rw774477
707 / 727 / 737 cockpit similarities
Sun Nov 19, 2017 5:10 am
They look identical at first glance. Any way to distinguish between these by only looking at the front of the a/c ?
767333ER
Re: 707 / 727 / 737 cockpit similarities
Sun Nov 19, 2017 5:23 am
Are you referring to the cockpit or the nose section? The cockpits of the 707 and 727 are largely the same other than the fact that the 707 has all the paraphernalia associated with having an extra engine while the 737’s cockpit regardless of generation is quite different. If you are talking about nose section, all are the same as you say so to tell the difference at first glance, glance at the rest of the plane and you can easily tell the difference even from a head on view.
Been on: 732 733 734 73G 738 752 763 A319 A320 A321 CRJ CR7 CRA/CR9 E145 E175 E190 F28 MD-82 MD-83 C172R C172S P2006T PA-28-180
2 ears for spatial hearing, 2 eyes for depth perception, 2 ears for balance... How did Boeing think 1 sensor was good enough?!
Sun Nov 19, 2017 10:44 am
Isnt section 41 the same in all three types.
However the cockput/flight deck does differ a lot.... more so after the B737 classics wete built.
DL_Mech
Sun Nov 19, 2017 12:43 pm
Here is a good visual comparison B707 vs. B737. It shows how much deeper the 707 is underneath the cabin floor.
This plane is built to withstand anything... except a bad pilot.
Former AMT on A220,A310,A319/20/21,A330,A350,B707,B717,B727,B737,B747,B757,B767,B777,DC-9,DC-10,L-1011,
MD-80/90,MD-11
Dalmd88
Sun Nov 19, 2017 2:18 pm
At DL last week we had a ANG KC135R visit TechOps for Veterans Day. Standing in that cockpit the similarities to the modern 737NG are very striking.
Max Q
Mon Nov 20, 2017 3:02 am
There are a LOT of similarities between
those three aircraft, inside and out
Boeing really pioneered what was as close
to a common cockpit that could be found
in those days
Just to list a few:
Same windows, including sliding DV / emer
gency exit
Mechanical trim wheels with fold out handles to operate stab manually as a back up
Virtually identical instrumentation, such as
ADI’s, instrument comparator, engine instrumentation, flap gauges, fuel, oil, gauges, the pressurization panel on the 727-200 and 737 is identical
Throttles, speed brake, flap handle and operation all identical, rudder / aileron trim
parking brake, nose wheel steering tiller identical
Fire handles and operation identical, the list
goes on, many systems are similar between the three types, while there are differences any Pilot going from a 707 to a 727 / 737 was very comfortable
The 727 was a respectable advance in technology over the 707 with fully powered
controls, double hinged rudder, automatic
brakes on later models as well as fully automatic pressurization
The 737 wasn’t a big leap from the 727, basically the electrical system was updated
and automated to no longer require manual
paralleling of generators and the other systems were updated slightly and placed on the overhead to allow 2 Pilot operation
GGg
longhauler
Tue Nov 21, 2017 1:51 pm
I recently sat in the cockpit of the MAX-8 and waxed nostalgic of the old 737-200s I used to fly. The family lines are clearly there.
I chuckled at a couple of the panels overhead that were directly from the old -200, (and probably earlier aircraft I haven't flown). One, even included the cutouts for gauges on the -200 that were no longer there!
CosmicCruiser
Tue Nov 21, 2017 2:54 pm
It's been many years since my 727 days but I remember the instructor, before computer learning,saying that the reason the 727 had the fire handles off set to the right was that it was essentially the no.s 2, 3, & 4 fire handles for the 707. Removing no.1 was the wheel well warning.
Max Q
Wed Nov 22, 2017 1:09 am
The 727 was such a basic, mechanical jet
There were so many noises going on, testing the fire warning you could hear the loops activating, turning on the packs on a cold morning you could hear a furnace like sound as it warmed up
On the before and after start the Flight Engineers panel was a blur of activity, lots of switching, activating and setting going on
Climbing to altitude there was often a ‘thump’ as the pressure differential increased, always accompanied by the trim wheel
whizzing around (not nearly as much as a 737 though) and of course the airflow noise was very loud
The gear handle was a great big, heavy lever with distinct detents, no delicate electronic switch here, you had to be very positive and somewhat forceful with its operation and other controls, it was a rugged, heavy duty aircraft inside and outside, very different from today’s aircraft
But what a delight it was to fly, very stable yet beautifully responsive with perfect control harmony, it was probably the most fun to fly that I’ve experienced, unforgiving on landing but if you got it right, very satisfying
And it went through turbulence like a hot knife through butter, I’ve not flown or rode on any other type that shrugged off bumps like the 727
The very flexible wing and high sweepback was just a superb combination
I like the modern aircraft, almost everything you want is handled automatically and the automation is really good (when it works)
But the 727 was my first jet and what a great way to learn, lovely
aircraft that will always have some of my best aviation memories
GGg
Users browsing this forum: Airliner1973 and 10 guests
