VSMUT wrote:I have seen wireless sets in use in Copenhagen. They plug a device/antenna into the aircraft's external headset plug, and it transmits to the headset. Never seen it anywhere else.
longhauler wrote:VSMUT wrote:I have seen wireless sets in use in Copenhagen. They plug a device/antenna into the aircraft's external headset plug, and it transmits to the headset. Never seen it anywhere else.
We tried those about 5 years ago. We no longer use them as there was always tooo much static interference. I am guessing, mostly from the tug as the frequency of the static changed with tug engine rpm.
VSMUT wrote:We, where in the world would that be? The static interference issue doesn't surprise me though, just forgetting to switch your phone to flight-mode can cause interference in a normal headset in the cockpit.
Trimeresurus wrote:Like with a walkie talkie or a similar wireless device. It would be more convenient than the cable headphone thing that's connected to the front of the aircraft(not sure what it's called), since the ground crewman would be able to inform the pilot from a point of view other than the nose gear. Also I think it would be safer since he wouldn't have to get so close to the A/C.
