mholm59
737-9 vs. 737-10 MAX Engine Power
Tue Jun 20, 2017 12:58 pm
There have been complaints for years about how much runway it takes for a 737-9 to take off and how the engines are underpowered. With the 737-10 MAX being larger and with different engines did they address this under-power issue sufficiently where the plane can take off fully loaded with less runway needed? Any chance of a -10 barreling down a runway at SNA? :lol:
MD80, MD82, MD88, MD90, 727, 733, 735, 73G, 738, 739, 744, 752, 762, 763, 772, 319, 320, 321, CRJ200, CRJ700, EMB175, EMB135, EMB145, Q200, Q300, ATR42, E190
767333ER
Re: 737-9 vs. 737-10 MAX Engine Power
Tue Jun 20, 2017 3:42 pm
The 737-9 mainly has issues with how little it can rotate on the runway without tail striking, but it is a little underpowered too. The 737-10 is longer and heavier, but will have a slightly redesigned main gear to help with the rotation angle, so in that respect it should be the sam ears the 737-9 or maybe worse. Then comes the engines which are the same as the 737-9/8/7, if they decide not to give it extra thrust for whatever reason, it will certainly be underpowered as it is to be significantly heavier than the 737-9. Then comes the increased wing loading which will give it climb characteristics like the A321. Overall I think it will likely perform worse than the 737-9 in this area.
Been on: 732 733 734 73G 738 752 763 A319 A320 A321 CRJ CR7 CRA/CR9 E145 E175 E190 F28 MD-82 MD-83 C172R C172S P2006T
AirlineCritic
Tue Jun 20, 2017 5:35 pm
Except that we don't really know what the gear redesign is.
ikolkyo
Tue Jun 20, 2017 9:03 pm
Nothing official but I heard CFM managed to get 31K for the -10 and the gear should help the 10 get a larger rotation angle.
SCAT15F
Tue Jun 20, 2017 9:37 pm
I read something similar too, that the -10 will get a thrust bump after all...
ODwyerPW
Wed Jun 21, 2017 8:23 pm
CFM-56 on 737-900ER has a thrust of 28.4k
Leap-1B on 737-9MAX has a thrust of 28.0k
So a boost of the Leap-1B for the 737-10MAX to 31k is significant. More than a 10% thrust increase. With the landing gear mod shifting the pivot point back a bit and the thrust increase, I'm really looking forward to seeing it's takeoff performance.
*edited - replaced c.o.g. with pivot point... they are not the same... i hastily typed...
learning never stops.
ikolkyo
Wed Jun 21, 2017 9:00 pm
Small correction on your thrust numbers -
CFM56-7B27
Maximum take-off thrust - 27.2K
Continuous thrust output - 26K
LEAP-1B28
Maximum take-off thrust - 29.3K
Continuous thrust output - 28.7K
The LEAP seems to have a 2K advantage over the CFM56, which makes sense since the MAX is a slightly heavier frame.
My sources:
LEAP-1B - https://www.easa.europa.eu/system/files ... EAP-1B.pdf
CFM56 - https://www.easa.europa.eu/system/files ... 03_1.0.pdf
SCAT15F
Wed Jun 21, 2017 10:35 pm
Plus, assuming the max tow is increased by 5k as some here have suggested, its wing loading is still decently lower than the A321/LR.
77west
Sat Jun 24, 2017 9:20 pm
The gear look to be telescopic, not semi-levered, so who knows how much better this could make the takeoff performance!
77West - AW109S - BE90 - JS31 - B1900 - Q300 - ATR72 - DC9-30 - MD80 - B733 - A320 - B738 - A300-B4 - B773 - B77W
Revelation
Tue Jun 27, 2017 2:51 pm
Relevant to this thread, from Karel's post at viewtopic.php?f=3&t=1366149&p=19635797#p19635713
But Attarian’s letter lists several more features that Boeing has added to the aircraft to “improve the aircraft and better address some of the operational issues we see in the 737-900/ER variants”.
The upgrades include an “improved flap design” that enables more approaches and landing at Flaps 40, the slowest-speed setting for the 737.
Boeing also adjusted the maximum landing weight centre of gravity grid in a way that will avoid “tail tip” events. Some airlines use special tail stands to prevent a 737-900 with a heavy rear cargo load from tipping the nose up at the gate.
Boeing also improved the body contour of the 737 Max 10 to reduce the risk of tail strikes, Attarian writes.
And, of course, that thread had some interesting videos about the MAX10 landing gear concept.
The heart has it's beaches, it's homeland and thoughts of it's own
The heart has it's seasons, it's evenings and songs of it's own
Varsity1
Wed Jun 28, 2017 10:38 pm
We can speculate, but we don't have enough concrete details to say for certain.
I suspect it's performance will be very similar to the 739ER.
"PPRuNe will no longer allow discussions regarding Etihad Airlines, its employees, executives, agents, or other representatives. Such threads will be deleted." - ME3 thug airlines suing anyone who brings negative information public..
ikolkyo
Thu Jun 29, 2017 1:48 am
[quote="Varsity1"]We can speculate, but we don't have enough concrete details to say for certain.
I suspect it's performance will be very similar to the 739ER.[/quote
I'm expecting it to be better honestly, they are making quite a few improvements to make the -10 more attractive performance wise compared to the -900ER. They're making changes to the flaps, gear, drag improvements and etc.
xdlx
Sun Nov 05, 2017 6:19 pm
What ever happened with with better T to W ratios! So if Leap could do 35k this would be ideal!
WIederling
Sun Nov 05, 2017 6:38 pm
That predominantly is stuff for getting airborne ( and back ).
But it won't change economic in flight airframe performance.
didn't they go over the airframe with a fine comb for the MAX already?
Murphy is an optimist
ikolkyo
Sun Nov 05, 2017 6:44 pm
That’s exactly what I was getting at, -900ER isn’t very stellar on getting airborne quickly.
Max Q
Mon Nov 06, 2017 12:23 am
An engine itself cannot be ‘underpowered’ that makes no sense
Aircraft can have engines installed that provide a less than desirable thrust to weight ratio then they are underpowered
On a different aircraft that same engine
could provide a far greater level of performance
It’s not the engine, it’s what it’s attached to !
Mon Nov 06, 2017 12:35 am
Indeed. Well put.
I am reminded of an old SlamClick post:
Wings don't fall off airplanes. Airplanes fall off their wings. It is, after all, the wing that does the flying.
parapente
Mon Nov 06, 2017 9:35 am
I think there were some big decisions behind the dash 10 even if it sounds like a simple 'upgrade'.As stated above it's not.Its actually very complicated with a raft of changes required to wring every last drop of performance out of the a/c.
I wonder in fact whether Airbus would have even factored a dask 10 (with these performance peramiters) as even possible.
But it's a major long term investment by Boeing meaning the MAX fa,only is with us for the long term and the abandonment of the three aircraft strategy.Thus the MOM could be described as a direct result of that decision.Probably a good decision too.
WIederling
Mon Nov 06, 2017 4:22 pm
parapente wrote:
I wonder in fact whether Airbus would have even factored a dask 10 (with these performance perameters) as even possible.
My guess would be they have some good inkling on scope and associated cost involved.
lightsaber
Sat Nov 11, 2017 5:42 pm
I hear noise about a -10MAX thrust bump, but not a dramatic increase. I haven't even heard 31k, except here on a.net. But every bit helps.
There are always more areas of laminar flow that could be improved. Every time it is a cost/time/benefit calculation. Airbus knows the wing root of the A320 could be improved, but it didn't make NEO EIS. Eh... Later. Same with the MAX. Then the new engine disturbs wing flow, so new corrections will be done around the engine.
You only have the first amendment with the 2nd. If you're not going to offend someone with what you say, you don't have the 1st.
WIederling
Sun Nov 12, 2017 10:43 am
Wasn't the MAX engine integration declared perfect and Boeing excelling over itself here? :-)
apropos: would there be any gains from closing the thrust gate in the high lift arrangement ?
lightsaber
Tue Nov 14, 2017 6:22 pm
There is no perfect. There is always separation that can be improved.
Today's wings are 6% short of what could be designed as the industry is so conservative.
SCAT15F
Tue Nov 14, 2017 9:32 pm
"perfect" meaning the best they could do without designing taller landing gear. They basically just crammed the engine into the wing.
Users browsing this forum: HAWKXP, m007j and 10 guests
