Idlewildspotter
Any Airports with 3+ degrees approach
Thu Jul 20, 2017 1:51 am
With the vast majority of approaches being the standard 3 degrees, other than LCY, are there any 3.5, 4, 4.5, or 5 degree approaches out there?
Thanks/
Instagram: @JFKSPOTTING
portcolumbus
Re: Any Airports with 3+ degrees approach
Thu Jul 20, 2017 1:58 am
ILS 1L at LAS is 3.4
ILS 12L at North Las Vegas is 3.2
kliff0rd
Thu Jul 20, 2017 2:27 am
KSAN RNAV 27 is 3.5 degrees and ILS 09 is 3.1 degrees.
Redbellyguppy
Thu Jul 20, 2017 2:37 am
San Diego
Wayfarer515
Thu Jul 20, 2017 2:40 am
MHTG/TNT of course. 3.5 deg in both approaches.
GalaxyFlyer
Thu Jul 20, 2017 3:18 am
KVNY Van Nuys, plus loads of GA airports. In Europe, look at Sion and Lugano, CHE, Chambery, FR
GF
skyhawkmatthew
Thu Jul 20, 2017 4:48 am
The ILS Y approaches to 07L/25R at FRA are 3.2°.
The LOC 25L at HKG is a very sporty (for a heavy) 3.8°.
Qantas - The Spirit of Australia.
vhqpa
Thu Jul 20, 2017 5:47 am
Several airports in Norway have greater than 3° approaches especially in the north. From the top of my head Tromsø has 4° on both RNAV and ILS approaches to each runway end.
"There you go ladies and gentleman we're through Mach 1 the speed of sound no bumps no bangs... CONCORDE"
TripleDelta
Screener
Thu Jul 20, 2017 4:03 pm
There are several in mainland Europe as well (though not that far above 3):
  • Rome Fiumicino (FCO): ILS 34L is 3.5°
  • Zurich (ZRH): ILS 28 and 34 are 3.3°
  • Pula, Croatia (PUY): ILS 27 is 3.2°
  • Sarajevo, Bosnia (SJJ): ILS 12 is 3.2°
Hawkeye: "It doesn't make any sense."
Radar: "Well, none of it makes any sense. You just have to send in the right number of forms." - MASH 4077
greg85
Thu Jul 20, 2017 5:36 pm
Heraklion, Napoli, Marseille, Bodrum, actually there are lots of them all over Europe. Can't remember them all. The strange thing I find is that there are a good number of places that have a 3 degree ILS, but you then find they'll also have a VOR approach with a steeper approach.
Woodreau
Fri Jul 21, 2017 2:17 am
Aspen LOC-DME 15 is 4.55 degrees.
kitplane01
Fri Jul 21, 2017 6:48 am
Is it not the case that steeper approaches reduce landing noise? That seems like a good thing!
TOGA10
Fri Jul 21, 2017 9:06 am
Depends. Like MRS, with its 4degree ILS/RNAV approach onto 31R, most A/C will have to be completely configured to start descending on the G/S. Thus, gear down and landing flaps out quite early on in the approach, which causes a lot of drag. Ideal once in the glide, not much thrust needed to keep your speed but before you intercept you will need a lot of thrust just to keep flying level. Ideally you do a continuous descent, which reduces flying level a lot but this is not always doable, with sometimes ATC interfering, other traffic affecting or winds are just not playing along. So, yes, once on the glide nice and quiet, before that, not so much.
I wanna go back upstairs!
kitplane01
Sat Jul 22, 2017 2:05 am
I would think (I'm a pilot, but not an airline pilot) that most approaches are quite high before established on the glideslope, and that noise at these altitudes is unimportant. Isn't the outer market like 4-7 miles out??? And airlines established before that???
FlyHossD
Sat Jul 22, 2017 2:23 am
Though no longer flown, Rocky Mountain's (DEN-Stapleton) had 6 degree glideslopes into ASE and SBS and 8 degrees into VON (Avon, Colorado - at the foot of what is now the Beaver Creek Resort).
TOGA10
Sat Jul 22, 2017 8:06 am
An overflying 747/330 makes quite some noise, even if it's flying at 3000'! Bit quieter if you live very close to the airport, not so much if you're slightly further away from the airport.
B777LRF
Sat Jul 22, 2017 8:21 am
Last time I went into Baghdad, it was a visual 10 degree descent from 10.000ft onto the runway. Didn't quite fit any criteria for 'stable approach', but was great fun to fly. The go-around, however, was the best bit of flying a commercial jet I've ever experienced; hauling around a 100ton jet in a tight, tight circuit (inside the airport perimeter) was about as good as it gets.
Signature. You just read one.
packcheer
Sat Jul 22, 2017 12:55 pm
Flying commercially, this sounds like an exciting roller coaster of a ride that few pilots get to experience (intentionally).
Things that fly, Girls and Planes...
Classa64
Sat Jul 22, 2017 1:20 pm
Why or who decided 3 degrees was going to be the standard or what seems to be the most common?
"Freedom is the miles i'm rolling on"
waly777
Thu Jul 27, 2017 9:03 pm
Toronto city airport ILS 26 is 4.8 degrees and 08 is 3.5 if I remember correctly.
The test of first-rate intelligence is the ability to hold 2 opposed ideas in the mind concurrently, and still function
Idlewildspotter
Mon Jul 31, 2017 6:31 pm
really? which aircraft?
GalaxyFlyer
Tue Aug 01, 2017 1:15 am
The C-17 does one 360 from about 20,000 to Baghdad. About 10,000 fpm down, I believe.
sgbroimp
Wed Aug 09, 2017 6:01 pm
St. Barth's (SBH) will have you hanging on your seat belt if you come in on RWY 10.
a320fan
Thu Aug 10, 2017 9:24 am
Is LHR still doing the 3.5 degree trial to see if it reduced noise?
A319, A320, A321, A330-200, A350-900, A380, 737-700, 737-800, 777-200ER, 777-300, 777-300ER, 787-8, Q300, Q400
Users browsing this forum: No registered users and 44 guests
