planeophilic
Why are some IATA Airport codes named after the city/locale, while others after the Airport name?
Sat Feb 18, 2017 10:34 am
Most airports like DEL- New Delhi, or FRA- Frankfurt are named after their home location.
While some like JFK- John F. Kennedy Intl. Airport, New York, or CDG- Charles De Gaulle (Paris intl.), Paris, are named after the airports the,selves? How is this decided?
IQ 6969- If I wasn't addicted to Frog Porn, I would be perfect.
doug_or
Re: Why are some ICAO Airport codes named after the city/locale, while others after the Airport name?
Sat Feb 18, 2017 3:31 pm
First off, those are IATA codes I believe. ICAO codes are the 4 letter ones (KJFK, EGLL, etc.).
It depends, but often second airports are named after the airport since the city has already been used. Other times another airport may have already snagged the more obvious code.
When in doubt, one B pump off
diverted
Sat Feb 18, 2017 4:05 pm
Want a fun one? Take a look at Canada's airports. Some make sense like YFB. Iqaluit used to be called Frobisher Bay. YOW, Ottawa, YWG Winnipeg, YVR Vancouver. But why is Toronto Pearson YYZ? Montreal Dorval/Trudeau YUL? St John's YYT?
GalaxyFlyer
Sat Feb 18, 2017 4:12 pm
You are trying make logic out of something that is inherently arbitrary. RAF base ICAO codes are related to the phone switch network used during the Battle of Britain for example.
GF
PatrickZ80
Sat Feb 18, 2017 4:48 pm
I guess it's just what's available.
And of course, as mentioned before, you shouldn't mix up IATA codes and ICAO codes. For US airports they're mostly the same except the ICAO code has a K in front of it, but that's not the case in other parts of the world. A famous example is Boston - Ostend (in ICAO: KBOS - EBOS, in IATA BOS - OST).
Sometimes a code is already in use and you got to come up with something else. Take Groningen airport for example, which is GRQ. Sure they would have wanted GRO, but they couldn't because GRO was already assigned to Girona.
lightsaber
Re: Why are some IATA Airport codes named after the city/locale, while others after the Airport name?
Sat Feb 18, 2017 6:34 pm
I have modified the topic title to IATA.
Please continue discussion on why airports have certain codes.
You only have the first amendment with the 2nd. If you're not going to offend someone with what you say, you don't have the 1st.
LH707330
Sat Feb 18, 2017 7:49 pm
Some are pretty easy. If a city has one main airport, it often gets that city code (FRA, MUC, HAM, SFO, LAX, PDX, PEK). If the city has numerous major airports then they have to disambiguate with unique identifiers (CDG/ORY, JFK/LGA, DAL/DFW, etc.). Some also don't make much sense today for historical reasons, e.g. ORD.
PatrickZ80
Sat Feb 18, 2017 8:02 pm
And sometimes the old major airport has the obvious IATA code for the city and they had to come up with something different for the new airport. DAL is Dallas Love Field and therefor Dallas Fort Worth couldn't also be DAL. They had to make it DFW. Same is the case in Houston, where HOU is Houston Hobby airport so Houston Intercontinental had to be something else. That became IAH.
Also some codes stand for a metropolitan area instead of one specific airport. For example LON stands for London and STO stand for Stockholm. Both of these cities got multiple airports, but the code stands for the whole of them together.
mwhcvt
Tue Nov 07, 2017 8:09 am
I’m sure I’ve read in the past but not sure how much truth if any there is to it that in the early days of DXB the management/owners/leaders tried to convince DUB to sell them the right to use that code, as I say this might be some complete BS
another that I’ve always like as it’s just perfect is the codes for Oshkosh Airport which are OSH / KOSH :) that just really is perfect
Must think up a new one soon, slow moving brain trying to get into gear ;)
Balerit
Wed Nov 08, 2017 8:58 am
All airports in South Africa were named using FA as a prefix and then followed by an abbreviation of the airport name. As an example Cape Town is FACT and the IATA code is CPT while Johannesburg was Jan Smuts - FAJS but was renamed OR Tambo Intl - FAOR, IATA code JNB. When the airport has a persons name then that is used, otherwise it is the city's name that is used.
Licensed Aircraft Maintenance Engineer (retired).
CyBeRino
Fri Nov 10, 2017 4:09 am
Although I wouldn't put it past those crazy Arabs to try to do such a thing, I would expect it to be extremely impossible to actually get it done.
ro1960
Wed Nov 15, 2017 9:07 pm
When cities had just one airport the 3 most obvious letters from the city's name were used. Then with a second field, the airport had to have different names hence a different 3-letter code referring to that name. Of course duplication are not allowed so you have to change one letter like for Groningen as mentioned above. And there are cases like Canada that has their own rules.
As for the "X" in LAX and PDX, it dates back when they transited from 2 to 3 letter codes (LA > LAX, PD > PDX).
You may like my airport photos:
https://www.flickr.com/photos/aeroports
Users browsing this forum: Starlionblue and 9 guests
