zzaewon
Difference between A320-214 and A320-216
Wed Nov 01, 2017 9:31 pm
Hello,
I would like to know the differences between 320-214 and 320-216 model. Someone told me that back 3 digit numbers signify a fleet weight variance or its engine configuration. With that being said, are there any aircraft modifications changes?
longhauler
Re: Difference between A320-214 and A320-216
Wed Nov 01, 2017 9:57 pm
An A320-214 has CFM56-5B4, -5B4/P or -5B42P engines.
The A320-216 would have CFM56-5B6 engines.
Any other variations would be dicated by the airline buying the aircraft but would not change the model number.
767333ER
Wed Nov 01, 2017 10:50 pm
What longhauler said. The last number signifies a different engine subtype. In this case the -214’s engines are rated at 27000 lbf and the -216 are rated at 23500 lbf which same as what is used on the A319-112. The two different engines are actually the same machinery, the only difference is software limiting thrust to different ratings. I honestly don’t know why anyone would opt for the -216 and I guess that’s why they are few and far between.
Been on: 732 733 734 73G 738 752 763 A319 A320 A321 CRJ CR7 CRA/CR9 E145 E175 E190 F28 MD-82 MD-83 C172R C172S P2006T
Thu Nov 02, 2017 2:26 am
2nd digit : engine manufacturer
0 = General Electric
1 = CFM International
2 = Pratt and Whitney
3 = IAE (International Aero Engines)
4 = Rolls Royce
6 = Alliance (for the A380)
3rd digit: engine version
On the 320
-111= CFM56-5A1
-211= CFM56-5A1
-212 = CFM56-5A3
-214 = CFM56-5B4/P or CFM56-5B4/2P
-215 = CMF56-5B5/P (Thanks to A342)
-216 = CFM56-5B6/P (Uprated by 300 lb.)
-231 = IAEV2500-A1
-232 = IAEV2527-A5
-233 = IAEV2527E-A5
http://aviation.rosboch.net/?p=5
Thu Nov 02, 2017 2:28 am
Lower airport and overflight fees, and lower noise fees. The lower derate May enable operations into noise sensitive airports.
Polot
Thu Nov 02, 2017 5:41 pm
I imagine there are maintenance savings as well, as the engines are less stressed.
767333ER
Fri Nov 03, 2017 5:03 am
I guess that makes sense. So then that means those in charge of administering those fees differentiate between engine type and subtype. Maintenance costs might be slightly lower but the full cabablilites of the -214’s engine aren’t used all that often I would imagine and considering the engine can do a lot more than that on the A321 I imagine the savings would be small if any.
ikolkyo
Sat Nov 04, 2017 7:50 pm
4 = Rolls Royce
On the 320
-111= CFM56-5A1
-211= CFM56-5A1
-212 = CFM56-5A3
-231 = IAEV2500-A1
-232 = IAEV2527-A5
-233 = IAEV2527E-A5
Might wanna make some exceptions to that list, on the A320neo specifically CFM is 5 and PW is 7.
Sun Nov 05, 2017 1:21 am
4 = Rolls Royce
On the 320
-111= CFM56-5A1
-211= CFM56-5A1
-212 = CFM56-5A3
-231 = IAEV2500-A1
-232 = IAEV2527-A5
-233 = IAEV2527E-A5
The list is old. Why must manufacturers keep changing nomenclature?!? :old:
zzaewon
Fri Nov 10, 2017 7:37 pm
Hey thanks all! I'm learning new things everyday!
Users browsing this forum: OldAeroGuy, tepidhalibut and 8 guests
