BravoOne wrote:Surge tanks are usually at the end of the wings?
jetmech wrote:BravoOne wrote:Surge tanks are usually at the end of the wings?
I suspect that MMW93 might be talking about the surge tank for the tail-plane fuel tank / trim tank? If so, it indeed appears that the surge tank is located in the right hand horizontal stabiliser only for the B744 and A330 / A340.
Regards, JetMech
BravoOne wrote:The reference to "trim tanks" might be a carry over from the MD11 fuel tanks in the horizontal stab?
BravoOne wrote:That was as much a part of he system as the extra 13,000 lbs of fuel. Even if you did not need the fuel for the trip, it would pump fuel aft when you climbed through 19,870', or some weird number like that. The purpose was to move the CG aft for less drag.
BravoOne wrote:I'm sure some more current MD11 person will chime in with some more accurate data
Regards, JetMech
Francoflier wrote:The stab tank on the 747 is just a 'dumb' fuel tank. It is filled if the total fuel required is in excess of a certain value (according to a fuel distribution logic between the 8 tanks) and is used almost immediately during the cruise (it empties into the center tank if memory serves).
mmo wrote:As far as the tail tank, when the CWT opened the transfer valves in the tail tank, it drained into the CWT. That tank was just about over the CG and very little change in trim resulted. I can't remember the numbers and my NNC are packed away, but I seem to remember a 3-4 hour window if the tank failed to transfer until you had to be on the ground due to CG problems.
Francoflier wrote:As to why the tail surge tank is on the right... No particular reason I guess. The tank is not big enough to justify 2 surge tanks, and they had to put it somewhere...
mmo wrote:I've been scratching my head trying to remember the "surge tank is located in the right hand horizontal stabiliser only for the B744", and can't remember one being there
MMW93 wrote:Yes, the surge tank is in the tail also, not only in the wings when the airplanes have trim tanks. But anybody know why the position is on the right side?
The trim tank is for use the fuel for to balance the C.G. (Center of Gravity). Because you have disequilibrium for the flight, and if you deflect the surfaces (elevators, ailerons) you spend the fuel so, with this system (Trim Tank) you save money for the fuel.
So I read the comments, and the vent (surge tank) is the right side because he fancy the manufacturer, no?
Regards, MMW93
Starlionblue wrote:I can think of only one reason for putting it on the right instead of the left. If there is a spill you want to minimise the risk of it splashing on loaders working at the rear main hold and bulk hold doors. I know the doors aren't exactly under the stab, but they're waaaay up there. A little wind goes a long way.
Then again, that seems like a rather weak justification.
MMW93 wrote:Bravo One Interesting, so MD-11 don't use the HFST like Boeing, thanks for your support.
Stationblue So Boeing don't use the HFTS for compensate CoG (CG), no? (what is AFAlk?)
And the ventilation side of the tail tank is another mystery so Bravo One (if you can get this information also, would be useful to me.) Perhaps it is there for voice recorders and flight data, so if the fuel is spilling, can burn when combined with air and lightning and that can affect the black boxes.
BravoOne wrote:That was as much a part of he system as the extra 13,000 lbs of fuel. Even if you did not need the fuel for the trip, it would pump fuel aft when you climbed through 19,870', or some weird number like that. The purpose was to move the CG aft for less drag. I'm sure some more current MD11 person will chime in with some more accurate data
glen wrote:Starlionblue wrote:I can think of only one reason for putting it on the right instead of the left. If there is a spill you want to minimise the risk of it splashing on loaders working at the rear main hold and bulk hold doors. I know the doors aren't exactly under the stab, but they're waaaay up there. A little wind goes a long way.
Your answer is contradictory as the main cargo and bulk hold doors are on the right hand side. For the Airbus models I know it for sure and as far as I can see also for the 747 models. Ironically the MD11 had the bulk door and the vent tank both on the left hand side...
But your input gave me another idea. When fueling with passengers on board, we need to provide a clear area at the left aft passenger door in order to have space there for an eventual evacuation. I don't know if this is a general rule to have this area on the left hand side or if it is a company specific rule. However it makes sense to have the primary evacuation side on the opposite side of the vent tank for the case of some malfunction during fueling. And as it makes sense to have this clear area also on the opposite side of all the loading activity, this could indeed be a reason to have the vent tanke on the right hand side.
But as I already said, I don't know if it is a general rule, to have the clear area on the left hand side. I also don't remember, how we handled this on the MD11. With my above idea it would have made sense to have the clear area on the right hand side with the MD11, but I don't know anymore.
And looking at the fact about the MD11 having the vent tank on the left hand side (that's at least what the schematics indicate), I think the 747 and the A330/340 have it both on the right hand side just by pure chance.
mmo wrote:The tail tank on the 744 is only used for range extension. It is not used for CG trimming as other aircraft have. It provides roughly one hour of additional range.
