aerotech777
A350 EDP clutch
Thu Jan 04, 2018 9:58 pm
Hi,
http://www.smartcockpit.com/docs/a350-9 ... pilots.pdf
In the link above (ATA 29, page 29.3), it is said that "The Hydraulic System Monitoring Unit (HSMU) monitors EDP clutch".
-What's the function of the clutch in this EDP (engine driven pump)?
-Besides A350, are there other aircraft that their EDPs (engine driven pump) are fitted with a clutch?
Feedback appreciated.
Lpbri
Re: A350 EDP clutch
Thu Jan 04, 2018 10:48 pm
All aircraft in know of have a depressurization solenoid. This blocks the flow out of the pump when the pump is selected off. Or when the fire handle is pulled, or there is an overheat condition. The solenoid also bypasses the pump during an inflight restart.
aerotech777
Re: A350 EDP clutch
Sun Jan 07, 2018 5:11 pm
Thanks for the feedback.
I am aware of the depressurization solenoid (the switch in the cockpit should remain ON to prolong solenoid life) of the EDP.
Since A350 is[b][b] new[/b][/b] aircraft I said may be the EDP is fitted with a clutch as it is mentioned in link above. So I am wondering if the A350 EDP is fitted with clutch same as the IDG (Integrated Driven Generator) or CSD (Constant Speed Drive) on old aircraft. So I am wondering if the A350 EDP can be disconnected from the engine gearbox same as the IDG or the CSD.
It will be nice if someone (AMT, Pilot, ...) have access to the A350 AMM (Aircraft Maintenance Manual) or may be in the A350 FCOM (Flight Crew Operating Manual) to confirm if it a clutch or just depressurization solenoid. So feedback very appreciated
Lpbri, in the aircraft that I am little bit familiar (737) there is no overheat sensor in the EDP and when the fire handle is pulled the supply hydraulic valve is closed. If I am not mistaken other Boeing aircraft are fitted with EDP overheat switch.
Thanks.
jetmech
Re: A350 EDP clutch
Mon Jan 08, 2018 1:24 am
From the looks of the following, I'd say not;
http://www.smartcockpit.com/docs/takeof ... ockpit.pdf
The disconnect push buttons for the IDG's are clearly visible and configured as guarded switches which makes sense as I believe once the IDG's are disconnected they can only be reconnected on the ground
The hydraulic pumps do not appear to have a disconnect function or guarded switch - although the hydraulic supplies do - so I presume there is no clutch.
Regards, JetMech
Re: A350 EDP clutch
Mon Jan 08, 2018 3:39 am
Regards, JetMech
Correct. The IDG guarded pushbuttons (Airbus nomenclature) disconnect the IDGs and they can only be reconnected by maintenance action on the ground. The hydraulic pumps, however, can be switched on and off in flight with the "Pump" pushbuttons.
To expand, on Airbus the logic is thus:
- Red guard: Irreversible action. Use must be confirmed by other pilot. E.g. Fire pushbuttons, RAT deploy...
- Black guard: Reversible action but use (in the air) must be confirmed by other pilot. E.g. FADEC power supply pushbuttons, tank transfer pushbuttons, flight computer pushbuttons.
- No guard: No need to confirm. E.g. Engine anti-ice.
A couple of special cases: ADIRS rotary switches are not guarded (though you have to pull and twist) but use must be confirmed by other pilot if in the air. Fuel jettison pushbuttons have red guards, but obviously, you can stop the jettison. The logic is that you can close the valves but you can't suck the fuel back in, so it counts as irreversible.
jetmech
Re: A350 EDP clutch
Mon Jan 08, 2018 1:24 pm
Starlionblue wrote:
To expand, on Airbus the logic is thus.
I wonder if it was always this way?
For some reason, I have recollection of an incident involving an A340 (SQ?) where the pilot inadvertently shutoff all four hydraulic systems in-flight instead of manipulating four, fuel cross-feed valves.
Part of the reason for this was that all the overhead switches were of an identical, unguarded black push-button design.
Interestingly, I cannot find any information on this so it must be a figment of my imagination?
Regards, JetMech
Re: A350 EDP clutch
Mon Jan 08, 2018 3:52 pm
I don't know if it was always thus. I only know the 330 and 350 in detail. However no one but yourself can save you from pressing a pushbutton you shouldn't be pressing. That's why the kosher method of pressing anything while following the QRH or ECAM is to name the panel first and be very methodical. For example to turn on Crossfeed 1 on the 340, you'd read "Crossfeed one, on" from QRH or ECAM, then point at the panel with the big letters FUEL on the side (helpful hint) and say "Fuel", then you'd point at the relevant pushbutton and say "crossfeed one", then press the pushbutton, then confirm it goes to on and say "on". Innocent bystanders will think you sound a bit weird but this method really helps to mitigate wrong presses.
Re: A350 EDP clutch
Mon Jan 08, 2018 9:02 pm
aerotech777
The EDP clutch within the hydraulic pump does act very much like the electrical IDG disconnect on othe Airbus. The aircraft has two hydraulic systems at 5080 psi, each engine has two EDPs connected to the accessory gearbox.
The clutch disconnect can be used by Crew from the cockpit in response to some faults or can be activated on the pump by mechanics to dispatch the aircraft under the MEL with one of the 4 EDPs inoperative.
Once the EDP clutch is disconnected the aircraft needs to be shut down and a spring loaded reset ring pulled on the EDP pump. Run some software tests and then it back online.
While that document says the A350 has a HSMU, that is a simplification for pilots. They have data concentrators that are connected via the network to remote monitoring applications on the main servers.
The A330/340 have depressurization solenoids on their engine driven hydraulic pumps which open automatically on start etc.
The A350 electrical VFG also has a a manual disconnect and a automatic thermal disconnect. If these operate with the engine rotating (dry crank or under power) the VFG needs to be replaced. The reset ring can only be pulled on the VFG for a static disconnect.
JetMech,
The SQ incident happened before the hydraulics had guarded switches, hence their incorporation. Not sure if they were attempting a fuel crossfeed or fuel imbalance.
Starlionblue,
Some guarded switches are reversible, eg the gravity gear, fire, fuel jettison.
Re: A350 EDP clutch
Tue Jan 09, 2018 2:01 am
zeke wrote:
Starlionblue,
Fair point but I think there is some element of "Airbus logic" in those three. Granted, we may be entering splitting hairs territory.
- Pressing the fuel jettison pushbutton again stops the jettison, but does not suck the fuel back in. By that logic, the action taken is irreversible.
- Gravity gear lever action is reversible but not with the gravity extension mechanism. You get normal gear operation back if you get hydraulic pressure back. You can then use the normal gear lever.
- Fire pushbuttons shuts off the various hydraulic, pneumatic and fuel valves and deactivates the IDG. Is that last bit really reversible? The FCOM doesn't say explicitly as far as I can find.
jetmech
Re: A350 EDP clutch
Tue Jan 09, 2018 1:11 pm
I worked with an engineer who was very anal and one of his pet issues to pull you up on was pushing buttons on the overhead panel without doing the procedure you described. He did indeed look funny sitting in the flight deck alone doing this procedure. Fantastic engineer though with an encyclopaedic knowledge.
Interesting, must be one of the first aircraft with this feature?
I'm glad it wasn't a figment of my imagination. It's interesting I can find no information on the incident.
Regards, JetMech
aerotech777
Re: A350 EDP clutch
Wed Jan 10, 2018 5:35 pm
Thanks zeke for your post.
a) Does the pilot use a switch from the cockpit to disconnect in flight the EDP from the engine gearbox? If so is it the guarded switch in the Overhead panel?
I was looking to the Overhead panel in A380 in the link below and it seems there is a guarded switch to disconnect the EDP in A380:
http://www.smartcockpit.com/docs/a380-overhead-panel-light-test-on.pdf
b) Can the pilot (in flight) or the AMT (on ground) disconnect the EDP in A380?
It seems this feature (the disconnection of the EDP from the gearbox) is useful especially in flight even if each engine is fitted with one EDP.
c) Why Boeing is not using this feature in flight (used by Boeing in the IDG or VFSG) on the EDPs? I wrote "in flight" because Boeing (not Douglas) uses only one EDP per engine and there is no benefit for this feature on the ground for the dispatch.
