bhill
Approach and inclement weather
Mon Jan 08, 2018 3:12 pm
Good Day All, I am curious about approaches during inclement weather. I live about 20 miles north from KSEA, and it seems that during times of inclement weather, rain, clouds.. that aircraft are at a MUCH lower altitude while on approach. Why is this? One would think that you would want to be above the rain, etc as long as possible, and to have more altitude to work with if something did happen...gusts, shear, etc.
Carpe Pices
Re: Approach and inclement weather
Mon Jan 08, 2018 3:45 pm
Have you checked Flightradar24? With clouds and such sound carries differently so it might just be the impression you get.
An approach is an approach. Apart from cold weather corrections, the altitudes don't change due to weather.
26point2
Mon Jan 08, 2018 9:42 pm
Check the wind direction. Inclement weather brings wind from the south and, evidently, an approach over your house.
FlyHossD
Mon Jan 08, 2018 11:18 pm
[photoid][/photoid]
In the course of a normal weather - i.e., good weather - approach, the aircraft fly the same glideslope as during poor weather. In fact, not dipping below the glideslope is required by the FARs.
atcdan
Tue Jan 09, 2018 6:36 am
In many cases when conducting a visual approach on a clear day, aircraft will be turned onto final 15-20 miles out and already on the glideslope sometimes even above it. During IMC aircraft will be vectored to intercept the glideslope from below, and when simultaneous parallel approaches are in use, one runway is turned onto final at 2000, the other at 3000. This is done to ensure separation in the event one or both aircraft overshoots the final, where as on a clear day they can be visually separated from one another.
Very basic explanation, but the aircraft are flying a longer, lower final in IMC than in VMC.
Tower Controller
VNY, DFW, LAX
All posts are my own opinions and do not represent my employer or any government entity in any way!
bhill
Tue Jan 09, 2018 4:13 pm
This may be it...it seems that the usual "turn" over Seattle/Lake Union, the approach is "extended", and the turn is done farther out...
just an observation...
Carpe Pices
Users browsing this forum: Planetalk and 22 guests
