evank516
737-700 vs 737 MAX 7 Short Field and Hot/High Performance
Tue Oct 03, 2017 1:47 pm
I was wondering how the 737 MAX 7 will perform compared to the 737-700 on short runways and at hot/high airports? I know the 737-700 can perform relatively well on short runways (see EYW), but I'm curious as to whether that characteristic was retained with the MAX 7 or any of the new MAX aircraft?
CHI87LG
Re: 737-700 vs 737 MAX 7 Short Field and Hot/High Performance
Tue Oct 03, 2017 1:51 pm
Directly from the horse itself:
While the 737 MAX has its most improved performance in cruise, which will
improve the payload range capability by a percentage, the 737 MAX may have
slightly better performance in regards to field length limited takeoff and landing
charts. Using the existing 737NG charts will be a conservative estimate.
The MAX 7 is heavier and carries less fuel but it goes further and takes off in a shorter distance.
evank516
Tue Oct 03, 2017 1:53 pm
So do you think the MAX 7 could handle an airport like EYW?
phxa340
Tue Oct 03, 2017 1:58 pm
Doesn't Delta already bring in the 700 to Key West ? Or do you mean non weight restricted ?
Chemist
Tue Oct 03, 2017 1:59 pm
I think the NG 700 has handled EYW, so you'd assume so given the above information.
evank516
Tue Oct 03, 2017 2:00 pm
DL does bring the 700 to Key West. The only weight restriction is the one checked bag rule. I was just curious if this feature was retained with the MAX line.
ikolkyo
Tue Oct 03, 2017 2:03 pm
I wonder if the MAX 7 could be fitted with the thrust rating of the MAX 10, that would be pretty interesting.
TropicalSky
Tue Oct 03, 2017 2:12 pm
I missed this info......what's the thrust rating between the models?
tjwgrr
Tue Oct 03, 2017 2:22 pm
The MAX 7 SP - a pilot's dream
Direct KNOBS, maintain 2700' until established on the localizer, cleared ILS runway 26 left approach.
ikolkyo
Tue Oct 03, 2017 2:23 pm
The MAX 10 will have 31K LEAP-1B engines, from the Boeing website I’m seeing the MAX 7 as being fitted with LEAP-1B in tthe 26-29K thrust range.
wnflyguy
Tue Oct 03, 2017 3:01 pm
I believe DL will be switching all Key West operations to C300's in the future.
WN 700's handle the airport just fine!
The pilot work group kept complaining the Runway safety margins were to thin to keep operations at Key West.
I believe WN pushed Boeing for better short field performance with 7MAX with plans for SNA and BUR in mind so it could successfully operate markets like Hawaii and longer flights without payload restrictions.
COPA, WestJet and Ryan air are also pushing for a additional performance with the 7MAX.
Hopefully Boeing can deliver.
Flyguy
my post are my opinion only and not those of southwest airlines and or airtran airlines.
MIflyer12
Tue Oct 03, 2017 4:33 pm
Delta bought its few original -700s equipped for short field ops in mind, did it not?
viewtopic.php?t=762415
LH707330
Tue Oct 03, 2017 8:01 pm
I think you'd run into moment arm issues due to the shorter tube. Same reason the 319 doesn't get the moist powerful ones in its range.
evank516
Tue Oct 03, 2017 8:26 pm
Flyguy
Not the CS300, but definitely the CS100, however we need to remember that they won't be basing them out of ATL at first. Though it would be a prime time to re-launch NYC-EYW either from JFK or LGA.
sunstar
Tue Oct 10, 2017 1:52 pm
Do any of the 737's MAX aircraft come with the Short Field Package like on the NG's
BoeingGuy
Tue Oct 10, 2017 11:21 pm
They all do. The Short Field Package is baseline on the MAX.
enzo011
Wed Oct 11, 2017 7:59 am
Is this before the slight stretch of the 737-7MAX or just a general comment on the whole family?
WIederling
Wed Oct 11, 2017 8:19 am
The Mk2 incarnation of the 7MAX now is a _simple shrink_ of the 8MAX. ( to slightly above the length of the -700/-7MAX Mk1.)
Murphy is an optimist
CHI87LG
Wed Oct 11, 2017 12:54 pm
Just a general comment on the new MAX planes. They are heavier without fuel, but carry less fuel - and use much less fuel at cruise. It's somewhat remarkable that it works out that way.
WIederling
Thu Oct 12, 2017 10:29 am
Nothing remarkable about it at all as it is the primary design objective.
You accept higher structure or engine weights for an even higher gain in fuel efficiency.
( and explains why the older model still may perform better on the shortest routes.)
737tanker
Thu Oct 12, 2017 1:50 pm
wnflyguy
It wasn't pilots complaining about the short runway that caused WN to pull out of EYW but the fact that WN couldn't get the same OpSpecs for a wet runway that FL had, and DL currently has. That meant that anytime there was any moisture at EYW WN had to drastically limit the number of passengers. The FAA was reluctant to approve the new OpSpecs due to the runway overruns that WN had at BUR and MDW as well as other issues.
BawliBooch
Thu Oct 12, 2017 2:23 pm
Somewhat related question: Can a 737 MAX8 with 168 seats operate a 2/3 hour sector without load restrictions from a 9000 ft runway 10700 feet Above Sea Level? Or will the airline have to maintain a subfleet of 737 MAX7's to do the route?
Mr.Kapoor's favorite poodle! on twitter @Banwaarilal
DiamondFlyer
Thu Oct 12, 2017 2:38 pm
Flyguy
Not only that, but Delta would have to order the CS300, in order to actually operate the thing...
From my cold, dead hands
767333ER
Fri Oct 13, 2017 2:06 am
Flyguy
Or just use their CS100s if/when they end up getting them.
Been on: 732 733 734 73G 738 752 763 A319 A320 A321 CRJ CR7 CRA/CR9 E145 E175 E190 F28 MD-82 MD-83 C172R C172S P2006T
lightsaber
Sat Oct 14, 2017 3:55 pm
Tail size (force) times moment arm determines the maximum thrust. However, there are work arounds. The C-series has a higher thrust option that only kicks in above 100kts. This allows enough tail force to counter the slight addition of thrust.
Unless a taller tail is put on (for example, airbus could put the A318 tail on the A320), the MAX 7 thrust will be rudder/tail area limited. To others, this is due to the engine out scenario where either the tail counters a big torque disparity (one engine is just drag, the other is at maximum throttle as controlled by the FADAC), or the plane does the cartwheel of death.
So the MAX 7 could have more thrust if that added thrust is only available at some air speed. Now, weight would be added to handle the stresses of the added thrust, so when the shortfield performance isn't needed, it is just cost as every kg of added weight ends up costing about $500 per decade of operation (more fuel burn, break and tire wear). So how does Boeing handle this?
WIth the A321LR, airbus is putting in all the weight for all planes as the manufacturing cost savings and improved resale makes everyone happy. A small thrust increase wouldn't add much weight, but how many more sales to pay for the engineering and the more expensive part for a small modification, the flight testing. For you have to repeat noise, takeoff, and crosswind.
For the MAX 7, Boeing should look into leading edge treatment as Airbus is doing for the A320NEO shortfield kit.
https://www.flightglobal.com/news/artic ... ne-416903/
Lightsaber
You only have the first amendment with the 2nd. If you're not going to offend someone with what you say, you don't have the 1st.
WIederling
Sat Oct 14, 2017 5:55 pm
Isn't SHARP primarily about optimizing the wing to body fairing?
lightsaber
Sun Oct 15, 2017 1:55 am
Yes. I mis-typed, for while it is the leading edge of the fairing, what I wrote implied more. The NG would benefit from similar work. Heck, ever since the F-17/F-18, everyone knows the trick of stopping separation at the wing root.
WIederling
Sun Oct 15, 2017 8:23 am
Does the NG ever develop that issue?
The 737 Dachshundfeet limit rotation ( lack of adequate lift at lower speeds ) and thus flow separation should be less of an issue?
