same thing, it's actually a great design and a big advantage is it cannot be ripped off by
a malfunctioning or misdirected jetway !
LAXffDUB wrote:I'm not sure if this is the right forum, but hope someone can answer or direct me.
Why did Boeing opt for that particular one? It's a style and operation akin to those on the DC-10/L1011 but quite unique for them. The rest of the 7X7 series use the type that rotate/slide when opened to rest outside the frame.
Were they copying the other manufacturers? Or were they trying a concept in anticipation of future aircraft; but subsequent dissatisfaction caused a rethink for the 777 and 787?
Max Q wrote:Any door can 'jam' in an emergency landing, don't see how the 767/ L1011/ DC10 design is any more vulnerable to this.
XAM2175 wrote:My understanding though is that this style of door, regardless of the exact method of emergency opening, has a greater risk of being rendered unopenable by fuselage deformation than both older and newer types..
benbeny wrote:XAM2175 wrote:My understanding though is that this style of door, regardless of the exact method of emergency opening, has a greater risk of being rendered unopenable by fuselage deformation than both older and newer types..
I don't get it. Would you please explain it?
StereoTechque wrote:benbeny wrote:XAM2175 wrote:My understanding though is that this style of door, regardless of the exact method of emergency opening, has a greater risk of being rendered unopenable by fuselage deformation than both older and newer types..
In case of a heavy impact resulting major deformation around the door, the door may jam around the guide rail..
The chances of this kind of situation happening do seem very remote though..
