Fedric1234
maximum speed
Mon Oct 02, 2017 2:32 pm
What is the maximum speed reached during the flight?
The Best company in the world Taxi Airport Transfer
GalaxyFlyer
Re: maximum speed
Mon Oct 02, 2017 3:17 pm
What do you mean--indicated, Mach, true airspeed? In what flight regime? By what type?
IPFreely
Re: maximum speed
Mon Oct 02, 2017 4:09 pm
When asked the way it was asked, the OP is almost certainly asking about ground speed.
gloom
Re: maximum speed
Mon Oct 02, 2017 6:25 pm
There are too many variables to answer.
Civil/military/experimental/all?
Any altitude or restricted?
Do we include vertical launched objects such as rockets?
What powerplant? Any, rocket, jet, piston?
Judging whether GS/TAS/IAS and what units is the least we should worry about.
Adam
Aptivaboy
Re: maximum speed
Mon Oct 02, 2017 7:15 pm
The fastest? That's easy...
LUDICROUS SPEED!!!!!!!!!!!!!!
https://www.youtube.com/watch?v=ygE01sOhzz0
B777LRF
Re: maximum speed
Tue Oct 03, 2017 8:38 am
Highest speed is reached during the cruise phase, the exact amount of which depend mainly on the aircraft type and how much you work the engines. A 737 Classic, for example, typically cruises at Mach 0,75. An A320 usually does around .78. A 747 is around .85 and a Gulfstream 650 can make it to .92.
In other words 'how long is a piece of string'.
Signature. You just read one.
maortega15
Re: maximum speed
Tue Oct 03, 2017 9:27 am
Depends on how you cut it. :mrgreen:
ChrisKen
Re: maximum speed
Tue Oct 03, 2017 12:10 pm
Twice the length from it's centre to one end. :roll: Works every time :lol:
Fedric1234
Re: maximum speed
Tue Oct 03, 2017 12:14 pm
GalaxyFlyer, yes
Fedric1234
Re: maximum speed
Tue Oct 03, 2017 12:35 pm
Gloom thanks your reply.
1) everyone
2) Any altitude
3) no
4) jet
Woodreau
Re: maximum speed
Tue Oct 03, 2017 1:40 pm
I would imagine the fastest true airspeed of an aircraft would be at the altitude where you transition from indicated airspeed to indicated Mach.
For example for a CRJ-700 the transition is at FL316 indicating 335kts and M0.85 you get a true airspeed of around 495kts
For a 320 the altitude is FL246 at 350kts and M0.82.
That’s if you ride the edge of the envelope.
When you climb higher than the altitude of the speed/Mach transition, your Mach number remains the same but your true airspeed will decrease. Using the CRJ-700 example flying at M0.83 at FL360 will result in a true airspeed of around 465-470kts
The winds then affect the actual ground speed achieved by the aircraft.
SheikhDjibouti
Re: maximum speed
Tue Oct 03, 2017 1:51 pm
1) everyone
2) Any altitude
3) no
4) jet
I realise you are new to these boards, as indeed I am too, so maybe you will permit me to help clarify your question/comment.
Gloom wrote / you answered...
Civil/military/experimental/all? "everyone"
Any altitude or restricted? "Any altitude"
Do we include vertical launched objects such as rockets? "no"
What powerplant? Any, rocket, jet, piston? "jet"
Unfortunately this still leaves us asking more questions.
Are you asking a simple question, i.e. what is the fastest aircraft ever? The main candidate would be the SR-71
Or are you asking something more complicated, such as the fastest speed that a particular type of aircraft might achieve? (typically in level flight)
Whilst it is great to open a discussion here on a.net, I also find that Wikipedia is usually a good resource
https://en.wikipedia.org/wiki/Flight_airspeed_record
Fedric1234
Re: maximum speed
Tue Oct 03, 2017 2:54 pm
Thank you for your reply, I am new to these boards.
B777LRF
Re: maximum speed
Thu Oct 05, 2017 5:52 pm
Start here: https://www.nasa.gov/sites/default/file ... le_k-4.pdf
Osiris
Re: maximum speed
Sat Oct 07, 2017 6:17 pm
1) everyone
2) Any altitude
3) no
4) jet
Mach speeds from 0.78-0.92 would pretty much cover all commercial jets in currently in operation. At 35,000ft this would equate to 515mph-610mph. Most modern widebody jets (like the 787 or a350) cruise at mach 0.85, which is 564mph at 35,000ft.
However, in terms of how fast you're moving over the ground (ground speed) it varies wildly due to wind. Aircraft can fly into 150mph headwinds, reducing their ground speed by that amount, or fly with a 150mph tailwind, increasing the ground speed by that amount. Incidentally, I was on a 747-400 from the US to the UK and our tailwinds were so strong that the ground speed on the moving map read 750mph.
To give you anything more detailed than that you're going to have to be more clear of what you need.
Re: maximum speed
Sun Oct 08, 2017 12:40 am
As hinted above, one of the issues with answering the question is that an apparently simple concept such as "speed" is not that simple in an airliner. We have indicated airspeed, calibrated airspeed, equivalent airspeed true air speed, Mach and ground speed. The relations between them are not constant. They vary due to density, compressibility effects and wind.
For example in the cruise we might be at Mach 0.82 with a ground speed of 480 but the indicated airspeed is only 240, while 20000 feet lower indicated airspeed might be 310 with a lower ground speed and Mach 0.6.
You can get lots of fun info here, including the maths. https://en.wikipedia.org/wiki/Airspeed
On the 330 normal cruise is at Mach 0.82. On the 350 it is M0.85. Ground speed with nil wind is around 480 knots. However given wind effects ground speeds anywhere in the 350-600 range aren't unusual
Users browsing this forum: No registered users and 16 guests
