airbazar wrote:At nearly 12,000ft of altitude, I'd say that's a pretty big limitationIt's probably also not a very high volume destination.
workhorse wrote:airbazar wrote:At nearly 12,000ft of altitude, I'd say that's a pretty big limitationIt's probably also not a very high volume destination.
But there are A330-200s flying there, so at least sometimes, there is volume. Is the 332 so much better than the 320 and 738, performance-wise?
raylee67 wrote:757-200 was the usual equipment for Lhasa before the A319 was introduced. And 757 is famous for its take-off performance.
zakuivcustom wrote:
A319neo doesn't have a high thrust version, though (at least not yet). Max thrust on that is 24k lbf I believed.
May be the C919 will replace the A319 in Tibet airports then. The C919 uses engines with 31k lbf max thrust. If China can deploy the C919 safely to Lhasa routes, it would be a major political triumph too. I can totally see CAAC try to certify C919 for Lhasa operations. From the point of view of business, seeing C919 operating normally at such challenging airport would give overseas buyers some additional comfort and confidence too.
I can see that myself (I'm actually more surprised at the fact that C919 has a lower MTOW than an A319 but with much higher thrust). I believe they're also trying to certify the ARJ21 for "highland operation", but it's not quite there yet.
zrh177 wrote:Speaking from personal experience, the approach to Lhasa is weird. The altimeter on my watch (which is fairly reliable and works off of atmospheric pressure) actually had cabin pressure going down as we descended to Tibet! Also, there is a fairly significant military presence at the airport. I recall several Flanker-style aircraft towards the end of the runway as well as an il-76 the day we left.
workhorse wrote:I see, thanks to all for your replies.
By the way, looks like we have a business case here for the A319neo and the B737-7MAX, don't we? If an airline has a high altitude airport in its network, they will need at least a couple of "high performers" like that in their fleet. And that necessity can influence the choice of the whole narrowbody fleet for commonality reasons. Losing an order for 100 A320neos just because you don't have a 319neo (or losing an order for 100 7M8s because you don't have a 7M7) would not be nice...
raylee67 wrote:zakuivcustom wrote:raylee67 wrote:May be the C919 will replace the A319 in Tibet airports then. The C919 uses engines with 31k lbf max thrust. If China can deploy the C919 safely to Lhasa routes, it would be a major political triumph too. I can totally see CAAC try to certify C919 for Lhasa operations. From the point of view of business, seeing C919 operating normally at such challenging airport would give overseas buyers some additional comfort and confidence too.
The ARJ21 is not quite anywhere yet. I almost feel that they have given up on it.
The ARJ-21 is not a commercial success. It takes 3 aircraft to fly 4 short flights per day (6 to 8 should be normal for each aircraft).
China develops aircraft that do not fly very long. They need to figure out what is wrong in their development process. Is the ARJ the third or 4th attempt? I include the MA-60 as none flew through a heavy maintenance cycle before they we're unsafe to fly. They simply do not develop for the customer, but instead for the party.
It is really easy to screw up a design and ruin a concept.
Lightsaber
lightsaber wrote:workhorse wrote:I see, thanks to all for your replies.
These will be niche orders.
1. The A320NEO with the sharp kit or a -7 MAX.
2. The C-series has excellent performance at these conditions
3. The MRJ will make all NEO and MAX look like runway hogs.
Airbus will sell A319NEOs in the hope of such an order. But why not buy the SHARP kit with it's incredible field performance?
Lightsaber
Chaostheory wrote:lightsaber wrote:workhorse wrote:I see, thanks to all for your replies.
Lightsaber
Field and climb performance don't always go hand in hand.
Tell me, how is the sfp/sharp package relevant to engine out ceilings? The airport in question is at 12000ft elevation and from memory, the msa exceeds 6000m/20000ft. The 4 or 5t extra carried by the 320 is effectively dead weight and will kill your performance. Throw in above isa temps and/or the need for anti-ice and you'll be quaking in your boots.
