FoxtrotSierra
The 737MAX has a GE90 style startup noise (but quieter)
Fri Oct 13, 2017 7:40 am
After watching several videos aboard WN's 737MAX, I noticed a rumble very similar to the tune of GE90's on startup. I have also heard this on the 787 as well, so I am pretty sure this is a GE phenomenon. Anyway, I found it interesting to note that soon, all Boeing aircraft including 737's will have the signature GE startup rumble which used to be unique to just the 777.
Startup at 8:20
https://www.youtube.com/watch?v=cHUSqPjr3Go
Momo1435
Re: The 737MAX has a GE90 style startup noise (but quieter)
Fri Oct 13, 2017 7:44 am
All Boeing aircraft except for the RR powered 787s of course.
oldannyboy
Fri Oct 13, 2017 10:10 am
I love that rumble! Not as 'mighty' as the one of the gargantuan GE90, but still pretty impressive!
Too bad Boeing have not invested in more effective noise deadening materials for the MAX...I feel this aircraft is still a tad too noisy inside, especially given how quiet the new engines are...
oldannyboy
Fri Oct 13, 2017 10:11 am
Even the newest RR products are sporting the characteristic high-pitched whine on spool-up.... I love that too!
Narfish641
Fri Oct 13, 2017 12:19 pm
It does sound like the GE90 I agree. It has that very intimidating sound to it. I also hear a little bit of the 737NG when the gearbox for the fan blades start up.
Flew on:
SWA 737 738
Narfish641
Fri Oct 13, 2017 12:21 pm
I might be thinking wrong, but I think the 767 has a quieter engine start for some reason, hearing it in the video. Its like you don't hear anything until the engine is ignited.
Flew on:
SWA 737 738
767333ER
Fri Oct 13, 2017 3:22 pm
And the A320 and C919 (will) also sound the same starting up. The LEAP sounds a little more like a GEnx to me though.
On the 767 I’ve only experienced the CF6 and PW4000, but the reason y don’t hear them until lightoff on the videos is because the noise they make is so deep that the mic doesn’t pick it up. The CF6 though doesn’t make that much noise until lightoff, but the noise it does is very deep. All engine star noises on the 767 are quieter than the newer GE engines.
Been on: 732 733 734 73G 738 752 763 A319 A320 A321 CRJ CR7 CRA/CR9 E145 E175 E190 F28 MD-82 MD-83 C172R C172S P2006T PA-28-180
2 ears for spatial hearing, 2 eyes for depth perception, 2 ears for balance... How did Boeing think 1 sensor was good enough?!
flyboy80
Fri Oct 13, 2017 3:24 pm
I'm curious if the MAX is as loud behind the wing where the exhaust stream is, has anyone experienced it? YouTube vids are hard to tell given the level of noise and what's actually picked up.
arcticcruiser
Fri Oct 13, 2017 3:31 pm
Fan blades. Gearbox? CFM Leap?
GalaxyFlyer
Fri Oct 13, 2017 4:05 pm
Sub-idle vibration range. When the rotating mass converts from geometric balance (think shaft) to center of mass balance.
Narfish641
Fri Oct 13, 2017 5:28 pm
In a more detailed way, when the engine begins to start it sounds almost identical when a CFM56 on a 737NG starts its engines. Then it sounds like the deep rumble of the GE90 as it starts spooling up, then when the engine ignites, it sound like the GEnx when lit.
Flew on:
SWA 737 738
arcticcruiser
Fri Oct 13, 2017 5:49 pm
Whatever. But the Leap is NOT a geared fan engine.
Narfish641
Fri Oct 13, 2017 7:22 pm
Thanks for the correction.
Flew on:
SWA 737 738
kabq737
Fri Oct 13, 2017 8:34 pm
It’s really high pitched on takeoff.
Been on: 320, 321, 333, 733, 73G, 738, 739, 744, 752, 763, 764, 772, 789, C208, CR7, CR9, BE20, MD83, MD88, MD90, E70, E75, E90, TRIM
Flown: SEEKER, C150M C172N, C172R, C172S, C182RG, DA40, PA-46
KanaHawaii
Fri Oct 13, 2017 9:39 pm
The high pitched sound also happens on the Trent 700 engine. Hawaiian Air has those on the A330's and you hear that whine all the time upon take off.
trnswrld
Sat Oct 14, 2017 2:04 am
I am very curious to see if the max will be more quiet from the stand point of someone being on the ground and it flying over. Reason I ask this is the 737-800 (and maybe other NG models), is unusually loud when flying over. Let me describe my situation. So I live west of Chicago out near Naperville. I am directly under the inbound stream from the southwest and ORD inbounds fly over at 10,000 all day everyday. The 737-800 is freakishly noisy!! I'm not sure if it's an engine or airframe/aerodynamic thing or a combo of both, but it is significantly louder going over than ANY other modern aircraft. I even wanted to start my own thread on this subject but have never bothered. I will have to pay attention once the max starts flying into ORD. Sorry I sort of went off topic, but figured it's a close enough thread to talk about this in.
On a somewhat related story, another unique noise I hear from the same spot is the Airbus 319/320/321 series aircraft occasionally have a very unique sound that I think is related to the change of power settings around 10,000ft. Possibly the reduction of power to slow to 250kts at 10. Hard to describe the sound, but it's a very unique noise that's odd enough to even catch the attention of a non-aviation enthusiast. This is also from the ground and is heard just prior to the aircraft passing over. Almost sounds like the noise that's made if you blow into a beer bottle just right.
Redbellyguppy
Sat Oct 14, 2017 9:11 am
That's the sound of Airbus slats coming out.
767333ER
Sat Oct 14, 2017 10:54 pm
Gearbox in this case refers to the linkage that connects the starter/hydraulic pump/fuel pump or IDG to the turbine.
Runway28L
Sun Oct 15, 2017 12:53 am
Does the MAX have the humming sound that the NGs do when they're on the ground or parked at the gate?
I haven't been able to tell from the few videos I've seen.
barney captain
Sun Oct 15, 2017 2:38 am
The start-up on the MAX is also quite long - easily twice to three times as long as the NG.
Southeast Of Disorder
Narfish641
Sun Oct 15, 2017 4:17 am
I can kinda relate to your situation.
I live about 30 mins. from the airport (Use to since were moving), and depending on how the pattern is on the runways they take off and land, they are about a good 7,000 ft. or lower during takeoff. To me the 737 Next Gens are not that loud at take off, nor are the Airbus A320 family aircrafts. I will say however that the loudest would be the 777 aircrafts that passover. Always rumbling by, and no matter what you do you can't really drown the noise out. The irony of the GE90s XD!
But about the 737 MAX getting back to topic, I am willing to fly the MAX one day, not sure how quiet it is in the cabin vs. the cabin on the 737NG. Nor do I know how quiet it is at a standing view point, but I'll be the judge whenever I feel like spotting next week or flying next year for a second time lol.
Flew on:
SWA 737 738
CarlosSi
Sun Oct 15, 2017 7:49 pm
A lot of naysayers complain about people saying they sound the same to the 77GE; nay to them! Does JT8D on an MD80 sound like GE90? How about a CR7? a320? e175?
You haven't heard many e170s taking off or have noticed them; those are significantly and noticeably louder than most modern aircraft (aside from the MD80s under retirement, which aren't really modern anymore). If I think it's an MD80 but I'm not sure, it's usually an e170.
parmelbe
Mon Oct 16, 2017 1:09 pm
Oh, good, so it's not just me. I've noticed this as well. There's a distinct rumble on startup once the fan gets going then once it's running there's a subtle whistle over the rest of the noise. It's really neat. I've been working the MAX for a couple of weeks now and I still haven't gotten over it.
Indeed. On the NG's both engines will be running by the end of a usual push, before the ramp drives away, but now they'll just be starting up #1 by that time.
Can't really speak to this, but from the ramp it is noticeably quieter. I haven't measured it but it feels like almost 30%-40% quieter. I've stood 20-30ft away from an idling MAX and comfortably taken off my hearing protection (still wouldn't recommend doing this, obviously.)
ALL views and opinions expressed are mine ONLY and are NOT representative of those of Southwest Airlines
767333ER
Mon Oct 16, 2017 4:37 pm
Some people say all these new engines sound exactly like GE90 when spooling up or whatever, but in reality they don’t, they sound exactly how I excepted they would. Very wide chord fan and medium sized fan. As for noise, the E175 makes quite a bit, but the 737NG is still significantly louder and is the loudest thing to fly over my house other than the 737 classic.
Users browsing this forum: thepinkmachine and 8 guests
